Brak Komunikację Przez Usb Z Modemem Neostrady
fedorafan
problem jak wyżej
komenda tail /var/log/messages , daje taki efekt (podłączanie modemu)
Sep 29 20:28:22 las kernel: usb 1-1: USB disconnect, address 2
Sep 29 20:28:28 las kernel: usb 1-2: new full speed USB device using uhci_hcd and address 3
Sep 29 20:28:29 las kernel: usb 1-2: USB disconnect, address 3
Sep 29 20:28:30 las kernel: usb 1-1: new full speed USB device using uhci_hcd and address 4
czy ktos moglby pomoc???
System FC4, modem zte zxdsl 852
[root@las ~]# lsusb
-bash: lsusb: command not found
[root@las ~]# rpm -Uvh /media/disk/Fedora/RPMS/usbutils-0.71-2.i386.rpm
bĹÄ
d: otwarcie /media/disk/Fedora/RPMS/usbutils-0.71-2.i386.rpm nie powiodĹo siÄ: Nie ma takiego pliku ani katalogu
[root@las ~]# lsusb
[root@las /]# dmesg
Linux version 2.6.11-1.1369_FC4 ([email protected]) (gcc verion 4.0.0 20050525 (Red Hat 4.0.0-9)) #1 Thu Jun 2 22:55:56 EDT 2005
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000008000000 (usable)
BIOS-e820: 00000000ffe00000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
128MB LOWMEM available.
Using x86 segment limits to approximate NX protection
On node 0 totalpages: 32768
  DMA zone: 4096 pages, LIFO batch:1
  Normal zone: 28672 pages, LIFO batch:15
  HighMem zone: 0 pages, LIFO batch:1
DMI 2.2 present.
ACPI: RSDP (v000 Dell                                  ) @ 0x000fdf50
  >>> ERROR: Invalid checksum
Allocating PCI resources starting at 08000000 (gap: 08000000:f7e00000)
Built 1 zonelists
Kernel command line: ro root=LABEL=/
Initializing CPU#0
CPU 0 irqstacks, hard=c0457000 soft=c0456000
PID hash table entries: 1024 (order: 10, 16384 bytes)
Detected 398.862 MHz processor.
Using tsc for high-res timesource
Console: colour VGA+ 80x25
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 124460k/131072k available (2518k kernel code, 6104k reserved, 690k data 180k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 786.43 BogoMIPS (lpj=393216)
Security Framework v1.0.0 initialized
SELinux:  Initializing.
SELinux:  Starting in permissive mode
selinux_register_security:  Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0183f9ff 00000000 00000000 00000000 0000000000000000 00000000
CPU: After vendor identify, caps: 0183f9ff 00000000 00000000 00000000 00000000 0000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 512K
CPU: After all inits, caps: 0183f1ff 00000000 00000000 00000040 00000000 0000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel Pentium II (Deschutes) stepping 02
Enabling fast FPU save and restore... done.
Checking 'hlt' instruction... OK.
checking if image is initramfs... it is
softlockup thread 0 started up.
Freeing initrd memory: 1081k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfcaee, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20050309
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI: disabled
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
Boot video device is 0000:01:00.0
PCI: Using IRQ router PIIX/ICH [8086/7110] at 0000:00:07.0
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
audit: initializing netlink socket (disabled)
audit(1159644262.229:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux:  Registering netfilter hooks
Initializing Cryptographic API
ksign: Installing public key data
Loading keyring
- Added public key 42BD35A990375F72
- User ID: Red Hat, Inc. (Kernel Module GPG key)
Limiting direct PCI/PCI transfers.
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
isapnp: Scanning for PnP cards...
isapnp: Card 'CS4236B'
isapnp: 1 Plug & Play card detected total
Real Time Clock Driver v1.12
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel 440BX Chipset.
agpgart: AGP aperture is 64M @ 0xf4000000
PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
Serial: 8250/16550 driver $Revision: 1.90 $ 76 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
PCI: Found IRQ 10 for device 0000:00:0e.0
ttyS47 at I/O 0xd828 (irq = 10) is a 8250
ttyS50 at I/O 0xd840 (irq = 10) is a 8250
ttyS52 at I/O 0xd850 (irq = 10) is a 8250
ttyS54 at I/O 0xd860 (irq = 10) is a 8250
ttyS56 at I/O 0xd870 (irq = 10) is a 8250
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller at PCI slot 0000:00:07.1
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
    ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
    ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
hda: Maxtor 90640D4, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: TOSHIBA CD-ROM XM-6302B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 12594960 sectors (6448 MB) w/256KiB Cache, CHS=12495/16/63, UDMA(33)
hda: cache flushes not supported
hda: hda1 hda2
hdc: ATAPI 32X CD-ROM drive, 256kB Cache, DMA
Uniform CD-ROM driver Revision: 3.20
ide-floppy driver 0.99.newide
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.01:USB HID core driver
mice: PS/2 mouse device common for all mice
md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 256 buckets, 8Kbytes
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
Initializing IPsec netlink socket
NET: Registered protocol family 17
Freeing unused kernel memory: 180k freed
kjournald starting.  Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
SELinux:  Disabled at runtime.
SELinux:  Unregistering netfilter hooks
Floppy drive(s): fd0 is 1.44M
FDC 0 is a National Semiconductor PC87306
PCI: Found IRQ 11 for device 0000:00:11.0
PCI: Sharing IRQ 11 with 0000:00:07.2
PCI: Sharing IRQ 11 with 0000:01:00.0
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
0000:00:11.0: 3Com PCI 3c905B Cyclone 100baseTx at 0xdc00. Vers LK1.1.19
pnp: Device 00:01.00 activated.
pnp: Device 00:01.02 activated.
pnp: Device 00:01.03 activated.
pnp: Device 00:01.01 activated.
gameport: NS558 PnP Gameport is pnp00:01.01/gameport0, io 0x3a0, speed 685kHz
piix4_smbus 0000:00:07.3: Found 0000:00:07.3 device
piix4_smbus 0000:00:07.3: Host SMBus controller not enabled!
shpchp: acpi_shpchprm:get_device PCI ROOT HID fail=0x1001
USB Universal Host Controller Interface driver v2.2
PCI: Found IRQ 11 for device 0000:00:07.2
PCI: Sharing IRQ 11 with 0000:00:11.0
uhci_hcd 0000:00:07.2: UHCI Host Controller
uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:07.2: irq 11, io base 0x0000dce0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usb 1-2: new full speed USB device using uhci_hcd and address 2
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
device-mapper: 4.4.0-ioctl (2005-01-12) initialised: [email protected]
EXT3 FS on hda1, internal journal
Adding 265064k swap on /dev/hda2.  Priority:-1 extents:1
ip_tables: (C) 2000-2002 Netfilter core team
e2: Unknown symbol exit_mm
parport0: PC-style at 0x378 (0x778) [PCSPP,TRISTATE,EPP]
parport0: irq 7 detected
lp0: using parport0 (polling).
lp0: console ready
NET: Registered protocol family 10
Disabled Privacy Extensions on device c03e6820(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
[root@las /]# cat /etc/modprobe.conf
alias eth0 3c59x
alias snd-card-0 snd-cs4236
options snd-card-0 index=0
options snd-cs4236 index=0
remove snd-cs4236 { /usr/sbin/alsactl store 0 >/dev/null 2>&1 || :; }; /sbin/mdprobe -r --ignore-remove snd-cs4236
alias usb-controller uhci-hcd
Dzieki za zainteresowanie tematem :D
