Instalacja Sterowników (zxdsl 852 + Neo)
BLuM
  • 4 weeks later...
Sam sobie odpowiadam :D ..
a więc udało mi się ten problem obejść.. ale pojawił się nowy podczas budowania rpm z spec:
rpmbuild -ba usbendpoint-1.11-dual.spec
wywaliło na końcu taki komunikat po wykonaniu 'make' w katalogu 'e2':
make -C /lib/modules/2.6.15-1.2054_FC5/build SUBDIRS=/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2 modules
make[1]: Entering directory `/usr/src/kernels/2.6.15-1.2054_FC5-x86_64'
  CC [M]  /usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/usbsndcm.o
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/usbsndcm.c: In function 'CmCommandRcv':
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/usbsndcm.c:184: warning: 'sleep_on_timeout' is deprecated (declared at include/lin ux/wait.h:369)
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/usbsndcm.c: In function 'CmCommandSend':
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/usbsndcm.c:259: warning: 'sleep_on_timeout' is deprecated (declared at include/lin ux/wait.h:369)
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/usbsndcm.c: In function 'CmPacketSend':
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/usbsndcm.c:327: warning: 'sleep_on_timeout' is deprecated (declared at include/lin ux/wait.h:369)
  CC [M]  /usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.o
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c: In function 'BlDatagramSend':
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c:250: warning: passing argument 4 of 'USBADSL_ProcessMPXFR' from incompatib le pointer type
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c:253: warning: 'sleep_on_timeout' is deprecated (declared at include/linux/ wait.h:369)
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c: In function 'USBADSL_ProcessMPXFR':
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c:325: error: 'URB_ASYNC_UNLINK' undeclared (first use in this function)
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c:325: error: (Each undeclared identifier is reported only once
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c:325: error: for each function it appears in.)
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c: In function 'USBADSL_MPReceivePacket':
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c:368: warning: 'sleep_on_timeout' is deprecated (declared at include/linux/ wait.h:369)
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c: In function 'BlDatagramReceive':
/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.c:407: warning: passing argument 4 of 'USBADSL_MPReceivePacket' from incompa tible pointer type
make[2]: *** [/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2/BlSrv.o] Error 1
make[1]: *** [_module_/usr/src/redhat/BUILD/USBENDPOINT-1.11/e2] Error 2
make[1]: Leaving directory `/usr/src/kernels/2.6.15-1.2054_FC5-x86_64'
make: *** [default] Error 2
błąd: Błędny status wyjścia z /var/tmp/rpm-tmp.87277 (%build)
Wie ktoś jak sobie poradzić z tym dalej w naszej fedorce 5??
  • 3 weeks later...
Witam
Mam FC6 i mam podobny problem :/
tzn. zgodnie z instrukcja TP próbuje skompilowac plik
#rpmbuild --rebuild USBENDPOINT-1.11-2.src.rpm
Wynik dzialania :
blad: Legacy syntax is unsupported: copyright
blad: Linia 13 Nieznana etykieta: Copyright GNU
Po przegladnieciu róznych stron dowiedzialem sie ze prawdopodobnie nalezy zmienic copyright na license.
po edycji pliku *.spec wywolalem polecenie
#rpmbuild -ba <nazwa pliku>.spec
Wynik taki sam jak powyzej u kolegi BLuM'a
Komus udalo sie to obejsc??
Nie wiem jaka to wersja. Na modemie jest napisane tylko: "ZXDSL 852" i "Date: 06/04".
Popatrz na zdjecie zamieszczone na http://przemkalicki.pl/index05.html#271106_1
Jeśli jest to ten modem z lewej strony (nazywam go slangowo zxdsl1) to instalacja jest prostsza, wymaga modyfikacji źródła modułu jądra cxacru(dostepnego w kernelu), konfiguracji i ściągnięcia firmware'u. Przykładowy opis konfiguracji na Ubuntu znajdziesz na http://riot777.wordpress.com/2006/09/22/zxdsl-852-i-ubuntu/ . Jesli masz pecha i masz wersje z prawej strony, to tak zwana wersja nowsza (zxdsl2). Ten modem został uruchomiony dzieki dostarczonym przez tepse na plycie sterownikom unicorn, ale aby skompilować je pod nowszymi linuxami potrzebne są poprawki. Poprawione źródła, skrypt instalacyjny dla obu modemów znajdziesz na http://ubuneo.ubuntu.pl/ w źródłach programu UbuNeo.
Myślę, że po pewnych modyfikacjach powinno chodzić na FC.
Powodzenia
