Błąd Przy Nagrywaniu Dvd
andrzejm77
Witam. Mam taki problem: przy próbie nagrania dvd z danymi w programie k3b wyrzuca mi płytę i pokazuje błąd wejścia/wyjścia i jeszcze coś takiego:
System
K3b Version: 0.12.17
KDE Version: 3.5.5-0.2.fc6 Fedora-Core
QT Version: 3.3.7
Kernel: 2.6.19-1.2895.fc6
Devices
ASUS DVD-E616P2 1.07 (/dev/hdd, ) at [CD-ROM; DVD-ROM; DVD+R; DVD+R dwuwarstwowa] [DVD-ROM; DVD+R dwuwarstwowa; CD-ROM] [brak]
LITE-ON DVDRW SOHW-1653S CS0T (/dev/hdc, ) at [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-R; DVD-RW; DVD+R; DVD+RW; DVD+R dwuwarstwowa] [DVD-ROM; DVD-R sekwencyjna; DVD-RW w trybie ograniczonego zastępowania; DVD-RW sekwencyjny; DVD+RW; DVD+R; DVD+R dwuwarstwowa; CD-ROM; CD-R; CD-RW] [sesja naraz (SAO); TAO; RAW; SAO/R96P; SAO/R96R; Surowe/R16; Surowe/R96P; Surowe/R96R; Ograniczone zastępowanie]
K3b
Size of filesystem calculated: 2199276
Used versions
growisofs: 7.0
growisofs
Executing 'builtin_dd if=/dev/fd/0 of=/dev/hdc obs=32k seek=0'
:-[ PERFORM OPC failed with SK=3h/ASC=73h/ACQ=03h]: Input/output error
growisofs command:
/usr/bin/growisofs -Z /dev/hdc=/dev/fd/0 -use-the-force-luke=notray -use-the-force-luke=tty -use-the-force-luke=tracksize:2199276 -dvd-compat -speed=2 -use-the-force-luke=bufsize:32m
mkisofs
Warning: creating filesystem that does not conform to ISO-9660.
Warning: ISO-9660 filenames longer than 31 may cause buffer overflows in the OS.
2199276
INFO: UTF-8 character encoding detected by locale settings.
Assuming UTF-8 encoded filenames on source filesystem,
use -input-charset to override.
0.07% done, estimate finish Tue Feb 6 21:47:56 2007
0.09% done, estimate finish Tue Feb 6 21:47:56 2007
0.11% done, estimate finish Tue Feb 6 22:02:35 2007
0.14% done, estimate finish Tue Feb 6 22:00:05 2007
0.16% done, estimate finish Tue Feb 6 21:58:22 2007
0.18% done, estimate finish Tue Feb 6 21:57:04 2007
0.20% done, estimate finish Tue Feb 6 21:56:04 2007
0.23% done, estimate finish Tue Feb 6 21:55:14 2007
0.25% done, estimate finish Tue Feb 6 21:54:35 2007
0.27% done, estimate finish Tue Feb 6 21:54:02 2007
0.30% done, estimate finish Tue Feb 6 21:53:34 2007
0.32% done, estimate finish Tue Feb 6 21:53:09 2007
0.34% done, estimate finish Tue Feb 6 21:52:48 2007
0.36% done, estimate finish Tue Feb 6 21:52:30 2007
0.39% done, estimate finish Tue Feb 6 21:52:14 2007
0.41% done, estimate finish Tue Feb 6 21:52:00 2007
0.43% done, estimate finish Tue Feb 6 21:51:47 2007
0.46% done, estimate finish Tue Feb 6 21:51:35 2007
0.48% done, estimate finish Tue Feb 6 21:51:25 2007
0.50% done, estimate finish Tue Feb 6 21:51:15 2007
0.52% done, estimate finish Tue Feb 6 21:51:07 2007
0.55% done, estimate finish Tue Feb 6 21:50:59 2007
0.57% done, estimate finish Tue Feb 6 21:50:51 2007
0.59% done, estimate finish Tue Feb 6 21:50:45 2007
0.61% done, estimate finish Tue Feb 6 21:50:38 2007
0.64% done, estimate finish Tue Feb 6 21:50:32 2007
0.66% done, estimate finish Tue Feb 6 21:50:27 2007
0.68% done, estimate finish Tue Feb 6 21:50:22 2007
0.70% done, estimate finish Tue Feb 6 21:50:17 2007
0.73% done, estimate finish Tue Feb 6 21:50:13 2007
mkisofs command:
/usr/bin/mkisofs -gui -graft-points -volid K3b data project -volset -appid K3B THE CD KREATOR © 1998-2005 SEBASTIAN TRUEG AND THE K3B TEAM -publisher -preparer -sysid LINUX -volset-size 1 -volset-seqno 1 -sort /tmp/kde-andrzej/k3boItbtc.tmp -rational-rock -hide-list /tmp/kde-andrzej/k3bwh5coc.tmp -joliet -hide-joliet-list /tmp/kde-andrzej/k3bZYcEZb.tmp -udf -allow-leading-dots -full-iso9660-filenames -relaxed-filenames -allow-lowercase -no-iso-translate -allow-multidot -max-iso9660-filenames -iso-level 2 -path-list /tmp/kde-andrzej/k3bS4p8sc.tmp
próbowałem przeinstalowanie k3b, cdrecord, cdrdao i innych rzeczy z forum i nic. Dodam że w innych programach jest podobnie (gnomebaker, nerolinux). Może coś z konfiguracją, partycje mam w fat32 a nagrywarka lite-on 1653s z właczonym dma. proszę o pomoc i wyrozumiałość gdyżjestem początkującym użytkownikiem (_linuxa_ → Linuksa) ORT. Z góry wielkie dzięki.
