Problem Z Instalacją Kaffeine
feodora
Pobrałem kaffeine z strony projektu prubuje go kompilować ii tu błędy
[root@host154 kaffeine-0.8.1]# ./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for kde-config... /usr/bin/kde-config
checking where to install... /usr (as returned by kde-config)
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether gcc is blacklisted... yes
configure: error:
This particular compiler version is blacklisted because it
is known to miscompile KDE. Please use a newer version, or
if that is not yet available, choose an older version.
Please do not report a bug or bother us reporting this
configure error. We know about it, and we introduced
it by intention to avoid untraceable bugs or crashes in KDE.
Gość
