alpin19 Napisano Sierpień 25, 2006 Zgłoszenie Share Napisano Sierpień 25, 2006 Witam Na win2000 [192.168.3.14] zainstalowałem RealVNC Viewer aby móc połączyć się przez VNC ze swoją FC5 [192.168.3.82]. Kiedy próbuję połaczyć się za pomocą RealVNC otrzymuję odpowiedź o treści: VNC Viewer Error: unable to connect to host: Connection Refused (10061) Kiedy patrzę w logi vncserver'a ([alpin19@localhost log]$ tail -f /home/alpin19/.vnc/localhost.localdomain:*.log) widzę, że 'nic' się nie dzieje: ==> /home/alpin19/.vnc/localhost.localdomain:1.log <== Underlying X server release 70000000, The X.Org Foundation Fri Aug 25 10:59:34 2006 vncext: VNC extension running! vncext: Listening for VNC connections on port 5901 vncext: Listening for HTTP connections on port 5801 vncext: created VNC server for screen 0 Could not init font path element /usr/share/X11/fonts/OTF, removing from list! Could not init font path element /usr/share/X11/fonts/CID/, removing from list! ==> /home/alpin19/.vnc/localhost.localdomain:4.log <== Underlying X server release 70000000, The X.Org Foundation Fri Aug 25 11:03:30 2006 vncext: VNC extension running! vncext: Listening for VNC connections on port 5904 vncext: Listening for HTTP connections on port 5804 vncext: created VNC server for screen 0 Could not init font path element /usr/share/X11/fonts/OTF, removing from list! Could not init font path element /usr/share/X11/fonts/CID/, removing from list! [alpin19@localhost log]$ tail -f /home/alpin19/.vnc/localhost.localdomain:*.log ==> /home/alpin19/.vnc/localhost.localdomain:1.log <== Underlying X server release 70000000, The X.Org Foundation Fri Aug 25 10:59:34 2006 vncext: VNC extension running! vncext: Listening for VNC connections on port 5901 vncext: Listening for HTTP connections on port 5801 vncext: created VNC server for screen 0 Could not init font path element /usr/share/X11/fonts/OTF, removing from list! Could not init font path element /usr/share/X11/fonts/CID/, removing from list! ==> /home/alpin19/.vnc/localhost.localdomain:4.log <== Underlying X server release 70000000, The X.Org Foundation Fri Aug 25 11:03:30 2006 vncext: VNC extension running! vncext: Listening for VNC connections on port 5904 vncext: Listening for HTTP connections on port 5804 vncext: created VNC server for screen 0 Could not init font path element /usr/share/X11/fonts/OTF, removing from list! Could not init font path element /usr/share/X11/fonts/CID/, removing from list! Poradźcie proszę co zrobić ------- edit: Ok. udało mi się połączyć, ale jeszcze nie tak jak bym tego chciał, ponieważ odpala się nowa sesja Term'a i nie wiem jak dostać się do działającego już Gnome'a Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
wojtekjs Napisano Sierpień 25, 2006 Zgłoszenie Share Napisano Sierpień 25, 2006 firewall... i wszystko jasne P.S. mam nadzieję Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
rzabcio Napisano Sierpień 25, 2006 Zgłoszenie Share Napisano Sierpień 25, 2006 A na jaki port się łączysz? VncViewer standardowo uderza na 5900, natomiast jak widać w logach serwer nasłuchuje na 5901. Między innymi. Potelnetuj najpierw te porty z Win, by zobaczyć czy w ogóle masz połączenie. :: EDIT :: Nie doczytałem dopisku. VNCserver znany jest z tego, iż tworzy nową sesję Xksów (nie Terma, jak napisałeś). Do tej samej potrzebujesz uruchomić najpierw: # vino-preferences a potem # vino-session Opcja ta jest gdzieś dostępna z menu Gnome'a lecz ponieważ korzystam z Xfce (tam też można go uruchomić! ) więc nie potrafię powiedzieć w którym miejscu. Vino łączy się na display=:0 serwera Xksów. O ile się nie mylę jest to standardowy pakiet wchodzący w skład Gnome'a. :: EDIT 2 :: (_acha_ → aha) ORT! I vino nasłuchuje już normalnie na domyślnym 5900! Ogólnie - rewelacja programik! Nawe można go zdalnie uruchomić po ssh: # vino-session --display=:0 O ile ma się wyłączoną opcję potwierdzania akceptacji połączenia - trzecia opcja w preferencjach. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
virusek113 Napisano Luty 23, 2009 Zgłoszenie Share Napisano Luty 23, 2009 Witam, Mam podobny problem. Niby teoretycznie wszystko w fedorce jest uruchomione ok ale jak łącze się z windy vncviewerem to mam: unable to connect to host: Próba przeprowadzenia operacji, wykonywanej przez gniazdo, na nieosiągalnym hoście (10065) i nie wiem juz co to. Może ja coś źle robie lub zrobiłem. po włączeniu fedorki wpisuje vncserver i dostaje to: vncserver New 'localhost.localdomain:1 (root)' desktop is localhost.localdomain:1 Starting applications specified in /root/.vnc/xstartup Log file is /root/.vnc/localhost.localdomain:1.log vncconfig -iconic & [ -x /etc/vnc/xstartup ] && exec /etc/vnc/xstartup [ -r $HOME/ .Xresources ] && xrdb $HOME/ .Xresources xsetroot -solid grey xterm -geometry 80x24+10+10 -ls -title "$VNCDESKTOP Desktop" & twm & gnome-session & gnome-panel & nautilus & Czy ja coś mam skopane w konfiguracji ????????????????????? help [email protected] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
