el_jot Napisano Marzec 1, 2007 Zgłoszenie Share Napisano Marzec 1, 2007 Uzupełniłem konfigurację sendmail-a o zalecane wpisy zawarte na kilku serwerach z czarnymi listami. Odpowiednie wpisy do pliku sendmail.cf znalazły się po przetworzeniu pod nagłówkiem ###################################################################### ### Relay_ok: is the relay/sender ok? ###################################################################### SRelay_ok # anything originating locally is ok # check IP address R$* $: $&{client_addr} R$@ $@ RELAY originated locally R0 $@ RELAY originated locally R$=R $* $@ RELAY relayable IP address R$* $: [ $1 ] put brackets around it... R$=w $@ RELAY ... and see if it is local # check client name: first: did it resolve? R$* $: < $&{client_resolve} > R<TEMP> $#TEMP $@ 4.7.1 $: "450 Relaying temporarily denied. Cannot resolve PTR record for " $&{client_addr} R<FORGED> $#error $@ 5.7.1 $: "550 Relaying denied. IP name possibly forged " $&{client_name} R<FAIL> $#error $@ 5.7.1 $: "550 Relaying denied. IP name lookup failed " $&{client_name} R$* $: <@> $&{client_name} R<@> $@ RELAY # pass to name server to make hostname canonical R<@> $* $=P $:<?> $1 $2 R<@> $+ $:<?> $[ $1 $] R$* . $1 strip trailing dots R<?> $=w $@ RELAY R<?> $* $=R $@ RELAY # DNS based IP address spam list dnsbl.sorbs.net R$* $: $&{client_addr} R$-.$-.$-.$- $: <?> $(dnsbl $4.$3.$2.$1.dnsbl.sorbs.net. $: OK $) R<?>OK $: OKSOFAR R<?>$+<TMP> $: TMPOK R<?>$+ $#error $@ 5.7.1 $: "554 Rejected " $&{client_addr} " found in dnsbl.sorbs.net" # DNS based IP address spam list bl.spamcop.net R$* $: $&{client_addr} R$-.$-.$-.$- $: <?> $(dnsbl $4.$3.$2.$1.bl.spamcop.net. $: OK $) R<?>OK $: OKSOFAR R<?>$+<TMP> $: TMPOK R<?>$+ $#error $@ 5.7.1 $: "Spam_blocked see: http://spamcop.net/bl.shtml?"$&{client_addr} # DNS based IP address spam list relays.ordb.org R$* $: $&{client_addr} R$-.$-.$-.$- $: <?> $(dnsbl $4.$3.$2.$1.relays.ordb.org. $: OK $) R<?>OK $: OKSOFAR R<?>$+<TMP> $: TMPOK R<?>$+ $#error $@ 5.7.1 $: "550_Email rejected - see http://www.ordb.org/faq/\#why_rejected" Wpisy dodane do obsługi blacklists pogrubiłem. Sendmail działa jako relay dla wewnętrznego właściwego serwera poczty i uruchamia się na tym pliku konfiguracyjnym bez błędów. Niestety, nie widzę efektów działania tych wpisów np w maillog-u nie mówiąc o ilości spamu, który jest na stałym poziomie. Jak można sprawdzić czy te wpisy działają ? A może filtrowanie na podstawie blacklists nie działa dla funkcji relay lub kolejność wpisów jest niewłaściwa ? el_jot Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
