Libstdc++.so.5.0.7
esdoka
przy yum whatprivides libstdc++.so.5.0.7 wyrzuca mi coś takiego.
 Loading "installonlyn" plugin
usage: yum [options] < grouplist, localinstall, groupinfo, localupdate, resolvedep, erase, deplist, groupremove, makecache, upgrade, provides, shell, install, whatprovides, groupinstall, update, groupupdate, info, search, check-update, list, remove, clean, grouperase >
options:
  -h, --help            show this help message and exit
  -t, --tolerant        be tolerant of errors
  -C                    run entirely from cache, don't update cache
  -c  [config file]     config file location
  -R  [minutes]         maximum command wait time
  -d  [debug level]     debugging output level
  -e  [error level]     error output level
  -y                    answer yes for all questions
  --version             show Yum version and exit
  --installroot=[path]  set install root
  --enablerepo=[repo]   enable one or more repositories (wildcards allowed)
  --disablerepo=[repo]  disable one or more repositories (wildcards allowed)
  -x [package], --exclude=[package]
                        exclude package(s) by name or glob
  --obsoletes           enable obsoletes processing during updates
  --noplugins           disable Yum plugins
natomiast przy samym yum install libstdc++
Setting up Install Process
Setting up repositories
Nothing to do
szczerze mówiąc nie wiem co robić (as I said, I'm newbie). Chyba po prostu poczekam na paczkę ff 2.0
Gość
