Yaro Napisano Styczeń 24, 2007 Zgłoszenie Share Napisano Styczeń 24, 2007 Postepuje zgodnie z instrukcją: 1) $tar -xvzf RT2500-Linux-STA-x.x.x.x.tar.gz -C /usr/src/linux-2.6.5-1.358 go to "./RT2500-Linux-STA-x.x.x.x/Module" directory. 2) $cp -f ./2.6.x/Makefile 3) $make config 2) $make -C /path/to/source SUBDIRS=$PWD modules Where /path/to/source is the path to the source directory for the (configured and built) target kernel. 3) run '/sbin/insmod rt2500.ko' (as root) '/sbin/ifconfig ra0 inet YOUR_IP up' 4) uncomment the line include ./config.mk in Makefile 5) $make install robie punkt 3): [root@localhost Module]# make config -------------------- Ralink RT2500 Station Configuration -------------------- Linux kernel source directory : /lib/modules/2.6.19/build Module install directory : /lib/modules/2.6.19/kernel/drivers/net This kernel greater than 2.6.0 . /rt2500.ko PROBEPATH = /etc/modprobe.conf. w punkcie 4) wpisuje zamiatst /path/to/source /lib/modules/2.6.19/build i: [root@localhost build]# make -C /lib/modules/2.6.19/build/ SUBDIRS=&PWD modules [8] 9664 bash: PWD: command not found [root@localhost build]# make: Wejście do katalogu `/usr/src/linux-2.6.19' scripts/kconfig/conf -s arch/i386/Kconfig .config:75:warning: trying to assign nonexistent symbol MODULE_SIG .config:76:warning: trying to assign nonexistent symbol MODULE_SIG_FORCE .config:83:warning: trying to assign nonexistent symbol UTRACE .config:84:warning: trying to assign nonexistent symbol PTRACE .config:111:warning: trying to assign nonexistent symbol X86_XEN .config:180:warning: trying to assign nonexistent symbol SWIOTLB .config:211:warning: trying to assign nonexistent symbol VGA_NOPROBE .config:324:warning: trying to assign nonexistent symbol PCI_GOXEN_FE .config:558:warning: trying to assign nonexistent symbol IP_NF_MATCH_DSCP .config:586:warning: trying to assign nonexistent symbol IP_NF_TARGET_DSCP .config:865:warning: trying to assign nonexistent symbol TUX .config:870:warning: trying to assign nonexistent symbol TUX_EXTCGI .config:871:warning: trying to assign nonexistent symbol TUX_EXTENDED_LOG .config:872:warning: trying to assign nonexistent symbol TUX_DEBUG .config:997:warning: trying to assign nonexistent symbol MTD_NAND_CAFE .config:1230:warning: trying to assign nonexistent symbol SCSI_SATA .config:1231:warning: trying to assign nonexistent symbol SCSI_SATA_AHCI .config:1232:warning: trying to assign nonexistent symbol SCSI_SATA_SVW .config:1233:warning: trying to assign nonexistent symbol SCSI_ATA_PIIX .config:1234:warning: trying to assign nonexistent symbol SCSI_SATA_MV .config:1235:warning: trying to assign nonexistent symbol SCSI_SATA_NV .config:1236:warning: trying to assign nonexistent symbol SCSI_PDC_ADMA .config:1238:warning: trying to assign nonexistent symbol SCSI_SATA_QSTOR .config:1239:warning: trying to assign nonexistent symbol SCSI_SATA_PROMISE .config:1240:warning: trying to assign nonexistent symbol SCSI_SATA_SX4 .config:1241:warning: trying to assign nonexistent symbol SCSI_SATA_SIL .config:1242:warning: trying to assign nonexistent symbol SCSI_SATA_SIL24 .config:1243:warning: trying to assign nonexistent symbol SCSI_SATA_SIS .config:1244:warning: trying to assign nonexistent symbol SCSI_SATA_ULI .config:1245:warning: trying to assign nonexistent symbol SCSI_SATA_VIA .config:1246:warning: trying to assign nonexistent symbol SCSI_SATA_VITESSE .config:1247:warning: trying to assign nonexistent symbol SCSI_SATA_INTEL_COMBINED .config:1982:warning: trying to assign nonexistent symbol CRASH .config:2290:warning: trying to assign nonexistent symbol VIDEO_SAA7134_DVB_ALL_FRONTENDS .config:2300:warning: trying to assign nonexistent symbol VIDEO_CX88_DVB_ALL_FRONTENDS .config:2986:warning: trying to assign nonexistent symbol INFINIBAND_SDP .config:2987:warning: trying to assign nonexistent symbol INFINIBAND_SDP_DEBUG .config:2988:warning: trying to assign nonexistent symbol INFINIBAND_SDP_DEBUG_DATA .config:3007:warning: trying to assign nonexistent symbol EDAC_K8 .config:3110:warning: trying to assign nonexistent symbol FSCACHE .config:3121:warning: trying to assign nonexistent symbol CACHEFILES .config:3122:warning: trying to assign nonexistent symbol CACHEFILES_DEBUG .config:3168:warning: trying to assign nonexistent symbol SQUASHFS .config:3169:warning: trying to assign nonexistent symbol SQUASHFS_EMBEDDED .config:3170:warning: trying to assign nonexistent symbol SQUASHFS_FRAGMENT_CACHE_SIZE .config:3171:warning: trying to assign nonexistent symbol SQUASHFS_VMALLOC .config:3187:warning: trying to assign nonexistent symbol NFS_FSCACHE .config:3328:warning: trying to assign nonexistent symbol BOOT_DELAY .config:3353:warning: trying to assign nonexistent symbol SECURITY_SECLVL .config:3393:warning: trying to assign nonexistent symbol CRYPTO_SIGNATURE .config:3394:warning: trying to assign nonexistent symbol CRYPTO_SIGNATURE_DSA .config:3395:warning: trying to assign nonexistent symbol CRYPTO_MPILIB * * Restart config... * * * General setup * Local version - append to kernel release (LOCALVERSION) [] Automatically append version information to the version string (LOCALVERSION_AUTO) [N/y/?] n Support for paging of anonymous memory (swap) (SWAP) [Y/n/?] y System V IPC (SYSVIPC) [Y/n/?] y IPC Namespaces (IPC_NS) [N/y/?] (NEW) y bash: y: command not found [8]+ Stopped make -C /lib/modules/2.6.19/build/ SUBDIRS= O co tu biega? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
