MC' Napisano Kwiecień 24, 2006 Zgłoszenie Share Napisano Kwiecień 24, 2006 Witam, Mam następujący problem. Ponieważ potrzebny mi jest plik *.ktl dla pl2 (polska klawiatura + ogonki?) do tego służy program keytab-lilo do którego opis wygląda tak: Compiling keyboard translation tables - - - - - - - - - - - - - - - - - - - LILO obtains layout information from the keyboard translation tables Linux uses for the text console. They are usually stored in /usr/lib/kbd/keytables. LILO comes with a program keytab-lilo.pl that reads those tables and generates a table suitable for use by the map installer. keytab-lilo.pl invokes the program loadkeys to print the tables in a format that is easy to parse.* * On some systems, only root can execute loadkeys. It is then necessary to run keytab-lilo.pl as root too. keytab-lilo.pl is used as follows: keytab-lilo.pl [ -p <old_code>=<new_code> ] ... [<path>]<default_layout>[.<extension>] ] [<path>]<kbd_layout>[.<extension>] ] -p <old_code>=<new_code> Specifies corrections ("patches") to the mapping obtained from the translation table files. E.g. if pressing the upper case "A" should yield an at sign, -p 65=64 would be used. The -p option can be repeated any number of times. The codes can also be given as hexadecimal or as octal numbers if they are prefixed with 0x or 0, respectively. <path> The directory in which the file resides. The default path is /usr/lib/kbd/keytables. <extension> Usually the trailing .map, which is automatically added if the file name doesn't contain dots. <default_layout> Is the layout which specifies the translation by the BIOS. If none is specified, us is assumed. <kbd_layout> Is the actual layout of the keyboard. keytab-lilo.pl writes the resulting translation table as a binary string to standard output. Such tables can be stored anywhere with any name, but the suggested naming convention is /boot/<kbd>.ktl ("Keyboard Table for Lilo"), where <kbd> is the name of the keyboard layout. Example: keytab-lilo.pl de >/boot/de.ktl Niestety w fedorze dla polecenia przerobionego dla moich potrzeb (bo tu w fedorce znalazłem ten plik)dostaję: #./keytab-lilo.pl /lib/kbd/keymaps/i386/qwerty/pl2.map.gz > ~/pl2.ktl cannot open file /usr/lib/kbd/keytables/us.map Keymap is empty # Nie mam pojęcia czemu on wybiera sobie tą domyślną ścieżkę do domyślnej "us" zamiast tej którą podałem ;/ Dodam jeszcze że nie mam zainstalowanego lilo lecz gruba. Jak więc wobec tego powinienem postępować by uzyskać ten pl2.ktl? Może robię jakiś błąd loigiczny, poprawcie mnie jeśli tak. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
