Open Ttd
lukas_gab
Prubóje i nic .. Confugure i make wporzo lae make install wypluwa [root@localhost openttd-0.4.8]# make install
Makefile:872: *** make install is highly experimental at his state and not tested very much - use at your own risk - to use run \"make install INSTALL:=1\" - make sure Makefile.config is set correctly up - run \"make upgradeconf\". Stop.
i tyle cobie pogralem .. spotkal sie ktos z tym ? co trzeba zrobić ?
