MaxRipper Napisano Styczeń 17, 2007 Zgłoszenie Share Napisano Styczeń 17, 2007 Witam Od kilku dni probuje zainstalować neo na moim modemie (Thomson Speedtouch330). Instalacji dokonuje zgodnie z opisem ze strony: http://steve-parker.org/speedtouchconf/ - ( BTW. probowalem juz innych metod i tez bez postpow) przy instalacji metodą Steva Parkera (!) wyskakuje mi takie cos: [root@localhost speedtouchconf-27-Jun-2006]# ./speedtouchconf.sh © Steve Parker, 17 Oct 2002 - 2005 (http://steve-parker.org) speedtouchconf comes with ABSOLUTELY NO WARRANTY; for details type: ./speedtouchconf.sh -gpl This is free software, and you are welcome to redistribute it under certain conditions. See the included file COPYING for more details. ************************************************ * * * speedtouchconf.sh by Steve Parker * * * * http://speedtouchconf.sourceforge.net/ * * based on speedtouch.sourceforge.net project * * * ************************************************ If you have any problems with this script, mail me (steve at steve-parker dot org) with the files /tmp/speedtouch.txt and (possibly) /var/log/messages for diagnosis. The kernel speedtch module is loaded. This is not compatible with the speedtouch usermode driver. Removing the speedtch module Linux kernel version 2.6 okay. mount: none already mounted or /proc/bus/usb busy /mnt/FreeDOS/.Trash-root/speedtouchconf-27-Jun-2006 ******************************************* * * * Please select your ISP Settings * * * ******************************************* Country/ISP VPI VCI Belgium, ? 8 35 Denmark, Orang 8 35 France, Wanadoo 8 35 France, ? 8 67 Italy, ? 8 35 Netherlands, ? 8 48 Netherlands 0 35 Poland (NeoStrada) 0 35 UK, Any 0 38 Austria (AON) 8 48 US, BellSouth 8 35 Singapore Pacificnet 0 100 Please type your VPI VCI numbers (eg, 0 38 for UK) 0 35 Please enter your ISP Login ID (eg [email protected]) [email protected] Please enter your ISP Password haslo Settings: VPI / VCI : 0 / 35 Login : [email protected] Password : haslo Are these correct? (Y/N) Y No further user interaction is required. Configuring SpeedTouch Driver... Software Configuration - SUCCESS Building SpeedTouch Driver... Software Build - SUCCESS Installing SpeedTouch Driver... Software Installation - SUCCESS Creating ppp files in /etc/ppp You can ignore any insmod hints here... mount: none already mounted or /proc/bus/usb busy *** Configuration finished. Starting the connection *** śro sty 17 22:40:47 CET 2007 The modem lights should start flashing for approx. 60 seconds... You might see some messages about USBDEVFS_BULK failed - you can ignore this. Jan 17 22:40:53 localhost modem_run[5459]: BLOCK2 Jan 17 22:40:57 localhost modem_run[5459]: BLOCK1 śro sty 17 22:41:29 CET 2007 The modem_run command failed (code 250) modem_run results: Failed to load microcode - this is not a problem if you have already loaded the microcode. The microcode can only be loaded once per system boot; We'll assume that the microcode is already loaded, and not call this an error. You may encounter problems, though. If you get a message to check your password, and your password is definitely correct, switch off the PC, disconnect the modem for a few seconds, re-connect, switch on, remove the speedtch module if it is loaded, and try again. Also check for the presence of /var/run/ppp*pid - remove this file, if found. Jan 17 22:41:29 localhost last message repeated 8 times Running : /usr/sbin/pppd call adsl Called pppd - you should see some messages about IP addresses now... Jan 17 22:41:39 localhost pppd[5511]: pppd 2.4.4 started by root, uid 0 Jan 17 22:41:39 localhost pppd[5511]: Using interface ppp0 Jan 17 22:41:39 localhost pppoa3[5515]: pppoa3 version 1.3.1 started by root (uid 0) Jan 17 22:41:39 localhost pppoa3[5515]: Control thread ready Jan 17 22:41:39 localhost pppd[5511]: Connect: ppp0 <--> /dev/pts/2 Jan 17 22:41:39 localhost pppoa3[5515]: host --> pppoa3 --> modem stream ready Jan 17 22:41:39 localhost pppoa3[5515]: modem --> pppoa3 --> host stream ready Jan 17 22:42:10 localhost pppd[5511]: LCP: timeout sending Config-Requests Jan 17 22:42:10 localhost pppd[5511]: Connection terminated. ********************************* * Don't seem to have connected. * ********************************* Please check the username and password in /etc/ppp/*-secrets. Also check the VPI/VCI in /etc/ppp/peers/adsl Then run /etc/init.d/speedtouch start Current settings: [email protected] / R6kdkfGA / 0 / 35 [root@localhost speedtouchconf-27-Jun-2006]# Help... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
MaxRipper Napisano Styczeń 20, 2007 Autor Zgłoszenie Share Napisano Styczeń 20, 2007 Hmm panowie błędow instalacyjnych sie pozbylem - internet odpala sie... ale tylko raz, bezpośrednio po instalacji. W sumie nie wiem co jest grane. Mam stary modem Thompson Speedtouch 330, srebrny ze starym logiem tepsy. Po restarcie zaczyna sie komedia wszystkie moduly ładuja sie prawidlowo do momentu ładowania modułu neostrady. Wyskakuje komunikat: "Starting ADSL connection.." i czekam, czekam (tak z 2 minuty) i na koncu dostaje status [ZAWIODŁ] Co gorsza po zalogowaniu się gdy probuje polączyc sie recznie z Terminala, poleceniem: pppd call adsl nic sie nie dzieje - nawet nie wyskakuje żaden bląd ehhh :/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Strzelcu Napisano Styczeń 28, 2007 Zgłoszenie Share Napisano Styczeń 28, 2007 Zainstaluj neo wg poprawionego poradnika Ja też mam stare logo tepsy na modemie (pewnie wersja 2.0) i zrobiłem paczke dla mojego modemu. http://forum.fedora.pl/index.php?showtopic=12431 Pozdrawiam! Napisz co Ci z tego wyszło Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
