Kompilacja Cedegi Z Cvs
feodora
To tak zabrałem się za instalacje Cedegi z CVS doszłem do make i o to błąd:
WineCVS.sh - Progress(u) : Green is current
  0 = Uninstall
  1 = Cleanup
  2 = CVS checkout
  3 = Configure
  4 = Make depend
  5 = Make
  6 = Make install
  7 = Finish up
Compiling ...
--------- Error log - file /root/.WineCVS/sources/cvscedega/ErrorLog : ---------
make[2]: `libglu32.so' jest aktualne.
make[2]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/dlls/glu32'
make[2]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/dlls/ntdll'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/files'
make[3]: `files.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/files'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/if1632'
make[3]: `if1632.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/if1632'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/loader'
make[3]: `loader.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/loader'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/loader/ne'
make[3]: `ne.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/loader/ne'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/memory'
make[3]: `memory.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/memory'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/misc'
make[3]: `misc.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/misc'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/msdos'
make[3]: `msdos.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/msdos'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/ole'
make[3]: `ole.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/ole'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/relay32'
make[3]: `relay32.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/relay32'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/scheduler'
make[3]: `scheduler.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/scheduler'
make[3]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/win32'
make[3]: `win32.o' jest aktualne.
make[3]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/win32'
make[2]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/dlls/ntdll'
make[2]: Entering directory `/root/.WineCVS/sources/cvscedega/winex/dlls/kernel'
gcc -MMD -c  -I. -I. -I../../include -I../../include  -g -O2 -Wall -mpreferred-stack-boundary=2 -fno-keep-static-consts -D__const=const -fno-strict-aliasing -Wa,--execstack -D__int8=char -D__int16=short -D__int32=int "-D__int64=long long" -fPIC -D__WINE__  -D_REENTRANT -I/usr/X11R6/include -o time.o time.c
time.c: In function ‘SetTimeZoneInformation’:
time.c:479: warning: null argument where non-null required (argument 1)
time.c: In function ‘TIME_ClockTimeToFileTime’:
time.c:532: error: ‘CLK_TCK’ undeclared (first use in this function)
time.c:532: error: (Each undeclared identifier is reported only once
time.c:532: error: for each function it appears in.)
make[2]: *** [time.o] Błąd 1
make[2]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/dlls/kernel'
make[1]: *** [kernel/libkernel32.so] Błąd 2
make[1]: Leaving directory `/root/.WineCVS/sources/cvscedega/winex/dlls'
make: *** [dlls] Błąd 2
Error in Make
czy ktoś wie jak to naprawić
Gość
