Problem Z ./configure
kubast
witam!
na googlach coś niecoś znalazłem, ale tylko sobie namieszałem w głowie smile.gif
więc zwracam się do was, mam problem podczas ./configure, wywala mi taki błąd
C preprocessor "/lib/cpp" fails sanity check
ratujcie!
flag ze sciezkami jest kilka, wybierz te ktore odpowiadaja kompilatorom (bo oprocz tego pewnie istnieja ze sciezkami bibliotek - lib itp.) po fladze i znaku rownosci napisz sciezke do wlasciwego kompilatora
no spróbuj...
pół nocy siedziałem nad tym i guzik znalazłem o flagowaniu itp.
wszystkie pliki mam w odpowiednich ścieżkach, a to badziewie i tak wywala błąd!
config.log
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59.  Invocation command line was
  $ ./configure
## Platform. ##
hostname = localhost.localdomain
uname -m = x86_64
uname -r = 2.6.16-1.2096_FC5
uname -s = Linux
uname -v = #1 SMP Wed Apr 19 05:14:26 EDT 2006
/usr/bin/uname -p = unknown
/bin/uname -X    = unknown
/bin/arch              = x86_64
/usr/bin/arch -k      = unknown
/usr/convex/getsysinfo = unknown
hostinfo              = unknown
/bin/machine          = unknown
/usr/bin/oslevel      = unknown
/bin/universe          = unknown
PATH: /usr/kerberos/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/X11R6/bin
PATH: /home/kuba/bin
## Core tests. ##
configure:1563: checking build system type
configure:1581: result: x86_64-unknown-linux-gnu
configure:1589: checking host system type
configure:1603: result: x86_64-unknown-linux-gnu
configure:1611: checking target system type
configure:1625: result: x86_64-unknown-linux-gnu
configure:1672: checking for a BSD-compatible install
configure:1727: result: /usr/bin/install -c
configure:1742: checking for -p flag to install
configure:1755: result: yes
configure:1766: checking whether build environment is sane
configure:1809: result: yes
configure:1829: checking for gawk
configure:1845: found /usr/bin/gawk
configure:1855: result: gawk
configure:1865: checking whether make sets $(MAKE)
configure:1885: result: yes
configure:2067: checking for kde-config
configure:2129: result: /usr/bin/kde-config
configure:2225: checking where to install
configure:2229: result: /usr (as returned by kde-config)
configure:2284: checking for style of include used by make
configure:2312: result: GNU
configure:2460: checking for gcc
configure:2476: found /usr/bin/gcc
configure:2486: result: gcc
configure:2730: checking for C compiler version
configure:2733: gcc --version </dev/null >&5
gcc (GCC) 4.1.0 20060304 (Red Hat 4.1.0-3)
Copyright © 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2736: $? = 0
configure:2738: gcc -v </dev/null >&5
Using built-in specs.
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-libgcj-multifile --enable-languages=c,c++,objc,obj-c++,java,fortran,ada --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre --with-cpu=generic --host=x86_64-redhat-linux
Thread model: posix
gcc version 4.1.0 20060304 (Red Hat 4.1.0-3)
configure:2741: $? = 0
configure:2743: gcc -V </dev/null >&5
gcc: '-V' option must have argument
configure:2746: $? = 1
configure:2769: checking for C compiler default output file name
configure:2772: gcc    conftest.c  >&5
configure:2775: $? = 0
configure:2821: result: a.out
configure:2826: checking whether the C compiler works
configure:2832: ./a.out
configure:2835: $? = 0
configure:2852: result: yes
configure:2859: checking whether we are cross compiling
configure:2861: result: no
configure:2864: checking for suffix of executables
configure:2866: gcc -o conftest    conftest.c  >&5
configure:2869: $? = 0
configure:2894: result:
configure:2900: checking for suffix of object files
configure:2921: gcc -c    conftest.c >&5
configure:2924: $? = 0
configure:2946: result: o
configure:2950: checking whether we are using the GNU C compiler
configure:2974: gcc -c    conftest.c >&5
configure:2980: $? = 0
configure:2983: test -z    || test ! -s conftest.err
configure:2986: $? = 0
configure:2989: test -s conftest.o
configure:2992: $? = 0
configure:3005: result: yes
configure:3011: checking whether gcc accepts -g
configure:3032: gcc -c -g  conftest.c >&5
configure:3038: $? = 0
configure:3041: test -z    || test ! -s conftest.err
configure:3044: $? = 0
configure:3047: test -s conftest.o
configure:3050: $? = 0
configure:3061: result: yes
configure:3078: checking for gcc option to accept ANSI C
configure:3148: gcc  -c    conftest.c >&5
conftest.c:12:19: error: stdio.h: No such file or directory
conftest.c:13:23: error: sys/types.h: No such file or directory
conftest.c:14:22: error: sys/stat.h: No such file or directory
conftest.c:17: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
conftest.c:46: error: expected declaration specifiers or '...' before 'FILE'
configure:3154: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE "ksplash"
| #define VERSION "0.1"
| /* end confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
| #include <sys/types.h>
| #include <sys/stat.h>
| /* Most of the following tests are stolen from RCS 5.7's src/conf.sh.  */
| struct buf { int x; };
| FILE * (*rcsopen) (struct buf *, struct stat *, int);
| static char *e (p, i)
|      char **p;
|      int i;
|  return p;
| static char *f (char * (*g) (char **, int), char **p, ...)
|  char *s;
|  va_list v;
|  va_start (v,p);
|  s = g (p, va_arg (v,int));
|  va_end (v);
|  return s;
| /* OSF 4.0 Compaq cc is some sort of almost-ANSI by default.  It has
|    function prototypes and stuff, but not '\xHH' hex character constants.
|    These don't provoke an error unfortunately, instead are silently treated
|    as 'x'.  The following induces an error, until -std1 is added to get
|    proper ANSI mode.  Curiously '\x00'!='x' always comes out true, for an
|    array size at least.  It's necessary to write '\x00'==0 to get something
|    that's true only with -std1.  */
| int osf4_cc_array ['\x00' == 0 ? 1 : -1];
| int test (int i, double x);
| struct s1 {int (*f) (int a);};
| struct s2 {int (*f) (double a);};
| int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
| int argc;
| char **argv;
| int
| main ()
| return f (e, argv, 0) != argv[0]  ||  f (e, argv, 1) != argv[1];
|  return 0;
configure:3148: gcc -qlanglvl=ansi -c    conftest.c >&5
gcc: unrecognized option '-qlanglvl=ansi'
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|  return p;
|  char *s;
|  va_list v;
|  va_start (v,p);
|  va_end (v);
|  return s;
| int argc;
| char **argv;
| int
| main ()
|  return 0;
configure:3148: gcc -std1 -c    conftest.c >&5
cc1: error: unrecognized command line option "-std1"
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|  return p;
|  char *s;
|  va_list v;
|  va_start (v,p);
|  va_end (v);
|  return s;
| int argc;
| char **argv;
| int
| main ()
|  return 0;
configure:3148: gcc -Ae -c    conftest.c >&5
<command line>:1:2: error: missing '(' after predicate
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|  return p;
|  char *s;
|  va_list v;
|  va_start (v,p);
|  va_end (v);
|  return s;
| int argc;
| char **argv;
| int
| main ()
|  return 0;
configure:3148: gcc -Aa -D_HPUX_SOURCE -c    conftest.c >&5
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|  return p;
|  char *s;
|  va_list v;
|  va_start (v,p);
|  va_end (v);
|  return s;
| int argc;
| char **argv;
| int
| main ()
|  return 0;
configure:3148: gcc -Xc -D__EXTENSIONS__ -c    conftest.c >&5
gcc: unrecognized option '-Xc'
| /* confdefs.h.  */
| #include <stdarg.h>
| #include <stdio.h>
|      char **p;
|      int i;
|  return p;
|  char *s;
|  va_list v;
|  va_start (v,p);
|  va_end (v);
|  return s;
| int argc;
| char **argv;
| int
| main ()
|  return 0;
configure:3184: result: none needed
configure:3202: gcc -c    conftest.c >&5
conftest.c:2: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'me'
configure:3208: $? = 1
| #ifndef __cplusplus
|  choke me
| #endif
configure:3340: checking dependency style of gcc
configure:3423: result: gcc3
configure:3446: checking how to run the C preprocessor
configure:3481: gcc -E  conftest.c
In file included from /usr/lib/gcc/x86_64-redhat-linux/4.1.0/include/syslimits.h:7,
                from /usr/lib/gcc/x86_64-redhat-linux/4.1.0/include/limits.h:11,
                from conftest.c:12:
/usr/lib/gcc/x86_64-redhat-linux/4.1.0/include/limits.h:122:61: error: limits.h: No such file or directory
configure:3487: $? = 1
| /* confdefs.h.  */
| #ifdef __STDC__
| # include <limits.h>
| #else
| # include <assert.h>
| #endif
|        Syntax error
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
|        Syntax error
configure:3481: gcc -E -traditional-cpp  conftest.c
conftest.c:14: error: assert.h: No such file or directory
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
|        Syntax error
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
|        Syntax error
configure:3481: /lib/cpp  conftest.c
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
|        Syntax error
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
|        Syntax error
configure:3564: result: /lib/cpp
configure:3588: /lib/cpp  conftest.c
                from conftest.c:12:
configure:3594: $? = 1
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
|        Syntax error
                from conftest.c:12:
| /* confdefs.h.  */
| #ifdef __STDC__
| #else
| #endif
|        Syntax error
configure:3663: error: C preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
## Cache variables. ##
ac_cv_build=x86_64-unknown-linux-gnu
ac_cv_build_alias=x86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=yes
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_exeext=
ac_cv_host=x86_64-unknown-linux-gnu
ac_cv_host_alias=x86_64-unknown-linux-gnu
ac_cv_objext=o
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_CPP=/lib/cpp
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_cc_g=yes
ac_cv_prog_cc_stdc=no
ac_cv_prog_make_make_set=yes
ac_cv_target=x86_64-unknown-linux-gnu
ac_cv_target_alias=x86_64-unknown-linux-gnu
am_cv_CC_dependencies_compiler_type=gcc3
kde_cv_path=/usr/bin/kde-config
kde_cv_path_kde_config=/usr/bin/kde-config
## Output variables. ##
ACLOCAL='${SHELL} /home/kuba/moodin/admin/missing --run aclocal-1.7'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/kuba/moodin/admin/missing --run tar'
AR=''
ARTSCCONFIG=''
AUTOCONF='${SHELL} /home/kuba/moodin/admin/missing --run autoconf'
AUTODIRS=''
AUTOHEADER='${SHELL} /home/kuba/moodin/admin/missing --run autoheader'
AUTOMAKE='${SHELL} /home/kuba/moodin/admin/missing --run automake-1.7'
AWK='gawk'
CC='gcc'
CCDEPMODE='depmode=gcc3'
CFLAGS=' '
CONF_FILES=' $(top_srcdir)/./admin/configure.in.min $(top_srcdir)/configure.in.in'
CPP='/lib/cpp'
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DCOPIDL2CPP=''
DCOPIDL=''
DCOPIDLNG=''
DCOP_DEPENDENCIES=''
DEFS=''
DEPDIR='.deps'
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
ENABLE_PERMISSIVE_FLAG=''
EXEEXT=''
F77=''
FFLAGS=''
FRAMEWORK_COREAUDIO=''
GMSGFMT=''
HAVE_GCC_VISIBILITY=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL} $(INSTALL_STRIP_FLAG)'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
KCFG_DEPENDENCIES=''
KCONFIG_COMPILER=''
KDECONFIG='/usr/bin/kde-config'
KDE_CHECK_PLUGIN=''
KDE_EXTRA_RPATH=''
KDE_INCLUDES=''
KDE_LDFLAGS=''
KDE_MT_LDFLAGS=''
KDE_MT_LIBS=''
KDE_NO_UNDEFINED=''
KDE_PLUGIN=''
KDE_RPATH=''
KDE_USE_CLOSURE_FALSE=''
KDE_USE_CLOSURE_TRUE=''
KDE_USE_FINAL_FALSE=''
KDE_USE_FINAL_TRUE=''
KDE_USE_NMCHECK_FALSE=''
KDE_USE_NMCHECK_TRUE=''
KDE_XSL_STYLESHEET=''
LDFLAGS=''
LDFLAGS_AS_NEEDED=''
LDFLAGS_NEW_DTAGS=''
LIBCOMPAT=''
LIBCRYPT=''
LIBDL=''
LIBJPEG=''
LIBOBJS=''
LIBPNG=''
LIBPTHREAD=''
LIBRESOLV=''
LIBS=''
LIBSM=''
LIBSOCKET=''
LIBTOOL=''
LIBUCB=''
LIBUTIL=''
LIBZ=''
LIB_KAB=''
LIB_KABC=''
LIB_KDECORE=''
LIB_KDED=''
LIB_KDEPIM=''
LIB_KDEPRINT=''
LIB_KDEUI=''
LIB_KDNSSD=''
LIB_KFILE=''
LIB_KFM=''
LIB_KHTML=''
LIB_KIMPROXY=''
LIB_KIO=''
LIB_KJS=''
LIB_KNEWSTUFF=''
LIB_KPARTS=''
LIB_KSPELL=''
LIB_KSYCOCA=''
LIB_KUNITTEST=''
LIB_KUTILS=''
LIB_POLL=''
LIB_QPE=''
LIB_QT=''
LIB_SMB=''
LIB_X11=''
LIB_XEXT=''
LIB_XRENDER=''
LN_S=''
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/kuba/moodin/admin/missing --run makeinfo'
MAKEKDEWIDGETS=''
MCOPIDL=''
MEINPROC=''
MOC=''
MSGFMT=''
NOOPT_CFLAGS=''
NOOPT_CXXFLAGS=''
OBJEXT='o'
PACKAGE='ksplash'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL=''
QTE_NORTTI=''
QT_INCLUDES=''
QT_LDFLAGS=''
RANLIB=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
TOPSUBDIRS=''
UIC=''
UIC_TR=''
USER_INCLUDES=''
USER_LDFLAGS=''
USE_EXCEPTIONS=''
USE_RTTI=''
USE_THREADS=''
VERSION='0.1'
WOVERLOADED_VIRTUAL=''
XGETTEXT=''
XMLLINT=''
X_EXTRA_LIBS=''
X_INCLUDES=''
X_LDFLAGS=''
X_PRE_LIBS=''
X_RPATH=''
ac_ct_AR=''
ac_ct_CC='gcc'
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
all_includes=''
all_libraries=''
am__fastdepCC_FALSE='#'
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include='include'
am__leading_dot='.'
am__quote=''
bindir='${exec_prefix}/bin'
build='x86_64-unknown-linux-gnu'
build_alias=''
build_cpu='x86_64'
build_os='linux-gnu'
build_vendor='unknown'
datadir='${prefix}/share'
exec_prefix='NONE'
host='x86_64-unknown-linux-gnu'
host_alias=''
host_cpu='x86_64'
host_os='linux-gnu'
host_vendor='unknown'
include_ARTS_FALSE=''
include_ARTS_TRUE=''
include_x11_FALSE=''
include_x11_TRUE=''
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/home/kuba/moodin/admin/install-sh'
kde_appsdir=''
kde_bindir=''
kde_confdir=''
kde_datadir=''
kde_htmldir=''
kde_icondir=''
kde_includes=''
kde_kcfgdir=''
kde_libraries=''
kde_libs_htmldir='/usr/share/doc/HTML'
kde_libs_prefix='/usr'
kde_locale=''
kde_mimedir=''
kde_moduledir=''
kde_qtver=''
kde_servicesdir=''
kde_servicetypesdir=''
kde_sounddir=''
kde_styledir=''
kde_templatesdir=''
kde_wallpaperdir=''
kde_widgetdir=''
kdeinitdir=''
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
oldincludedir='/usr/include'
prefix='/usr'
program_transform_name='s,x,x,'
qt_includes=''
qt_libraries=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-linux-gnu'
target_alias=''
target_cpu='x86_64'
target_os='linux-gnu'
target_vendor='unknown'
unsermake_enable_pch_FALSE=''
unsermake_enable_pch_TRUE=''
x_includes='NONE'
x_libraries='NONE'
xdg_appsdir=''
xdg_directorydir=''
xdg_menudir=''
## confdefs.h. ##
configure: exit 1
