Problem Z Klawiatura
MitS
Witam!
na samym poczatku sorry za brak polskich znakow, gdyz temat dotyczy wlasnie tego problemu.
Otoz zainstalowalem na nowo fc5 i wystapil problem nie ma poslkich znakow gdy sie wcisnie kombinacje klawiszy np. alt+a itp (prawy alt). Zainstalowana zostala polska klawiatura (przy instalacji). Jak nacisne np. prawy alt+c to w np. firefoxie wchodzi mi w gorne menu Pomoc (prawy alt dziala jak lewy :/)
jaka macie na to rade ???
w /etc/sysconfig/keyboard mam:
KEYBOARDTYPE="pc"
KEYTABLE="pl2"
natomiast w /etc/X11/xorg.conf :
# Xorg configuration created by system-config-display
Section "ServerLayout"
Identifier     "single head configuration"
Screen      0  "Screen0" 0 0
InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, a font server independent of the X server is
# used to render fonts.
ModulePath   "/usr/lib/xorg/modules/extensions/nvidia"
ModulePath   "/usr/lib/xorg/modules"
FontPath     "unix/:7100"
EndSection
Section "Module"
Load  "dbe"
Load  "extmod"
Load  "fbdevhw"
Load  "record"
Load  "freetype"
Load  "type1"
Load  "glx"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#	Option	"Xleds"		"1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#	Option	"XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#	Option	"XkbModel"	"pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#	Option	"XkbModel"	"microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#	Option	"XkbLayout"	"de"
# or:
#	Option	"XkbVariant"	"nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#	Option	"XkbOptions"	"ctrl:swapcaps"
# Or if you just want both to be control, use:
#	Option	"XkbOptions"	"ctrl:nocaps"
Identifier  "Keyboard0"
Driver      "kbd"
Option	    "XkbModel" "pc105"
Option	    "XkbLayout" "pl"
EndSection
Identifier  "Mouse0"
Driver      "mouse"
Option	    "Protocol" "IMPS/2"
Option	    "Device" "/dev/input/mice"
Option	    "ZAxisMapping" "4 5"
Option	    "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
### Comment all HorizSync and VertSync values to use DDC:
Identifier   "Monitor0"
VendorName   "Monitor Vendor"
ModelName    "Daytek DT-1770"
HorizSync    30.0 - 70.0
VertRefresh  50.0 - 150.0
Option	    "dpms"
EndSection
Section "Device"
Identifier  "Videocard0"
Driver      "nvidia"
VendorName  "Videocard vendor"
BoardName   "nVidia Corporation NV18 [GeForce4 MX 440 AGP 8x]"
EndSection
Section "Screen"
Identifier "Screen0"
Device     "Videocard0"
Monitor    "Monitor0"
DefaultDepth     16
SubSection "Display"
	Viewport   0 0
	Depth     16
	Modes    "1280x1024"
EndSubSection
EndSection
Section "DRI"
Group        0
Mode         0666
EndSection
uzywaj codebox dla dlugich listingow - uosiu
