SpAyKeR Napisano Grudzień 17, 2006 Zgłoszenie Share Napisano Grudzień 17, 2006 Witam przy instalacji sterowników do swojej karty graficznej w wklepaniu komendy ./configure wyskakuje mi cos takiego: [root@120 mga]# ./configure checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether to enable maintainer-specific portions of Makefiles... no checking build system type... i686-redhat-linux-gnu checking host system type... i686-redhat-linux-gnu checking for style of include used by make... GNU checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ANSI C... none needed checking dependency style of gcc... gcc3 checking for a sed that does not truncate output... /bin/sed checking for egrep... grep -E checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognise dependent libraries... pass_all checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking for g++... no checking for c++... no checking for gpp... no checking for aCC... no checking for CC... no checking for cxx... no checking for cc++... no checking for cl... no checking for FCC... no checking for KCC... no checking for RCC... no checking for xlC_r... no checking for xlC... no checking whether we are using the GNU C++ compiler... no checking whether g++ accepts -g... no checking dependency style of g++... none checking how to run the C++ preprocessor... /lib/cpp configure: error: C++ preprocessor "/lib/cpp" fails sanity check See `config.log' for more details. Co sie dzieje prosze o pomoc Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
M&M Napisano Grudzień 17, 2006 Zgłoszenie Share Napisano Grudzień 17, 2006 su - yum gc++ c++ gpp* sprobuj po tym zrobic kompilacje. a najlepiej jak bys znalazl *.rpm powodzenia. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
SpAyKeR Napisano Grudzień 18, 2006 Autor Zgłoszenie Share Napisano Grudzień 18, 2006 W niczym takim mi nie pomogłeś. pokazuje sie coś takiego: [root@157 ~]# yum install gc++ c++ gpp* Loading "installonlyn" plugin Setting up Install Process Setting up repositories core [1/8] ftp://mirror.newnanutilities.org/pub/fedo...ata/repomd.xml: [Errno 4] IOError: [Errno ftp error] timed out Trying other mirror. ftp://redhat.taygeta.com/pub/RedHat/fedor...ata/repomd.xml: [Errno 4] IOError: [Errno ftp error] timed out Trying other mirror. core 100% |=========================| 1.1 kB 00:00 gst-0.10-apps [2/8] gst-0.10-apps 100% |=========================| 951 B 00:00 updates [3/8] updates 100% |=========================| 1.2 kB 00:00 freshrpms [4/8] freshrpms 100% |=========================| 951 B 00:00 gst-0.10-deps [5/8] gst-0.10-deps 100% |=========================| 951 B 00:00 macromedia [6/8] macromedia 100% |=========================| 951 B 00:00 extras [7/8] extras 100% |=========================| 1.1 kB 00:00 gst-0.10-gst [8/8] gst-0.10-gst 100% |=========================| 951 B 00:00 Reading repository metadata in from local files primary.xml.gz 100% |=========================| 1.8 MB 00:16 extras : ################################################## 5902/5902 Added 14 new packages, deleted 16 old in 17.06 seconds Parsing package install arguments No Match for argument: gc++ No Match for argument: c++ Nothing to do Prosiłbym o dalszą pomoc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Chester Napisano Grudzień 18, 2006 Zgłoszenie Share Napisano Grudzień 18, 2006 kolega chyba dosc sporego skrotu myslowego uzyl sprobuj tak: yum list | grep gcc wynikiem tego bedzie pewien zbior pakietow, wsrod ktorych bedzie podtawowy pakiet gcc mam wersje 64 bitowa Fedory, wiec u mnie jest to gcc.x86_64 jak juz odnajdziesz to na liscie wklpujesz yum install <nazwa_tego_pakietu> jezeli to Ci nie pomoglo to powyzsze czynnosci powtorz dla pakietu gpp jesli dalej niejasne, to pisz pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
