Fedora 6 I Jądro 2.6.19
Andrzej13
Zachcialo mi sie ( tak dla sportu ) kompilacji jadra 2.6.19 wg. instrukcji:
http://fedoranews.org/cms/node/2193
Wszystko przebieglo sprawnie bez zadnych bledów.
Lecz przy próbie wystartowania systemu z tym jadrem otrzymuje informacje:
device-mapper:table: 253:0: striped: Couldn't parse stripe destination
device-mapper: reload: octl failed :No such device or address
Unable to access resume device (LABEL=SWAP-nvidia_dba)
mount: could not find filesystem 'dev/root'
setuproot: moving /dev failed: No such file or directory
setuproot: error mounting /proc: No such file or directory
setuproot: error mounting /sys: No such file or directory
switchroot: mount failed: No such file or directory
Kernel panic - not syncing: Attempted to kill init
mój grub.conf
title Fedora Core (2.6.18-1.2851.fc6)
root (hd0,8)
kernel /boot/vmlinuz-2.6.18-1.2851.fc6 ro vga=0x318 root=LABEL=/ rhgb quiet
initrd /boot/initrd-2.6.18-1.2851.fc6.img
title Fedora Core (2.6.18-1.2850.fc6)
root (hd0,8)
kernel /boot/vmlinuz-2.6.18-1.2850.fc6 ro vga=0x318 root=LABEL=/ rhgb quiet 3
initrd /boot/initrd-2.6.18-1.2850.fc.img
title Fedora Core (2.6.18-1.2849.fc6)
root (hd0,8)
kernel /boot/vmlinuz-2.6.18-1.2849.fc6 ro vga=0x318 root=LABEL=/ rhgb quiet
initrd /boot/initrd-2.6.18-1.2849.fc6.img
title Windowsik XP
rootnoverify (hd0,0)
chainloader +1
title TEST
root (hd0,8)
title Fedora (2.6.19.1)
root (hd0,8)
kernel /boot/vmlinuz-2.6.19.1 ro vga=0x318 root=LABEL=/ rhgb quiet 3
initrd /boot/initrd-2.6.19.1.img
te inne wpisy dotycza kompilacji jadra z pakietu rpm.src.
zawartosc katalogu /boot
config-2.6.18-1.2849.fc6
config-2.6.18-1.2850.fc6
config-2.6.18-1.2851.fc6
config-2.6.19.1
config-2798An
grub
initrd-2.6.18-1.2850.fc6.img
initrd-2.6.19.1.img
symvers-2.6.18-1.2849.fc6.gz
symvers-2.6.18-1.2850.fc6.gz
symvers-2.6.18-1.2851.fc6.gz
System.map-2.6.18-1.2849.fc6
System.map-2.6.18-1.2850.fc6
System.map-2.6.18-1.2851.fc6
System.map-2.6.19.1
vmlinuz-2.6.19.1
Niestety nie wiem jak sobie poradzic z tym problemem.
  • 1 month later...
mam taki sam problem z tym jadrem 2.6.19
kernel/panic - not syncing: attempted to kill init
niestety nie wiem jak go rozwiazac. mozna uzyc plyty starowej linux i w grubie wprowadzic komende: linux rescue
potem mozna zamontowac system plikow (_linuxa_ → Linuksa) ORT. trzeba wiedziec co dalej tj. co zmienic w plikach konfiguracyjnych.
mysiek
  • 2 weeks later...
Wygląda na to, że wszyscy macie problem z initrd. Przejdźcie (na roocie) da katalogu /boot i wywalcie plik initrd odpowiadający waszemu kernelowi. A potem:
/sbin/mkinitrd <wersja>.img <wersja>
Gdzie ciąg znaków <wersja zastępujecie wersją kernela. Ten pierwszy argument to musi być nazwa pliku zgodna z tą jaka była wcześniej, ew. podać inną nazwę, a potem zmienić w grub.conf.
  • 2 months later...
Witam, mam podobny problem, tyle że tuż po instalacji. Zainstalowałem FC6 na drugim dysku (na pierwszym jest Ubuntu). Dopisałem co trzeba (chyba) do menu.lst, fragment ten wygląda teraz następująco:
title        Fedora Core
root        (hd1,0)
kernel        /vmlinuz-2.6.18-1.2798.fc6 root=/dev/hdb1 rhgb quiet
initrd        /initrd-2.6.18-1.2798.fc6.img
quiet
boot
Przy uruchamianiu pojawia się coś takiego:
Starting up ...
Uncompressing Linux ... Ok, booting the kernel.
Red Hat nash version 5.1.19 starting
Reading all physical volume. This may take a while ...
Found volume group "VolGroup00" using metadata type lvm2
2 logical volume(s) in volume group "VolGroup00" now active
Trying to use fd0 instead
WARNING: can't access (null)
exec of init ((null)) failed!!!: Bad adress
Kernel panic - not syncing: Attempted to kill init!
I nic dalej nie idzie zrobić, tylko restart.
Wobec tego problemu nie mogę dostać się na Fedorę, a pod Ubuntu komenda /sbin/mkinitrd <wersja>.img <wersja> nie działa.
Jak sobie teraz z tym poradzić? Z góry dziękuję za odpowiedź.
PS. konfiguracja komputera:
Sempron 2400, 512 MB RAM, dyski: 2x 40GB ATA/100
