Build-essential/blad Configure
sebek0222
po wpisaniu ./configure wyskakuje mi blad:
checking cross compile...
checking for directory with kernel source... /lib/modules/2.6.18-1.2849.fc6/source
checking for directory with kernel build... /lib/modules/2.6.18-1.2849.fc6/build
checking for kernel linux/version.h... no
The file /lib/modules/2.6.18-1.2849.fc6/source/include/linux/version.h does not exist.
Please install the package with full kernel sources for your distribution
or use --with-kernel=dir option to specify another directory with kernel
sources (default is /lib/modules/2.6.18-1.2849.fc6/source)
jak szukalem na innych forach to mozliwe ze brakuje build-essential ale to jest z tego co sie orientuje pakiet do ubuntu i debiana
