bisz Napisano Grudzień 24, 2006 Zgłoszenie Share Napisano Grudzień 24, 2006 skompilowalem program wmclockmon, chce odpalic, co robilem juz na tej dystrybucji i srodowisku graficznym, no i mam : [marcin@marcin wmclockmon-0.8.1]$ wmclockmon Xlib: extension "SHAPE" missing on display ":0.0". Xlib: extension "SHAPE" missing on display ":0.0". Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ecik__ Napisano Grudzień 24, 2006 Zgłoszenie Share Napisano Grudzień 24, 2006 Pokaż zawartość /var/log/Xorg.0.log Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
mCOIL Napisano Styczeń 15, 2007 Zgłoszenie Share Napisano Styczeń 15, 2007 Pokaż zawartość /var/log/Xorg.0.log mam podobny problem, wywala ten sam komunikat , ale przy odpalaniu beryla/compiz'a X Window System Version 7.1.1 Release Date: 12 May 2006 X Protocol Version 11, Revision 0, Release 7.1.1 Build Operating System: Linux 2.6.9-34.ELsmp i686 Red Hat, Inc. Current Operating System: Linux FC6 2.6.18-1.2798.fc6 #1 SMP Mon Oct 16 14:37:32 EDT 2006 i686 Build Date: 04 October 2006 Build ID: xorg-x11-server 1.1.1-47.fc6 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Module Loader present Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Mon Jan 15 17:20:22 2007 (==) Using config file: "/etc/X11/xorg.conf" (==) ServerLayout "Default Layout" (**) |-->Screen "Screen0" (0) (**) | |-->Monitor "Monitor0" (**) | |-->Device "Videocard0" (**) |-->Input Device "Mouse0" (**) |-->Input Device "Keyboard0" (==) FontPath set to: unix/:7100, built-ins (==) RgbPath set to "/usr/share/X11/rgb" (==) ModulePath set to "/usr/lib/xorg/modules" (**) Extension "Composite" is enabled (II) Open ACPI successful (/var/run/acpid.socket) (II) Module ABI versions: X.Org ANSI C Emulation: 0.3 X.Org Video Driver: 1.0 X.Org XInput driver : 0.6 X.Org Server Extension : 0.3 X.Org Font Renderer : 0.5 (II) Loader running on linux (II) LoadModule: "bitmap" (II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so (II) Module bitmap: vendor="X.Org Foundation" compiled for 7.1.1, module version = 1.0.0 Module class: X.Org Font Renderer ABI class: X.Org Font Renderer, version 0.5 (II) Loading font Bitmap (II) LoadModule: "pcidata" (II) Loading /usr/lib/xorg/modules/libpcidata.so (II) Module pcidata: vendor="X.Org Foundation" compiled for 7.1.1, module version = 1.0.0 ABI class: X.Org Video Driver, version 1.0 (++) using VT number 7 (WW) Lost VT_WAITACTIVE race, retrying (II) PCI: PCI scan (all values are in hex) (II) PCI: 00:00:0: chip 10de,01e0 card 0000,0000 rev c1 class 06,00,00 hdr 80 (II) PCI: 00:00:1: chip 10de,01eb card 10de,0c17 rev c1 class 05,00,00 hdr 80 (II) PCI: 00:00:2: chip 10de,01ee card 10de,0c17 rev c1 class 05,00,00 hdr 80 (II) PCI: 00:00:3: chip 10de,01ed card 10de,0c17 rev c1 class 05,00,00 hdr 80 (II) PCI: 00:00:4: chip 10de,01ec card 10de,0c17 rev c1 class 05,00,00 hdr 80 (II) PCI: 00:00:5: chip 10de,01ef card 10de,0c17 rev c1 class 05,00,00 hdr 80 (II) PCI: 00:01:0: chip 10de,0060 card 10de,0c11 rev a4 class 06,01,00 hdr 80 (II) PCI: 00:01:1: chip 10de,0064 card 10de,0c11 rev a2 class 0c,05,00 hdr 80 (II) PCI: 00:02:0: chip 10de,0067 card 10de,0c11 rev a4 class 0c,03,10 hdr 80 (II) PCI: 00:02:1: chip 10de,0067 card 10de,0c11 rev a4 class 0c,03,10 hdr 80 (II) PCI: 00:02:2: chip 10de,0068 card 10de,0c11 rev a4 class 0c,03,20 hdr 80 (II) PCI: 00:04:0: chip 10de,0066 card 10de,0c11 rev a1 class 02,00,00 hdr 00 (II) PCI: 00:06:0: chip 10de,006a card 10de,4144 rev a1 class 04,01,00 hdr 00 (II) PCI: 00:08:0: chip 10de,006c card 0000,0000 rev a3 class 06,04,00 hdr 01 (II) PCI: 00:09:0: chip 10de,0065 card 10de,05b2 rev a2 class 01,01,8a hdr 00 (II) PCI: 00:1e:0: chip 10de,01e8 card 0000,0000 rev c1 class 06,04,00 hdr 01 (II) PCI: 01:00:0: chip 10de,00f2 card 0000,0000 rev a2 class 03,00,00 hdr 00 (II) PCI: End of PCI scan (II) Host-to-PCI bridge: (II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set) (II) Bus 0 I/O range: [0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B] (II) Bus 0 non-prefetchable memory range: [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B] (II) Bus 0 prefetchable memory range: [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B] (II) PCI-to-ISA bridge: (II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set) (II) PCI-to-PCI bridge: (II) Bus 2: bridge is at (0:8:0), (0,2,2), BCTRL: 0x0002 (VGA_EN is cleared) (II) PCI-to-PCI bridge: (II) Bus 1: bridge is at (0:30:0), (0,1,1), BCTRL: 0x000a (VGA_EN is set) (II) Bus 1 non-prefetchable memory range: [0] -1 0 0xe8000000 - 0xeaffffff (0x3000000) MX[B] (II) Bus 1 prefetchable memory range: [0] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B] (--) PCI:*(1:0:0) nVidia Corporation NV43 [GeForce 6600/GeForce 6600 GT] rev 162, Mem @ 0xe8000000/24, 0xd0000000/28, 0xe9000000/24 (II) Addressable bus resource ranges are [0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B] [1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B] (II) OS-reported resource ranges: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] (II) PCI Memory resource overlap reduced 0xe0000000 from 0xe7ffffff to 0xdfffffff (II) Active PCI resource ranges: [0] -1 0 0xeb005000 - 0xeb005fff (0x1000) MX[B] [1] -1 0 0xeb001000 - 0xeb001fff (0x1000) MX[B] [2] -1 0 0xeb004000 - 0xeb0040ff (0x100) MX[B] [3] -1 0 0xeb003000 - 0xeb003fff (0x1000) MX[B] [4] -1 0 0xeb002000 - 0xeb002fff (0x1000) MX[B] [5] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O [6] -1 0 0xe9000000 - 0xe9ffffff (0x1000000) MX[B](B) [7] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B) [8] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B) [9] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B] [10] -1 0 0x0000d400 - 0x0000d47f (0x80) IX[B] [11] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B] [12] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B] [13] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B] (II) Active PCI resource ranges after removing overlaps: [0] -1 0 0xeb005000 - 0xeb005fff (0x1000) MX[B] [1] -1 0 0xeb001000 - 0xeb001fff (0x1000) MX[B] [2] -1 0 0xeb004000 - 0xeb0040ff (0x100) MX[B] [3] -1 0 0xeb003000 - 0xeb003fff (0x1000) MX[B] [4] -1 0 0xeb002000 - 0xeb002fff (0x1000) MX[B] [5] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O [6] -1 0 0xe9000000 - 0xe9ffffff (0x1000000) MX[B](B) [7] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B) [8] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B) [9] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B] [10] -1 0 0x0000d400 - 0x0000d47f (0x80) IX[B] [11] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B] [12] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B] [13] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B] (II) OS-reported resource ranges after removing overlaps with PCI: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] (II) All system resource ranges: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [4] -1 0 0xeb005000 - 0xeb005fff (0x1000) MX[B] [5] -1 0 0xeb001000 - 0xeb001fff (0x1000) MX[B] [6] -1 0 0xeb004000 - 0xeb0040ff (0x100) MX[B] [7] -1 0 0xeb003000 - 0xeb003fff (0x1000) MX[B] [8] -1 0 0xeb002000 - 0xeb002fff (0x1000) MX[B] [9] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O [10] -1 0 0xe9000000 - 0xe9ffffff (0x1000000) MX[B](B) [11] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B) [12] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B) [13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [15] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B] [16] -1 0 0x0000d400 - 0x0000d47f (0x80) IX[B] [17] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B] [18] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B] [19] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B] (II) LoadModule: "glx" (II) Loading /usr/lib/xorg/modules/extensions/libglx.so (II) Module glx: vendor="NVIDIA Corporation" compiled for 4.0.2, module version = 1.0.9746 Module class: X.Org Server Extension ABI class: X.Org Server Extension, version 0.1 (II) Loading extension GLX (II) LoadModule: "nvidia" (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so (II) Module nvidia: vendor="NVIDIA Corporation" compiled for 4.0.2, module version = 1.0.9746 Module class: X.Org Video Driver (II) LoadModule: "mouse" (II) Loading /usr/lib/xorg/modules/input/mouse_drv.so (II) Module mouse: vendor="X.Org Foundation" compiled for 7.1.1, module version = 1.1.1 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 0.6 (II) LoadModule: "kbd" (II) Loading /usr/lib/xorg/modules/input/kbd_drv.so (II) Module kbd: vendor="X.Org Foundation" compiled for 7.1.1, module version = 1.1.0 Module class: X.Org XInput Driver ABI class: X.Org XInput driver, version 0.6 (II) NVIDIA dlloader X Driver 1.0-9746 Fri Dec 15 09:56:41 PST 2006 (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs (II) Primary Device is: PCI 01:00:0 (--) Assigning device section with no busID to primary device (--) Chipset NVIDIA GPU found (II) Loading sub module "fb" (II) LoadModule: "fb" (II) Loading /usr/lib/xorg/modules/libfb.so (II) Module fb: vendor="X.Org Foundation" compiled for 7.1.1, module version = 1.0.0 ABI class: X.Org ANSI C Emulation, version 0.3 (II) Loading sub module "wfb" (II) LoadModule: "wfb" (II) Loading /usr/lib/xorg/modules/libwfb.so (II) Module wfb: vendor="X.Org Foundation" compiled for 7.1.99.2, module version = 1.0.0 (II) Loading sub module "ramdac" (II) LoadModule: "ramdac" (II) Loading /usr/lib/xorg/modules/libramdac.so (II) Module ramdac: vendor="X.Org Foundation" compiled for 7.1.1, module version = 0.1.0 ABI class: X.Org Video Driver, version 1.0 (II) resource ranges after xf86ClaimFixedResources() call: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [4] -1 0 0xeb005000 - 0xeb005fff (0x1000) MX[B] [5] -1 0 0xeb001000 - 0xeb001fff (0x1000) MX[B] [6] -1 0 0xeb004000 - 0xeb0040ff (0x100) MX[B] [7] -1 0 0xeb003000 - 0xeb003fff (0x1000) MX[B] [8] -1 0 0xeb002000 - 0xeb002fff (0x1000) MX[B] [9] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O [10] -1 0 0xe9000000 - 0xe9ffffff (0x1000000) MX[B](B) [11] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B) [12] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B) [13] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [14] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [15] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B] [16] -1 0 0x0000d400 - 0x0000d47f (0x80) IX[B] [17] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B] [18] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B] [19] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B] (II) resource ranges after probing: [0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [4] -1 0 0xeb005000 - 0xeb005fff (0x1000) MX[B] [5] -1 0 0xeb001000 - 0xeb001fff (0x1000) MX[B] [6] -1 0 0xeb004000 - 0xeb0040ff (0x100) MX[B] [7] -1 0 0xeb003000 - 0xeb003fff (0x1000) MX[B] [8] -1 0 0xeb002000 - 0xeb002fff (0x1000) MX[B] [9] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O [10] -1 0 0xe9000000 - 0xe9ffffff (0x1000000) MX[B](B) [11] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B) [12] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B) [13] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B] [14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B] [15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B] [16] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [17] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [18] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B] [19] -1 0 0x0000d400 - 0x0000d47f (0x80) IX[B] [20] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B] [21] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B] [22] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B] [23] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B] [24] 0 0 0x000003c0 - 0x000003df (0x20) IS[B] (II) Setting vga for screen 0. (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32 (==) NVIDIA(0): RGB weight 888 (==) NVIDIA(0): Default visual is TrueColor (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0) (**) NVIDIA(0): Option "RenderAccel" "True" (**) NVIDIA(0): Option "AllowGLXWithComposite" "True" (**) NVIDIA(0): Option "AddARGBGLXVisuals" "True" (**) NVIDIA(0): Enabling RENDER acceleration (II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is (II) NVIDIA(0): enabled. (II) NVIDIA(0): NVIDIA GPU GeForce 6600 at PCI:1:0:0 (GPU-0) (--) NVIDIA(0): Memory: 131072 kBytes (--) NVIDIA(0): VideoBIOS: 05.43.02.27.00 (II) NVIDIA(0): Detected AGP rate: 8X (--) NVIDIA(0): Interlaced video modes are supported on this GPU (--) NVIDIA(0): Connected display device(s) on GeForce 6600 at PCI:1:0:0: (--) NVIDIA(0): LG 775FT Plus (CRT-0) (--) NVIDIA(0): LG 775FT Plus (CRT-0): 400.0 MHz maximum pixel clock (II) NVIDIA(0): Assigned Display Device: CRT-0 (WW) NVIDIA(0): (WW) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select" (WW) NVIDIA(0): will be used as the requested mode. (WW) NVIDIA(0): (II) NVIDIA(0): Validated modes: (II) NVIDIA(0): "nvidia-auto-select" (II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024 (--) NVIDIA(0): DPI set to (98, 104); computed from "UseEdidDpi" X config (--) NVIDIA(0): option (--) Depth 24 pixmap format is 32 bpp (II) do I need RAC? No, I don't. (II) resource ranges after preInit: [0] 0 0 0xe9000000 - 0xe9ffffff (0x1000000) MX[B] [1] 0 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B] [2] 0 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B] [3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B) [4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B] [5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B] [6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B] [7] -1 0 0xeb005000 - 0xeb005fff (0x1000) MX[B] [8] -1 0 0xeb001000 - 0xeb001fff (0x1000) MX[B] [9] -1 0 0xeb004000 - 0xeb0040ff (0x100) MX[B] [10] -1 0 0xeb003000 - 0xeb003fff (0x1000) MX[B] [11] -1 0 0xeb002000 - 0xeb002fff (0x1000) MX[B] [12] -1 0 0xe0000000 - 0xdfffffff (0x0) MX[B]O [13] -1 0 0xe9000000 - 0xe9ffffff (0x1000000) MX[B](B) [14] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX[B](B) [15] -1 0 0xe8000000 - 0xe8ffffff (0x1000000) MX[B](B) [16] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD) [17] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD) [18] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD) [19] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B] [20] -1 0 0x00000000 - 0x000000ff (0x100) IX[B] [21] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B] [22] -1 0 0x0000d400 - 0x0000d47f (0x80) IX[B] [23] -1 0 0x0000d000 - 0x0000d0ff (0x100) IX[B] [24] -1 0 0x0000e000 - 0x0000e007 (0x8) IX[B] [25] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B] [26] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU) [27] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU) (II) NVIDIA(0): Setting mode "nvidia-auto-select" (II) Loading extension NV-GLX (II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized (II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture (==) NVIDIA(0): Backing store disabled (==) NVIDIA(0): Silken mouse enabled (**) Option "dpms" (**) NVIDIA(0): DPMS enabled (II) Loading extension NV-CONTROL (==) RandR enabled (II) Initializing built-in extension MIT-SHM (II) Initializing built-in extension XInputExtension (II) Initializing built-in extension XTEST (II) Initializing built-in extension XKEYBOARD (II) Initializing built-in extension XC-APPGROUP (II) Initializing built-in extension SECURITY (II) Initializing built-in extension XINERAMA (II) Initializing built-in extension XFIXES (II) Initializing built-in extension XFree86-Bigfont (II) Initializing built-in extension RENDER (II) Initializing built-in extension RANDR (II) Initializing built-in extension COMPOSITE (II) Initializing built-in extension DAMAGE (II) Initializing built-in extension XEVIE (II) Initializing extension GLX (**) Option "Protocol" "auto" (**) Mouse0: Device: "/dev/input/mice" (**) Mouse0: Protocol: "auto" (**) Option "CorePointer" (**) Mouse0: Core Pointer (**) Option "Device" "/dev/input/mice" (**) Option "Emulate3Buttons" "no" (**) Option "ZAxisMapping" "4 5" (**) Mouse0: ZAxisMapping: buttons 4 and 5 (**) Mouse0: Buttons: 9 (**) Option "CoreKeyboard" (**) Keyboard0: Core Keyboard (**) Option "Protocol" "standard" (**) Keyboard0: Protocol: standard (**) Option "AutoRepeat" "500 30" (**) Option "XkbRules" "xorg" (**) Keyboard0: XkbRules: "xorg" (**) Option "XkbModel" "pc105" (**) Keyboard0: XkbModel: "pc105" (**) Option "XkbLayout" "pl" (**) Keyboard0: XkbLayout: "pl" (**) Option "CustomKeycodes" "off" (**) Keyboard0: CustomKeycodes disabled (II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD) (II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE) (--) Mouse0: PnP-detected protocol: "ExplorerPS/2" (II) Mouse0: ps2EnableDataReporting: succeeded Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
ecik__ Napisano Styczeń 15, 2007 Zgłoszenie Share Napisano Styczeń 15, 2007 mam podobny problem, wywala ten sam komunikat , ale przy odpalaniu beryla/compiz'a Prawdopodobnie potrzebujesz wpisu Load "extmod" w sekcji Module w pliku /etc/X11/xorg.conf Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
