Gość PhockouS Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 Po wpisaniu yum remove gnome* , wyskakuje pelno zaleznosci : Removing: gnome-desktop i386 2.16.0-1.fc6 installed 1.9 M gnome-keyring i386 0.6.0-1.fc6 installed 860 k gnome-media i386 2.16.1-2.fc6 installed 5.2 M gnome-menus i386 2.16.0-2.fc6 installed 521 k gnome-mime-data i386 2.4.2-3.1 installed 3.4 M gnome-mount i386 0.5-2.fc6 installed 228 k gnome-python2 i386 2.16.0-1.fc6 installed 588 k gnome-python2-bonobo i386 2.16.0-1.fc6 installed 167 k gnome-python2-canvas i386 2.16.0-1.fc6 installed 45 k gnome-python2-gconf i386 2.16.0-1.fc6 installed 71 k gnome-python2-gnomevfs i386 2.16.0-1.fc6 installed 164 k gnome-vfs2 i386 2.16.0-4.fc6 installed 4.6 M Removing for dependencies: ImageMagick i386 6.2.8.0-3.fc6 installed 11 M desktop-printing i386 0.19-16.fc6 installed 259 k eel2 i386 2.16.0-1.fc6 installed 1.1 M evince i386 0.6.0-3.fc6 installed 2.7 M firestarter i386 1.0.3-14.fc6 installed 1.3 M firstboot noarch 1.4.23-1 installed 933 k gdm i386 1:2.16.0-10.fc6 installed 10 M gimp i386 2:2.2.13-1.fc6 installed 25 M gimp-data-extras noarch 2.0.1-1.1.1 installed 7.6 M gimp-help noarch 2-0.1.0.10.1.1 installed 64 M gimp-print-plugin i386 4.2.7-22 installed 95 k gstreamer i386 0.10.9-2 installed 1.4 M gstreamer-plugins-base i386 0.10.9-4 installed 1.4 M gstreamer-plugins-good i386 0.10.4-1.fc6 installed 1.4 M gtkhtml2 i386 2.11.0-3 installed 430 k im-chooser i386 0.3.3-2.fc6 installed 152 k krb5-auth-dialog i386 0.7-1 installed 52 k libbonoboui i386 2.16.0-1.fc6 installed 1.2 M libgnome i386 2.16.0-4.fc6 installed 3.3 M libgnomeui i386 2.16.0-4.fc6 installed 3.1 M libgsf i386 1.14.1-6 installed 259 k librsvg2 i386 2.16.0-2.fc6 installed 424 k libwpd i386 0.8.6-1 installed 471 k nautilus-cd-burner i386 2.16.0-3.fc6 installed 1.7 M nautilus-extensions i386 2.16.0-5.fc6 installed 31 k openoffice.org-calc i386 1:2.0.4-5.3 installed 19 M openoffice.org-core i386 1:2.0.4-5.3 installed 220 M openoffice.org-draw i386 1:2.0.4-5.3 installed 2.6 M openoffice.org-graphicfilter i386 1:2.0.4-5.3 installed 425 k openoffice.org-impress i386 1:2.0.4-5.3 installed 4.2 M openoffice.org-langpack-pl_PL i386 1:2.0.4-5.3 installed 37 M openoffice.org-math i386 1:2.0.4-5.3 installed 3.2 M openoffice.org-writer i386 1:2.0.4-5.3 installed 6.7 M openoffice.org-xsltfilter i386 1:2.0.4-5.3 installed 212 k pirut noarch 1.2.5-1 installed 903 k planner i386 0.14-3 installed 5.8 M rhythmbox i386 0.9.5-4.fc6 installed 6.3 M sound-juicer i386 2.16.0-1.fc6 installed 2.4 M system-config-date noarch 1.8.7-1 installed 3.2 M system-config-lvm noarch 1.0.18-1.2.FC6 installed 2.6 M system-config-network noarch 1.3.95-1 installed 2.1 M totem i386 2.16.1-1.fc6 installed 4.9 M xsane-gimp i386 0.991-2.fc6 installed 617 k czy usunie tez cos co uniemozliwi poprawne dzialanie systemu ? z gory dzieki . Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
menth0l Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 yum groupremove "GNOME Desktop Environment" Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość PhockouS Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 jeszcze gdybys podawal sprawdzone informacje bylbym wdzieczny ! -.-' ten sposob nie dziala .. EDIT : Nie instalowalem Gnome'a , lecz posiadam jego biblioteki na dysku , zle sformuowalem pytanie . Da sie usunac wszystkie pozostalosci po Gnome'ie z hdd ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
menth0l Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 Może trochę na około.. ale. Zainteresuj się tym:Yum-utils # package-cleanup --leaves --all Jeśli nie używasz do niczego tych gnomowych paczek to myślę że ci pomoże... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
da_niel Napisano Październik 30, 2006 Zgłoszenie Share Napisano Październik 30, 2006 ja kiedys chcialem usunac pozostalosci po KDE i paanie, jak nie pierdyknelo... nic nie dzialalo... re-instal pomogl Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
broda Napisano Październik 31, 2006 Zgłoszenie Share Napisano Październik 31, 2006 ja kiedys chcialem usunac pozostalosci po KDE i paanie, jak nie pierdyknelo... nic nie dzialalo... re-instal pomogl wystarczylo doinstalowac zaleznosci które usunales przy remove jak cos skopiesz w systemie, to najpierw postaraj sie to naprawic, bo nie nauczysz sie niczego o Linuksie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
XAL Napisano Październik 31, 2006 Zgłoszenie Share Napisano Październik 31, 2006 Wpisz to samo co wpisałeś tylko dopisz na końcu -except=nazwa_paczki ktora chcesz zostawic, nie pamietam jak to polecenie sie poprawnie pisało, wpisz yum --help czy coś to się dowiesz. swoją drogą, to czy trzeba było GNOME instalowac? ;] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość PhockouS Napisano Październik 31, 2006 Zgłoszenie Share Napisano Październik 31, 2006 nie instowalem gnome , ale sa jego pliki w systemie ( byc moze niezbedne do poprawnej jego pracy ) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
da_niel Napisano Październik 31, 2006 Zgłoszenie Share Napisano Październik 31, 2006 nie instowalem gnome , ale sa jego pliki w systemie ( byc moze niezbedne do poprawnej jego pracy ) jezeli nie instalowales samego GNOME tzn, ze zainstalowales jakies programy ktore wymagaja bibliotek GNOME, jesli usuniesz biblioteki GNOME to przestana ci dzialac programy korzystajace z tych bibliotek. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
