morg Napisano Styczeń 25, 2007 Zgłoszenie Share Napisano Styczeń 25, 2007 <b>[root@morg 7]# yum install gconf-editor</b> Loading "kernel-module" plugin Loading "installonlyn" plugin Loading "fedorakmod" plugin Loading "fastestmirror" plugin Loading "downloadonly" plugin Loading "changelog" plugin Loading "skip-broken" plugin Plugin "tsflags" uses deprecated constant TYPE_INTERFACE. Please use TYPE_INTERACTIVE instead. Loading "tsflags" plugin Loading "protectbase" plugin Loading "allowdowngrade" plugin Loading "priorities" plugin rpmdb: PANIC: fatal region error detected; run recovery error: db4 error(-30977) from dbenv->open: DB_RUNRECOVERY: Fatal error, run database recovery error: cannot open Packages index using db3 - (-30977) error: cannot open Packages database in /var/lib/rpm Traceback (most recent call last): File "/usr/bin/yum", line 29, in ? yummain.main(sys.argv[1:]) File "/usr/share/yum-cli/yummain.py", line 82, in main base.getOptionsConfig(args) File "/usr/share/yum-cli/cli.py", line 205, in getOptionsConfig errorlevel=opts.errorlevel) File "/usr/lib/python2.4/site-packages/yum/__init__.py", line 125, in doConfigSetup self.conf = config.readMainConfig(startupconf) File "/usr/lib/python2.4/site-packages/yum/config.py", line 598, in readMainConfig yumvars['releasever'] = _getsysver(startupconf.installroot, startupconf.distroverpkg) File "/usr/lib/python2.4/site-packages/yum/config.py", line 661, in _getsysver idx = ts.dbMatch('provides', distroverpkg) TypeError: rpmdb open failed You have mail in /var/spool/mail/root [root@morg 7]# rpm --initdb --rebuilddb <b>rpmdb: PANIC: fatal region error detected; run recovery</b> bĹÄ d: bĹÄ d db4(-30977) z dbenv->open: DB_RUNRECOVERY: Fatal error, run database recovery bĹÄ d: nie moĹźna otworzyÄ indeksu Packages przy uĹźyciu db3 - (-30977) [root@morg 7]# Wiecie jak przebudowac baze rpm? Morg Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
morg Napisano Styczeń 25, 2007 Autor Zgłoszenie Share Napisano Styczeń 25, 2007 Chyba juz mam rm -f /var/lib/rpm/__db* db42_verify /var/lib/rpm/Packages rpm --rebuilddb Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
