Problemik Z Instalka Compiz
Krayczek
Witam wszystkich.
Chcialem sobie zainstalowac XGL ale w trakcie instalki compiz za pomoca yum-a wywala mi na koniec cos takiego :(
Running transaction check
--> Processing Dependency: libgnome-2.so.0 for package: compiz
--> Processing Dependency: libQtGui.so.4 for package: compiz
--> Processing Dependency: libbonoboui-2.so.0 for package: compiz
--> Processing Dependency: libgnome-window-settings.so.1 for package: compiz
--> Processing Dependency: libgnome-desktop-2.so.2 for package: compiz
--> Processing Dependency: libQtCore.so.4 for package: compiz
--> Processing Dependency: libgnomeui-2.so.0 for package: compiz
--> Finished Dependency Resolution
Error: Missing Dependency: libgnome-2.so.0 is needed by package compiz
Error: Missing Dependency: libQtGui.so.4 is needed by package compiz
Error: Missing Dependency: libbonoboui-2.so.0 is needed by package compiz
Error: Missing Dependency: libgnome-window-settings.so.1 is needed by package compiz
Error: Missing Dependency: libgnome-desktop-2.so.2 is needed by package compiz
Error: Missing Dependency: libQtCore.so.4 is needed by package compiz
Error: Missing Dependency: libgnomeui-2.so.0 is needed by package compiz
nie potrafie sobie poradzic z tym problemem pozdrawiam i dzieki za pomoc.
Dzis sa wybitne problemy z repozytoriami / mirrorami, puszczaj do skutku powinien Ci te zaleznosci sam rozwiazac.
Mozesz tez wyczyscic cache i go odbudowac
yum clean all
yum update
i pozniej yum install bo np libgnome-2.so.0 powinien Ci znalesc bez problemow na core i updates
[root@inferno ~]# yum provides libgnome-2.so.0
Loading "installonlyn" plugin
Loading "fedorakmod" plugin
Loading "kernel-module" plugin
Searching Packages:
Setting up repositories
macromedia                                                           [1/5]
livna        [2/5]
updates                                                              [3/5]
core        [4/5]
extras                                                               [5/5]
libgnome.i386                            2.14.0-1               core
Matched from:
libgnome-2.so.0
libgnome.i386                            2.14.1-1.fc5.1         updates
Matched from:
libgnome-2.so.0
Pozdro
problem juz rozwiazalem, okazalo sie ze gdy pisalem yum install compiz i to samo do XGL to instalowac mi chcialo wersje dla i386 a wersja fedory ktora posiadam jest 64 bitowa po dopisaniu tylko .x86_64 wszystko bez problemu sie zainstalowalo. XGL wyglada fajnie i dziala szybciutko :)
pozdrowka
