Flash - Brak Czcionek
latino-ino
nie mialem nigdy problemów z flashem na swoim kompie, wiec nie jestem pewien czy to zadziala
uzywajac UWAGA TRUDNE SLOWO, ZANOTUJ W SWOIM PAMIETNIKU - WYSZUKIWARKI POSTÓW
trafilem na adres:
http://macromedia.mplug.org/faq.html
a tam na podpunkt 11, cytuje:
11. Most text is failing to display on Flash sites!
The plugin has bugs where it makes bad assumptions about the font configuration.
For this reason, it fails to find fonts on newer versions of X.org. You can
workaround this problem in the short-term by using these commands as root.
mkdir -p /usr/X11R6/lib/X11/fs/
ln -s /etc/X11/fs/config /usr/X11R6/lib/X11/fs/config
Read Red Hat Bugzilla #184028 for more information about this problem.
Ultimately Macromedia must fix this bug in a future version of their plugin.
moze okaze sie pomocne? jakby nie gralo zawsze mozesz spróbowac uzyc Googli
