Dwa Monitory I Jedna Zagwostka...
neoski
Czesc. Posiadam dwa monitory i mam problem z ich konfiguracja. Ponizej podaje config i moje zmagania.
xorg.conf
Section "ServerLayout"
       Identifier     "Dual Monitors"
       Screen      0  "Screen0" RightOf "Screen1"
       Screen      1  "Screen1" 0 0
       Option      "Xinerama" "off"
       Option      "Clone" "off"
EndSection
Section "Module"
       Load  "dbe"
       Load  "fbdevhw"
       Load  "record"
       Load  "freetype"
       Load  "type1"
       Load  "dri"
       Load  "glx"
       Load  "extmod"
       Load  "GLcore"
EndSection
Section "InputDevice"
       Identifier  "Keyboard0"
       Driver      "kbd"
       Option      "XkbModel" "pc105"
       Option      "XkbLayout" "pl"
EndSection
Section "Monitor"
   Identifier  "Monitor0"
   VendorName  "Monitor0"
   Option      "dpms"
EndSection
Section "Monitor"
   Identifier  "Monitor1"
   VendorName  "Monitor1"
   Option      "dpms"
EndSection
Section "Device"
       Identifier  "Videocard0"
       Driver      "fglrx"
       Option      "VideoOverlay" "on"
EndSection
Section "Device"
       Identifier  "Videocard1"
       Driver      "fglrx"
       BusID       "PCI:3:0:0"
#       Screen      1
EndSection
Section "Screen"
       Identifier    "Screen0"
       Device        "Videocard0"
       Monitor       "Monitor0"
       DefaultDepth  24
       SubSection "Display"
               Viewport  0 0
               Depth     24
               Modes     "1280x1024" "1024x768"
       EndSubSection
EndSection
Section "Screen"
       Identifier    "Screen1"
       Device        "Videocard1"
       Monitor       "Monitor1"
       DefaultDepth  24
               Viewport   0 0
               Depth      24
       EndSubSection
EndSection
Section "DRI"
       Group        0
       Mode         0666
EndSection
Section "Extensions"
       Option      "Composite" "Disable"
EndSection
W tym momencie dzialam na jednym monitorze. Powodem jest to iz po zaladowaniu calego systemu zamiast pokazac mi okno logowania on wyrzuca mi na monitorze (1) jakies kolorowe "niewiadomoco". Zmusza mnie tym do uruchomienia linux rescue oraz ponownego zahashowania "Screen 1". Po rebootcie da sie juz pracowac, jednakze monitory dzialaja jako clone.
Teoretycznie znalalzem na to obejscie, ale bezsensowne. Edytuje xorg.conf, odhashowuje "Screen 1", nastepnie wklepuje "init 3", po tym "init 5" i drugi monitor dziala. Nie na dlugo, po rebootcie znowu wywala kolorki na monitorze :(.
Ponizej troche info:
fglrxinfo
display: :0.0  screen: 0
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON X800 XT Platinum Edition
OpenGL version string: 2.0.6334 (8.34.8)
glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
   GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating,
   GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method,
   GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe,
   GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer
client glx vendor string: ATI
client glx version string: 1.3
client glx extensions:
   GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context,
   GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample,
   GLX_ATI_pixel_format_float, GLX_ATI_render_texture
GLX version: 1.2
GLX extensions:
   GLX_ARB_multisample
OpenGL extensions:
   GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array,
   GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program,
   GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
   GL_ARB_multisample, GL_ARB_occlusion_query, GL_ARB_point_parameters,
   GL_ARB_point_sprite, GL_ARB_shader_objects, GL_ARB_shading_language_100,
   GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp,
   GL_ARB_texture_compression, GL_ARB_texture_cube_map,
   GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
   GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
   GL_ARB_texture_float, GL_ARB_texture_mirrored_repeat,
   GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_vertex_blend,
   GL_ARB_vertex_buffer_object, GL_ARB_pixel_buffer_object,
   GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
   GL_ARB_draw_buffers, GL_ATI_draw_buffers, GL_ATI_element_array,
   GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_map_object_buffer,
   GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc,
   GL_ATI_texture_env_combine3, GL_ATI_texture_float,
   GL_ATI_texture_mirror_once, GL_ATI_vertex_array_object,
   GL_ATI_vertex_attrib_array_object, GL_ATI_vertex_streams,
   GL_ATIX_texture_env_combine3, GL_ATIX_texture_env_route,
   GL_ATIX_vertex_shader_output_point_size, GL_EXT_abgr, GL_EXT_bgra,
   GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax,
   GL_EXT_blend_subtract, GL_EXT_clip_volume_hint,
   GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object,
   GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters,
   GL_EXT_rescale_normal, GL_EXT_secondary_color,
   GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
   GL_EXT_texgen_reflection, GL_EXT_texture3D,
   GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
   GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
   GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
   GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,
   GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array,
   GL_EXT_vertex_shader, GL_HP_occlusion_test, GL_NV_blend_square,
   GL_NV_occlusion_query, GL_NV_texgen_reflection, GL_SGI_color_matrix,
   GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
   GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
  visual  x  bf lv rg d st colorbuffer ax dp st accumbuffer  ms  cav
id dep cl sp sz l  ci b ro  r  g  b  a bf th cl  r  g  b  a ns b eat
0x23 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x24 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x25 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x26 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x27 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x28 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x29 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x2a 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x2b 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x2c 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x2d 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x2e 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x2f 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x30 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x31 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x32 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x33 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x34 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x35 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x36 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x37 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x38 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x39 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x3a 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x3b 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x3c 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x3d 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x3e 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x3f 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x40 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x41 24 tc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x42 24 tc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x43 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x44 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x45 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x46 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x47 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x48 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x49 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x4a 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x4b 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x4c 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x4d 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x4e 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x4f 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x50 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x51 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x52 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x53 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x54 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x55 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x56 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x57 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x58 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x59 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x5a 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x5b 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x5c 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8 16 16 16 16  0 0 None
0x5d 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x5e 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0 16 16 16 16  0 0 None
0x5f 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x60 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  8  0  0  0  0  0 0 None
0x61 24 dc  0 32  0 r  y  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
0x62 24 dc  0 32  0 r  .  .  8  8  8  8  0 24  0  0  0  0  0  0 0 None
