Instalowanie Gdesklets
Jacck
Probowalem zainstalowac w/w gDesklets i wypisuje mi brak pakietu (chyba):
checking for pkg-config... /usr/bin/pkg-config
checking for gnome-python-2.0 >= 1.99.17 pygtk-2.0 >= 1.99.17... Package gobject-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gobject-2.0.pc'
to the PKG_CONFIG_PATH environment variable
Package 'gobject-2.0', required by 'PyGTK', not found
configure: error: Library requirements (gnome-python-2.0 >= 1.99.17 pygtk-2.0 >= 1.99 .17) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your lib raries are in a nonstandard prefix so pkg-config can find them.
przypuszczam, ze chodzi tu o brak paczki geobject-2.0, ale tak do konca to nie wiem co dalej z tym zrobic. O co chodzi w :
Toz to jest jakis plik zakodowany ten pkg-config
Gość
