marcini Napisano Listopad 2, 2006 Zgłoszenie Share Napisano Listopad 2, 2006 Witam! Usiluje zainstalowac karte wifi Broadcom BCM4318 na notebooku pod FC6. Probowalem wg przyklejonego tematu (bcm43xx-fwcutter), rozpakowal mi pliki do /lib/firmware, ale nie moge podniesc interfejsu ani w konsoli, ani graficznym narzedziem: [root@localhost ~]# ifconfig eth1 up SIOCSIFFLAGS: Operacja niedozwolona Chcialem wiec sprobowac ndiswrappera, ale yum chce mi instalowac jako zaleznosc te sama wersje kernela, ktora juz mam, i z tego powodu sie wykrzacza instalacja: [root@localhost media]# yum install ndiswrapper Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package ndiswrapper.i386 0:1.25-1.lvn6 set to be updated --> Running transaction check --> Processing Dependency: ndiswrapper-kmod >= 1.25 for package: ndiswrapper --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kmod-ndiswrapper.i686 0:1.25-1.2.6.18_1.2798.fc6 set to be updated --> Running transaction check --> Processing Dependency: kernel-i686 = 2.6.18-1.2798.fc6 for package: kmod-ndiswrapper --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i686 0:2.6.18-1.2798.fc6 set to be installed --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: ndiswrapper i386 1.25-1.lvn6 livna 29 k Installing for dependencies: kernel i686 2.6.18-1.2798.fc6 core 16 M kmod-ndiswrapper i686 1.25-1.2.6.18_1.2798.fc6 livna 92 k Transaction Summary ============================================================================= Install 3 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 16 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Check Error: package kernel-2.6.18-1.2798.fc6 is already installed file /boot/System.map-2.6.18-1.2798.fc6 from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 file /boot/config-2.6.18-1.2798.fc6 from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 file /boot/symvers-2.6.18-1.2798.fc6.gz from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 file /boot/vmlinuz-2.6.18-1.2798.fc6 from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 Co poradzicie? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Gość _PaT Napisano Listopad 2, 2006 Zgłoszenie Share Napisano Listopad 2, 2006 Usiluje zainstalowac karte wifi Broadcom BCM4318 na notebooku pod FC6. Co to za sprzęt? Probowalem wg przyklejonego tematu (bcm43xx-fwcutter), rozpakowal mi pliki do /lib/firmware, ale nie moge podniesc interfejsu ani w konsoli, ani graficznym narzedziem: [root@localhost ~]# ifconfig eth1 up SIOCSIFFLAGS: Operacja niedozwolona Używałeś w ogóle modprobe? Jakoś nie wspomniałeś... Spróbuj zrestartować kompa - sterownik BCM ma jeszcze błędy i jak nadmiernie się zabawiałeś w jego ładowanie, to mógł wyskoczyć błąd jak powyższy. Chcialem wiec sprobowac ndiswrappera, ale yum chce mi instalowac jako zaleznosc te sama wersje kernela, ktora juz mam, i z tego powodu sie wykrzacza instalacja: [root@localhost media]# yum install ndiswrapper Loading "installonlyn" plugin Setting up Install Process Setting up repositories Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package ndiswrapper.i386 0:1.25-1.lvn6 set to be updated --> Running transaction check --> Processing Dependency: ndiswrapper-kmod >= 1.25 for package: ndiswrapper --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kmod-ndiswrapper.i686 0:1.25-1.2.6.18_1.2798.fc6 set to be updated --> Running transaction check --> Processing Dependency: kernel-i686 = 2.6.18-1.2798.fc6 for package: kmod-ndiswrapper --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package kernel.i686 0:2.6.18-1.2798.fc6 set to be installed --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: ndiswrapper i386 1.25-1.lvn6 livna 29 k Installing for dependencies: kernel i686 2.6.18-1.2798.fc6 core 16 M kmod-ndiswrapper i686 1.25-1.2.6.18_1.2798.fc6 livna 92 k Transaction Summary ============================================================================= Install 3 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 16 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Check Error: package kernel-2.6.18-1.2798.fc6 is already installed file /boot/System.map-2.6.18-1.2798.fc6 from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 file /boot/config-2.6.18-1.2798.fc6 from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 file /boot/symvers-2.6.18-1.2798.fc6.gz from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 file /boot/vmlinuz-2.6.18-1.2798.fc6 from install of kernel-2.6.18-1.2798.fc6 conflicts with file from package kernel-2.6.18-1.2798.fc6 Co poradzicie? Masz dwa wyjścia. Pierwsze, które polecam, to downgrade kernela do wersji kernel-2.6.18-1.2200.fc6 (czyli do najnowszego dostępnego w stabilnych repo - nie wiem, po co Ci był ten z development). Drugie jest takie, że możesz używać testowych repozytoriów livny - znajdziesz tam odpowiedni kmod. Na dowód tego, że działa, jak się nie miesza w develach (choć ja mieszam (; ): [root@localhost ~]# yum install ndiswrapper --disablerepo=extras Loading "fastestmirror" plugin Loading "installonlyn" plugin Setting up Install Process Setting up repositories livna [1/4] flash [2/4] core [3/4] updates [4/4] Loading mirror speeds from cached hostfile Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Downloading header for ndiswrapper to pack into transaction set. ndiswrapper-1.25-1.lvn5.x 100% |=========================| 6.4 kB 00:00 ---> Package ndiswrapper.x86_64 0:1.25-1.lvn5 set to be updated --> Running transaction check --> Processing Dependency: ndiswrapper-kmod >= 1.25 for package: ndiswrapper --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Downloading header for kmod-ndiswrapper to pack into transaction set. kmod-ndiswrapper-1.25-1.2 100% |=========================| 6.3 kB 00:00 ---> Package kmod-ndiswrapper.x86_64 0:1.25-1.2.6.18_1.2200.fc5 set to be updated --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: ndiswrapper x86_64 1.25-1.lvn5 livna 29 k Installing for dependencies: kmod-ndiswrapper x86_64 1.25-1.2.6.18_1.2200.fc5 livna 105 k Transaction Summary ============================================================================= Install 2 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 134 k Is this ok [y/N]: y Downloading Packages: (1/2): kmod-ndiswrapper-1 100% |=========================| 105 kB 00:03 (2/2): ndiswrapper-1.25-1 100% |=========================| 29 kB 00:00 Running Transaction Test Finished Transaction Test Transaction Test Succeeded Running Transaction Installing: ndiswrapper ######################### [1/2] Installing: kmod-ndiswrapper ######################### [2/2] Installed: ndiswrapper.x86_64 0:1.25-1.lvn5 Dependency Installed: kmod-ndiswrapper.x86_64 0:1.25-1.2.6.18_1.2200.fc5 Complete! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
wklaczynski Napisano Listopad 2, 2006 Zgłoszenie Share Napisano Listopad 2, 2006 Ten ster BCM nie jest zbyt stabilny, wykrywa kartę, ale jest problem po skonfigurowaniu, nie zbyt pewnie podnosi szyfrowanego połączenia a jak to się udaje to jedynie za pomocą NetworkManager i próbując kilka razy wymusić połączenie. Mimo dwu letniej męki producenta nie udało im się jeszcze ustabilisować sterownika, a co wersja wada jest zawsze inna, wcześniej łatwo się łączył ale po jakimś czasie się rozłączał i nie zezwalał na kolejne połączenie, teraz z trudem daje się połączyć jeżeli połączenie jest zabezpieczone kluczem! Pozostaje ndiswrapper, znim nie ma problemu, działa super i osiąga lepszą prędkość połączenia! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcini Napisano Listopad 3, 2006 Autor Zgłoszenie Share Napisano Listopad 3, 2006 Uzywalem oczywiscie modprobe, restarty itp... ale zostawmy w takim razie bcm43xx i skupmy sie na ndiswrapperze. Szyfrowanie mam, a najchetniej to bym sie przelaczyl na WPA2 (teraz mam WPA bo jeszcze nie wiem czy pod linuxem da sie uruchomic WPA2). downgrade kernela do wersji kernel-2.6.18-1.2200.fc6 (czyli do najnowszego dostępnego w stabilnych repo - nie wiem, po co Ci był ten z development Zaden development, wersja zainstalowana z plytki 2 dni temu, zadnych updatow. Nie wiem czy zwrociles uwage, ze mam Fedore 6 a nie 5. Jak moge w takim razie pogodzic te zaleznosci? Zawsze zostaje kompilacja ndiswrappera ze zrodel, ale wolalbym z repozytoriow zainstalowac... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
exbros Napisano Listopad 3, 2006 Zgłoszenie Share Napisano Listopad 3, 2006 No, dobra... Nie wiem, czy ja czegos nie doczytalem / nie zrozumialem ale masz po prostu problem z kernelem - masz zainstalowana wersje i586 (bug w Anacondzie o ktorym od wyjscia FC6 powstalo juz 100 postow). Na dzien dobry pobierz kernel-2.6.18-1.2798.fc6.i686.rpm kernel-devel-2.6.18-1.2798.fc6.i686.rpm kernel-doc-2.6.18-1.2798.fc6.noarch.rpm kernel-headers-2.6.18-1.2798.fc6.i386.rpm (tak na wszelki wypadek powyzej masz caly komplet pakietow) Teraz zainstaluj - ale uzywajac rpm NIE yum (wydaj to polecenie w katalogu do ktorego sciagnales wymienione pakiety, oczywiscie jako root, czyli po zalogowaniu sie przez 'su -') rpm -Uvh --replacefiles --replacepkgs kernel-*.rpm Teraz restart pod nowym (starym ) jajem i zainstaluj odpowiedniego kmoda i ndiswrappera. Prawdopodobnie juz je masz, ale gdybys chcial je pociagnac to sa np tutaj kmod-ndiswrapper-1.25-1.2.6.18_1.2798.fc6.i686.rpm ndiswrapper-1.25-1.lvn6.i386.rpm i instalacja rpm -ivh kmod-ndiswrapper-*.rpm ndiswrapper-*.rpm lub jesli masz dostep do sieci na tym kompie (a chyba masz, bo juz uzywales yuma) to yum install kmod-ndiswrapper ndiswrapper A teraz to juz tylko pozostaje Ci odpalenie WiFi - ale opis tego procesu byl juz opisywany tyle razy, ze ja sobie i Wam wszystkim go oszczedze... Powodzenia BTW - Opis podmiany kernela (przydatny takze przed instalka nvidii) jest uniwersalny, sprawdzony, dzialajacy i nie uszkadza grub.conf Pozdro Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mavik Napisano Listopad 3, 2006 Zgłoszenie Share Napisano Listopad 3, 2006 jak zauważyłem do podnoszenia interfejsu użyłes komendy ifconfig wg mnie to powinno być iwconfig czy się mylę? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcini Napisano Listopad 3, 2006 Autor Zgłoszenie Share Napisano Listopad 3, 2006 Dzieki, nie wiedzialem o tym bugu. @mavik: ifconfig sluzy do podnoszenia inerfejsu, ustawiania adresu itp., iwconfig natomiast sluzy do ustawiania parametrow zwiazanych tylko z siecia bezprzewodowa (klucza, essid itp). Wiec tak: Zainstalowalem ndiswrappera, a potem sterownik karty: ndiswrapper -i /lib/sterywin/bcmwl5.inf I widze ze jest: [root@localhost ~]# ndiswrapper -l installed drivers: bcmwl5 driver installed, hardware (14E4:432A) present Do tego jeszcze /etc/modprobe.conf: #alias eth1 bcm43xx alias wlan0 ndiswrapper alias eth1 ndiswrapper options ndiswrapper if_name=eth1 Dodalem karte wlan0 w System > Administracja > Sieć, i kiedy probuje aktywowac, dostaje komunikat: Nie znaleziono urządzenia ndiswrapper wlan0, opóźnianie inicjowania Co mam dalej robic? Jak moge dodac ten interfejs wlan0? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
marcini Napisano Listopad 5, 2006 Autor Zgłoszenie Share Napisano Listopad 5, 2006 Udalo mi sie uruchomic ta sieciowke z WPA2, wiec jesli ktos ma podobny problem, to podaje jak to zrobilem: Po instalacji ndiswrappera umieścilem wpisy w /etc/modprobe.conf: #alias eth1 bcm43xx alias eth1 ndiswrapper options ndiswrapper if_name=eth1 Dalem komentarz przed bcm43xx, zeby sie nie ladowal. Teraz nalezy sie upewnic, ze jest zainstalowany pakiet wpa_supplicant. Nastepnie w /etc/wpa_supplicant/wpa_supplicant.conf podajemy ESSID sieci (mam wylaczone rozglaszanie): ctrl_interface=/var/run/wpa_supplicant ctrl_interface_group=wheel network={ ssid="nasz_identyfikator" key_mgmt=NONE } Prawdopodobnie dla kazdej uzywanej sieci trzeba podac kolejny essid. Nastepnie trzeba sie upewnic, ze uslugi NetworkManager i NetworkManagerDispatcher dzialaja i startuja razem z systemem. Teraz mozna kliknac na ikonke NetworkManagera w zasobniku, wybrac Utworz nowa siec bezprzewodowa, podac parametry i uzywac Moze ktos preferuje inny sposob konfiguracji, ale ten jest chyba maksymalnie prosty i u mnie dziala. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
