Blad Przy Instalacji Cedegi Z Cvs ...
lukas_gab
Cześć! Chce zaintalowac cedege z cvs no i ... najpierw chcial zebym wywalil cedege timedemo i wywalilem ale teraz to nic nie rozumiem ... wywla blad ...
    TIP: To force all your games to run in a window, uncomment
    the "Desktop" option in the configuration file.
    Look under section [x11drv].
    Configuration file will be <Home>/.cvscedega/config
    It will be created the first time you run cvscedega
pomozecie ??
  • 3 weeks later...
  • 3 weeks later...
Nie będę zakładał nowego tematu. Niestety naprawde mam problem z instalacją cedegi.
Kompiluje się, kompiluje, ale niestety dostąję coś takiego i koniec.
In file included from ../include/winnt.h:10,
                 from ../include/windef.h:16,
                 from ../include/wine/unicode.h:10,
                 from casemap.c:4:
../include/basetsd.h:153:3: error: #error Unknown CPU architecture!
In file included from ../include/windef.h:16,
                 from casemap.c:4:
../include/winnt.h:1035:2: error: #error You need to define a CONTEXT for your CPU
                 from casemap.c:4:
../include/winnt.h:1038: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
../include/winnt.h:2090: error: expected specifier-qualifier-list before ‘PCONTEXT’
../include/winnt.h:2103: error: expected declaration specifiers or ‘...’ before ‘PCONTEXT’
In file included from ../include/winnls.h:5,
                 from ../include/wine/unicode.h:11,
                 from casemap.c:4:
../include/winbase.h:121: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘LPCONTEXT’
../include/winbase.h:1370: error: expected declaration specifiers or ‘...’ before ‘CONTEXT’
../include/winbase.h:1510: warning: type defaults to ‘int’ in declaration of ‘CONTEXT’
../include/winbase.h:1510: error: expected ‘;’, ‘,’ or ‘)’ before ‘*’ token
make[1]: *** [casemap.o] Błąd 1
make[1]: Opuszczenie katalogu `/root/.WineCVS/sources/cvscedega/winex/unicode'
make: *** [unicode/libwine_unicode.so] Błąd 2
Wkleiłem od miejsca gdzie zaczęłyu pojawiac się jakieś 'errory'.
Bardzo prosiłbym o pomoc :)
