Brak Połączenia Na Starcie
fafig
witam,
moj problem jest nastepujacy. po zmienieniu starego wysluzonego sagema na router adsl mam maly problem. siec nie chce w ogole startowac od razu tylko za kazdym razem musze recznie wchodzic do system-config-network i uaktywniac recznie - wtedy net dziala. probowalem tam zaznaczyc opcje aby wszyscy userzy mogli wlaczac/wylaczac interfejs, no ale nic to nie dalo.
[maciek@AthlonX2 ~]$ lspci
00:00.0 RAM memory: nVidia Corporation MCP55 Memory Controller (rev a1)
00:01.0 ISA bridge: nVidia Corporation MCP55 LPC Bridge (rev a2)
00:01.1 SMBus: nVidia Corporation MCP55 SMBus (rev a2)
00:01.2 RAM memory: nVidia Corporation MCP55 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP55 USB Controller (rev a1)
00:02.1 USB Controller: nVidia Corporation MCP55 USB Controller (rev a2)
00:04.0 IDE interface: nVidia Corporation MCP55 IDE (rev a1)
00:05.0 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2)
00:05.1 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2)
00:05.2 IDE interface: nVidia Corporation MCP55 SATA Controller (rev a2)
00:06.0 PCI bridge: nVidia Corporation MCP55 PCI bridge (rev a2)
00:08.0 Bridge: nVidia Corporation MCP55 Ethernet (rev a2)
00:0a.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0b.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0c.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0d.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0e.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:0f.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
01:08.0 Multimedia audio controller: Creative Labs SB Audigy LS
07:00.0 VGA compatible controller: nVidia Corporation G70 [GeForce 7600 GT] (rev a1)
fconfig dziala:
[maciek@AthlonX2 ~]$ ifconfig
eth0      Link encap:Ethernet  HWaddr 04:4B:80:80:80:03
         inet addr:192.168.1.100  Bcast:192.168.1.255  Mask:255.255.255.0
         inet6 addr: fe80::64b:80ff:fe80:8003/64 Scope:Link
         RX packets:3013 errors:0 dropped:0 overruns:0 frame:0
         TX packets:3252 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:1000
         RX bytes:2266028 (2.1 MiB)  TX bytes:398063 (388.7 KiB)
         Interrupt:50 Base address:0x4000
lo        Link encap:Local Loopback
         RX packets:1248 errors:0 dropped:0 overruns:0 frame:0
         TX packets:1248 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:0
         RX bytes:3134696 (2.9 MiB)  TX bytes:3134696 (2.9 MiB)
a tu dmesg | grep eth0 ale we fragmentach bo duzo tego
[maciek@AthlonX2 ~]$ dmesg | grep eth0
eth0: forcedeth.c: subsystem: 01043:8239 bound to 0000:00:08.0
Outbound IN= OUT=eth0 SRC=192.168.1.100 DST=224.0.0.251 LEN=363 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=343
Outbound IN= OUT=eth0 SRC=192.168.1.100 DST=224.0.0.251 LEN=379 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=359
Outbound IN= OUT=eth0 SRC=192.168.1.100 DST=224.0.0.22 LEN=40 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
Inbound IN=eth0 OUT= MAC=04:4b:80:80:80:03:00:18:39:2a:1b:20:08:00 SRC=192.168.1.1 DST=192.168.1.100 LEN=115 TOS=0x00 PREC=0x00 TTL=64 ID=5699 DF PROTO=UDP SPT=2048 DPT=514 LEN=95
Inbound IN=eth0 OUT= MAC=04:4b:80:80:80:03:00:18:39:2a:1b:20:08:00 SRC=192.168.1.1 DST=192.168.1.100 LEN=115 TOS=0x00 PREC=0x00 TTL=64 ID=5700 DF PROTO=UDP SPT=2048 DPT=514 LEN=95
Inbound IN=eth0 OUT= MAC=04:4b:80:80:80:03:00:18:39:2a:1b:20:08:00 SRC=192.168.1.1 DST=192.168.1.100 LEN=114 TOS=0x00 PREC=0x00 TTL=64 ID=5701 DF PROTO=UDP SPT=2048 DPT=514 LEN=94
eth0: no IPv6 routers present
Inbound IN=eth0 OUT= MAC=04:4b:80:80:80:03:00:18:39:2a:1b:20:08:00 SRC=192.168.1.1 DST=192.168.1.100 LEN=114 TOS=0x00 PREC=0x00 TTL=64 ID=5702 DF PROTO=UDP SPT=2048 DPT=514 LEN=94
Inbound IN=eth0 OUT= MAC=04:4b:80:80:80:03:00:18:39:2a:1b:20:08:00 SRC=192.168.1.1 DST=192.168.1.100 LEN=115 TOS=0x00 PREC=0x00 TTL=64 ID=5703 DF PROTO=UDP SPT=2048 DPT=514 LEN=95
Inbound IN=eth0 OUT= MAC=04:4b:80:80:80:03:00:18:39:2a:1b:20:08:00 SRC=192.168.1.1 DST=192.168.1.100 LEN=112 TOS=0x00 PREC=0x00 TTL=64 ID=5704 DF PROTO=UDP SPT=2048 DPT=514 LEN=92
Inbound IN=eth0 OUT= MAC=04:4b:80:80:80:03:00:18:39:2a:1b:20:08:00 SRC=192.168.1.1 DST=192.168.1.100 LEN=111 TOS=0x00 PREC=0x00 TTL=64 ID=5705 DF PROTO=UDP SPT=2048 DPT=514 LEN=91
Outbound IN= OUT=eth0 SRC=192.168.1.100 DST=216.27.185.42 LEN=76 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=123 DPT=123 LEN=56
dodam ze router mam skonfigurowany jako serwer DHCP. z gory dzieki za jakakolwiek pomoc :)
ok problem rozwiazany, zapomnialem ze jak mialem sagema to powylaczalem czesc uslug sieciowych typu dhcp czy network manager. teraz po wlaczeniu i starcie wszystko dziala nalezycie :PPP
