bisz Napisano Sierpień 2, 2006 Zgłoszenie Share Napisano Sierpień 2, 2006 [marekd@marek monto-0.1.1]$ make make[1]: Entering directory `/home/marekd/fedora/monto-0.1.1/src' gcc -Wall -Os -I/usr/X11R6/include/X11 -c docklib.c In file included from docklib.c:22: docklib.h:38:21: error: X11/xpm.h: Nie ma takiego pliku ani katalogu In file included from docklib.c:22: docklib.h:77: error: expected specifier-qualifier-list before ‘XpmAttributes’ docklib.h:117: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘dcl_get_color’ docklib.h:138: error: expected declaration specifiers or ‘...’ before ‘Pixel’ docklib.h:139: error: expected declaration specifiers or ‘...’ before ‘Pixel’ docklib.c:35: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘back_pix’ docklib.c: In function ‘dcl_get_xpm’: docklib.c:58: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:58: error: ‘XpmReturnPixels’ undeclared (first use in this function) docklib.c:58: error: (Each undeclared identifier is reported only once docklib.c:58: error: for each function it appears in.) docklib.c:58: error: ‘XpmReturnExtensions’ undeclared (first use in this function) docklib.c:60: warning: implicit declaration of function ‘XpmCreatePixmapFromData’ docklib.c:61: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:63: error: ‘XpmSuccess’ undeclared (first use in this function) docklib.c: At top level: docklib.c:76: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘dcl_get_color’ docklib.c: In function ‘dcl_redraw_window’: docklib.c:121: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:121: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:124: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:124: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c: In function ‘dcl_redraw_window_xy’: docklib.c:138: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:138: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:141: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c:141: error: ‘XpmIcon’ has no member named ‘attributes’ docklib.c: In function ‘dcl_open_x_window’: docklib.c:292: error: ‘back_pix’ undeclared (first use in this function) docklib.c:292: warning: implicit declaration of function ‘dcl_get_color’ docklib.c:293: error: ‘fore_pix’ undeclared (first use in this function) docklib.c: At top level: docklib.c:843: error: expected declaration specifiers or ‘...’ before ‘Pixel’ docklib.c: In function ‘dcl_draw_point’: docklib.c:845: error: ‘color’ undeclared (first use in this function) docklib.c: At top level: docklib.c:855: error: expected declaration specifiers or ‘...’ before ‘Pixel’ docklib.c: In function ‘dcl_draw_line’: docklib.c:857: error: ‘color’ undeclared (first use in this function) make[1]: *** [docklib.o] Błąd 1 make[1]: Leaving directory `/home/marekd/fedora/monto-0.1.1/src' mv: nie można wykonać stat na `monto': Nie ma takiego pliku ani katalogu make: *** [all] Błąd 1 [marekd@marek monto-0.1.1]$ tak wyglada sytuacja i pojecia nie mam co jest nie tak ani czego może brakować. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ecik__ Napisano Sierpień 2, 2006 Zgłoszenie Share Napisano Sierpień 2, 2006 Zakładam, że wszystkie pakiety devel masz. Pokaż: rpm -qa \*-devel A tak poza tym daj jakiegoś linka do źródła programu, zobaczę jak u mnie pójdzie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bisz Napisano Sierpień 2, 2006 Autor Zgłoszenie Share Napisano Sierpień 2, 2006 (edytowane) [marekd@marek xfe-0.88]$ rpm -qa \*-devel libogg-devel-1.1.3-1.2 glib2-devel-2.10.1-1 libidn-devel-0.6.2-1.1 pciutils-devel-2.2.1-1.2 boost-devel-1.33.1-5 libacl-devel-2.2.34-1.2 hesiod-devel-3.0.2-31.2.1 openssl-devel-0.9.8a-5.2 newt-devel-0.52.2-5.2 openldap-devel-2.3.19-4 pam-devel-0.99.3.0-2 libxml2-devel-2.6.23-1.2 libmng-devel-1.0.9-3.2.1 libXcursor-devel-1.1.5.2-2.2 xorg-x11-proto-devel-7.0-6 libXft-devel-2.1.8.2-3.2 qt-devel-3.3.6-0.4.fc5 libstdc++-devel-4.1.1-1.fc5 audiofile-devel-0.2.6-2.2.1 pcre-devel-6.3-1.2.1 libxslt-devel-1.1.15-1.2.1 tcl-devel-8.4.13-1.1 zlib-devel-1.2.3-1.2.1 expat-devel-1.95.8-8.2 libtermcap-devel-2.0.8-45 sqlite-devel-3.3.3-1.2 kudzu-devel-1.2.34.3-1 gpm-devel-1.20.1-73.3 readline-devel-5.0-3.2.1 bzip2-devel-1.0.3-2.2.1 gdbm-devel-1.8.0-26.2 libvorbis-devel-1.1.2-1.2 libcap-devel-1.10-24.2 db4-devel-4.3.29-2 slang-devel-2.0.5-5.2.1 krb5-devel-1.4.3-4.1 neon-devel-0.25.5-1.2 libselinux-devel-1.29.7-1.2 curl-devel-7.15.1-1.2.1 fontconfig-devel-2.3.94-1 libICE-devel-1.0.0-2.2 libjpeg-devel-6b-36.2.1 libXinerama-devel-1.0.1-1.2 libXdmcp-devel-1.0.0-2.2 libpng-devel-1.2.8-2.2.1 libX11-devel-1.0.0-3.FC5.0 libXrender-devel-0.9.0.2-3.2 mesa-libGLU-devel-6.4.2-6.FC5.3 libXt-devel-1.0.0-2.2 libgcj-devel-4.1.1-1.fc5 alsa-lib-devel-1.0.11-4.rc2 esound-devel-0.2.36-2.2.1 libtiff-devel-3.7.4-7 gamin-devel-0.1.7-1.2.1 libgcrypt-devel-1.2.2-1.2.1 libart_lgpl-devel-2.3.17-2.2.1 libsndfile-devel-1.0.16-8.fc5.at elfutils-libelf-devel-0.119-1.2.1 libattr-devel-2.4.28-1.2 ncurses-devel-5.5-19 gmp-devel-4.1.4-6.2.1 cyrus-sasl-devel-2.1.21-10 e2fsprogs-devel-1.38-12 rpm-devel-4.4.2-15.2 krbafs-devel-1.2.2-9.2.1 libuser-devel-0.54.5-1 lockdev-devel-1.0.1-9.2.1 python-devel-2.4.2-3.2.1 dbus-devel-0.61-3 glibc-devel-2.4-4 freetype-devel-2.1.10-5.2.1 libSM-devel-1.0.0-2.2 libXau-devel-1.0.0-2.2 libXrandr-devel-1.1.0.2-2.2 mesa-libGL-devel-6.4.2-6.FC5.3 libXext-devel-1.0.0-3.2 arts-devel-1.5.3-0.1.fc5 libgpg-error-devel-1.1-1.2.1 kdelibs-devel-3.5.3-0.4.fc5 [marekd@marek xfe-0.88]$ a link do binarki : http://dockapps.org/file.php/id/274 i ogólnie z innymi wmakerowymi dock-appami jest to samo... Edytowane Sierpień 2, 2006 przez lszk Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lszk Napisano Sierpień 2, 2006 Zgłoszenie Share Napisano Sierpień 2, 2006 docklib.h:38:21: error: X11/xpm.h: Nie ma takiego pliku ani katalogu yum search xpm ... libXpm.x86_64 3.5.4.2-2.2 core Matched from: libXpm X.Org X11 libXpm runtime library X.Org X11 libXpm runtime library libXpm-devel.x86_64 3.5.4.2-2.2 core Matched from: libXpm-devel X.Org X11 libXpm development package X.Org X11 libXpm development package libXpm.i386 3.5.4.2-2.2 core Matched from: libXpm X.Org X11 libXpm runtime library X.Org X11 libXpm runtime library Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ecik__ Napisano Sierpień 2, 2006 Zgłoszenie Share Napisano Sierpień 2, 2006 W zasadzie wystarczylo sie przyjrzec jaki blad jest zglaszany. Wpisanie ponizszej komendy powinno pomóc. yum install libXpm-devel EDIT: drobne spóznienie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bisz Napisano Sierpień 2, 2006 Autor Zgłoszenie Share Napisano Sierpień 2, 2006 problem rozwiazany Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
