Problem Z Instalacją Sterowników
alazif
Podczas instalacjii sterowników nVidi wyskakuje blad :
[root@48-mo4-1 ~]# yum install kmod-nvidia
Loading "installonlyn" plugin
Setting up Install Process
Setting up repositories
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package kmod-nvidia.i686 0:1.0.9631-1.2.6.18_1.2869.fc6 set to be installed
--> Running transaction check
--> Processing Dependency: kernel-i686 = 2.6.18-1.2869.fc6 for package: kmod-nvidia
--> Processing Dependency: nvidia-kmod-common >= 1.0.9631 for package: kmod-nvidia
--> Restarting Dependency Resolution with new changes.
---> Package xorg-x11-drv-nvidia.i386 0:1.0.9631-1.lvn6 set to be updated
---> Package kernel.i686 0:2.6.18-1.2869.fc6 set to be installed
---> Package kernel.i586 0:2.6.18-1.2798.fc6 set to be erased
Dependencies Resolved
Package				 Arch	   Version		  Repository		Size
Installing:
kmod-nvidia			 i686	   1.0.9631-1.2.6.18_1.2869.fc6  livna			 1.6 M
Removing:
kernel				  i586	   2.6.18-1.2798.fc6  installed		  43 M
Installing for dependencies:
kernel				  i686	   2.6.18-1.2869.fc6  updates			16 M
xorg-x11-drv-nvidia	 i386	   1.0.9631-1.lvn6  livna			 4.5 M
Transaction Summary
Install	  3 Package(s)
Update	   0 Package(s)
Remove	   1 Package(s)
Total download size: 22 M
Is this ok [y/N]: y
Downloading Packages:
Running Transaction Test
Finished Transaction Test
Transaction Check Error:   package kernel-2.6.18-1.2869.fc6 is already installed
 file /boot/System.map-2.6.18-1.2869.fc6 from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6
 file /boot/config-2.6.18-1.2869.fc6 from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6
 file /boot/symvers-2.6.18-1.2869.fc6.gz from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6
 file /boot/vmlinuz-2.6.18-1.2869.fc6 from install of kernel-2.6.18-1.2869.fc6 conflicts with file from package kernel-2.6.18-1.2869.fc6
[root@48-mo4-1 ~]# yum install kmod-ndiswrapper ndiswrapper
---> Downloading header for kmod-ndiswrapper to pack into transaction set.
kmod-ndiswrapper-1.25-1.2 100% |=========================| 6.3 kB	00:00
---> Package kmod-ndiswrapper.i686 0:1.25-1.2.6.18_1.2869.fc6 set to be installed
---> Downloading header for ndiswrapper to pack into transaction set.
ndiswrapper-1.25-1.lvn6.i 100% |=========================| 6.5 kB	00:00
---> Package ndiswrapper.i386 0:1.25-1.lvn6 set to be updated
--> Processing Dependency: kernel-i686 = 2.6.18-1.2869.fc6 for package: kmod-ndiswrapper
Installing:
kmod-ndiswrapper		i686	   1.25-1.2.6.18_1.2869.fc6  livna			  93 k
ndiswrapper			 i386	   1.25-1.lvn6	  livna			  29 k
Removing:
Transaction Summary
Update	   0 Package(s)
Remove	   1 Package(s)
Total download size: 16 M
Is this ok [y/N]: y
(1/2): kmod-ndiswrapper-1 100% |=========================|  93 kB	00:00
(2/2): ndiswrapper-1.25-1 100% |=========================|  29 kB	00:00
jestem baaardzo poczatkujacym urzytkownikiem, prosze o pomoc
Poszukaj na forum postow o podmianie architektury z i586 do i686, mi sie nie chce pisac nas ten temat po raz ***-y.
Powodzenia
ok dzieki
No i klops
to mi wyskoczyo
[root@48-mo4-1 packages]# rpm -ivh kernel-2.6.18-1.2869.fc6.i686.rpm
Przygotowywanie...          ########################################### [100%]
        pakiet kernel-2.6.18-1.2869.fc6 jest już zainstalowany
        plik /boot/System.map-2.6.18-1.2869.fc6 z instalacji kernel-2.6.18-1.2869.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.18-1.2869.fc6
        plik /boot/config-2.6.18-1.2869.fc6 z instalacji kernel-2.6.18-1.2869.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.18-1.2869.fc6
        plik /boot/symvers-2.6.18-1.2869.fc6.gz z instalacji kernel-2.6.18-1.2869.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.18-1.2869.fc6
        plik /boot/vmlinuz-2.6.18-1.2869.fc6 z instalacji kernel-2.6.18-1.2869.fc6 jest w konflikcie z plikiem z pakietu kernel-2.6.18-1.2869.fc6
[root@48-mo4-1 packages]# tv time
bash: tv: command not found
Dobra, zrobie to jeszcze raz, ale tak trocher na skroty ;)
Idz do tego posta
http://forum.fedora.pl/index.php?s=&sh...ost&p=79759
sciagnij wskazane pakiety, nastepnie
rpm -Uvh --replacefiles --replacepkgs kernel-*.rpm
W ten sposob zadziala. Gwarantuje ;)
Powodzenia
wielkie dzieki chwala tobie za cierpliwosc oraz rady!!!!!!!!!!!!!
P.S: czy po zainstalowaniu sterow nVidi mam dostep do jakiegos panelu sterowania jak w windzie??
