Ati... Radeon 9600pro Fglrx
Muniek1
zaktualizowac bedziesz mogl dopiero jak pojawi sie paczka z modulem fglrx dla nowego jadra - taki jest minus zamknietych sterownikow. Jak nie pokazesz swojego loga to ja juz nic nie wykombinuje.
[edit]
sproboj jeszcze dac:
Option      "no_dri" "no"
do sekcji device
Log:
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: Linux 2.6.9-34.ELsmp i686 Red Hat, Inc.
Current Operating System: Linux TUX 2.6.18-1.2798.fc6 #1 SMP Mon Oct 16 14:54:20 EDT 2006 i686
Build Date: 04 October 2006
Build ID: xorg-x11-server 1.1.1-47.fc6
Before reporting problems, check http://wiki.x.org
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Mar 24 18:58:04 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Videocard0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) FontPath set to:
unix/:7100
(==) RgbPath set to "/usr/share/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(**) Extension "Composite" is disabled
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.0
X.Org XInput driver : 0.6
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/lib/xorg/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 1.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,3189 card 1106,0000 rev 80 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b198 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:05:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: 00:08:0: chip 1102,0002 card 1102,100a rev 0a class 04,01,00 hdr 80
(II) PCI: 00:08:1: chip 1102,7002 card 1102,0020 rev 0a class 09,80,00 hdr 80
(II) PCI: 00:10:0: chip 1106,3038 card 1462,7120 rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:1: chip 1106,3038 card 1462,7120 rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:2: chip 1106,3038 card 1462,7120 rev 80 class 0c,03,00 hdr 80
(II) PCI: 00:10:3: chip 1106,3104 card 1462,7120 rev 82 class 0c,03,20 hdr 00
(II) PCI: 00:11:0: chip 1106,3177 card 1106,0000 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:11:1: chip 1106,0571 card 1462,7120 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:11:5: chip 1106,3059 card 1462,7120 rev 50 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 1002,4152 card 18bc,041b rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,4172 card 18bc,041a rev 00 class 03,80,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[b]
(II) Bus 0 non-prefetchable memory range:
[0] -1	0	0x00000000 - 0xffffffff (0x0) MX[b]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1	0	0x0000c000 - 0x0000c0ff (0x100) IX[b]
[1] -1	0	0x0000c400 - 0x0000c4ff (0x100) IX[b]
[2] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b]
[3] -1	0	0x0000cc00 - 0x0000ccff (0x100) IX[b]
(II) Bus 1 non-prefetchable memory range:
[0] -1	0	0xdfe00000 - 0xdfefffff (0x100000) MX[b]
(II) Bus 1 prefetchable memory range:
[0] -1	0	0x9fd00000 - 0xdfcfffff (0x40000000) MX[b]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc RV350 AR [Radeon 9600] rev 0, Mem @ 0xc0000000/28, 0xdfef0000/16, I/O @ 0xc800/8, BIOS @ 0xdfec0000/17
(--) PCI: (1:0:1) ATI Technologies Inc RV350 AR [Radeon 9600] (Secondary) rev 0, Mem @ 0xb0000000/28, 0xdfee0000/16
(II) Addressable bus resource ranges are
[1] -1	0	0x00000000 - 0x0000ffff (0x10000) IX[b]
(II) OS-reported resource ranges:
[0] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[b]E(
[1] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[b]
[2] -1	0	0x000c0000 - 0x000effff (0x30000) MX[b]
[3] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[b]
[4] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
[5] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe7ffffff to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1	0	0xdffffe00 - 0xdffffeff (0x100) MX[b]
[1] -1	0	0xdfffff00 - 0xdfffffff (0x100) MX[b]
[2] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[b]O
[3] -1	0	0xdfee0000 - 0xdfeeffff (0x10000) MX[b](
[4] -1	0	0xb0000000 - 0xbfffffff (0x10000000) MX[b](
[5] -1	0	0xdfec0000 - 0xdfedffff (0x20000) MX[b](
[6] -1	0	0xdfef0000 - 0xdfefffff (0x10000) MX[b](
[7] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b](
[8] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[b]
[9] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
[10] -1	0	0x0000e000 - 0x0000e01f (0x20) IX[b]
[11] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[b]
[12] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
[13] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
[14] -1	0	0x0000e400 - 0x0000e41f (0x20) IX[b]
[15] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[b]
[16] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b](
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1	0	0xdffffe00 - 0xdffffeff (0x100) MX[b]
[5] -1	0	0xdfffff00 - 0xdfffffff (0x100) MX[b]
[6] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[b]O
[7] -1	0	0xdfee0000 - 0xdfeeffff (0x10000) MX[b](
[8] -1	0	0xb0000000 - 0xbfffffff (0x10000000) MX[b](
[9] -1	0	0xdfec0000 - 0xdfedffff (0x20000) MX[b](
[10] -1	0	0xdfef0000 - 0xdfefffff (0x10000) MX[b](
[11] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b](
[12] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
[13] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
[14] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[b]
[15] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
[16] -1	0	0x0000e000 - 0x0000e01f (0x20) IX[b]
[17] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[b]
[18] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
[19] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
[20] -1	0	0x0000e400 - 0x0000e41f (0x20) IX[b]
[21] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[b]
[22] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b](
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "drm"
(II) Loading /usr/lib/xorg/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) LoadModule: "type1"
(II) Loading /usr/lib/xorg/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.0.2
(II) Loading font Type1
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.1.1, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "fbdevhw"
(II) Loading /usr/lib/xorg/modules/linux/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.0.2
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading sub module "drm"
(II) Reloading /usr/lib/xorg/modules/linux/libdrm.so
(II) Loading extension XFree86-DRI
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "fglrx"
(II) Loading /usr/lib/xorg/modules/drivers/fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 7.1.0, module version = 8.34.8
Module class: X.Org Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.34.8
(II) ATI Proprietary Linux Driver Release Identifier: LGDr8.34g1
(II) ATI Proprietary Linux Driver Build Date: Feb 20 2007 11:49:19
(II) ATI Proprietary Linux Driver Build Information: autobuild-rel-r6-8.34.1.1.2.3-driver-lnx-x86-x86_64-327152
(--) Assigning device section with no busID to primary device
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(--) Chipset Supported AMD Graphics Processor (0x4152) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x9445800
(II) resource ranges after probing:
[12] 0	0	0x000a0000 - 0x000affff (0x10000) MS[b]
[13] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[b]
[14] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[b]
[15] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
[16] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
[17] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[b]
[18] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
[19] -1	0	0x0000e000 - 0x0000e01f (0x20) IX[b]
[20] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[b]
[21] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
[22] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
[23] -1	0	0x0000e400 - 0x0000e41f (0x20) IX[b]
[24] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[b]
[25] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b](
[26] 0	0	0x000003b0 - 0x000003bb (0xc) IS[b]
[27] 0	0	0x000003c0 - 0x000003df (0x20) IS[b]
(II) Setting vga for screen 0.
(II) fglrx(0): === [atiddxPreInit] === begin, [x]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "DPMS"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(--) fglrx(0): Chipset: "ATI RADEON 9600 Series" (Chipset = 0x4152)
(--) fglrx(0): (PciSubVendor = 0x18bc, PciSubDevice = 0x041b)
(--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xc0000000
(--) fglrx(0): MMIO registers at 0xdfef0000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 2.0
(II) fglrx(0): VESA VBE Total Mem: 16384 kB
(II) fglrx(0): VESA VBE OEM: ATI RADEON 9600 PRO
(II) fglrx(0): VESA VBE OEM Software Rev: 1.0
(II) fglrx(0): VESA VBE OEM Vendor: ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: V350
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
[drm] failed to load kernel module "fglrx"
(WW) fglrx(0): Failed to open DRM connection
(--) fglrx(0): VideoRAM: 131072 kByte, Type: DDR SGRAM / SDRAM
(II) fglrx(0): AGP card detected
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/lib/xorg/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) fglrx(0): Connected Display1: CRT on primary DAC [crt1]
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: GSM  Model: 3b55  Serial#: 26430
(II) fglrx(0): Year: 2003  Week: 7
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Analog Display Input,  Input Voltage Level: 0.714/0.286 V
(II) fglrx(0): Sync:  Separate
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 30  vert.: 23
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.631 redY: 0.347   greenX: 0.309 greenY: 0.583
(II) fglrx(0): blueX: 0.149 blueY: 0.113   whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@67Hz
(II) fglrx(0): 640x480@72Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@56Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@72Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 832x624@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 640  vsize 480  refresh: 75  vid: 20273
(II) fglrx(0): #1: hsize: 800  vsize 600  refresh: 75  vid: 20293
(II) fglrx(0): #2: hsize: 1024  vsize 768  refresh: 75  vid: 20321
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 65.0 MHz   Image Size:  304 x 228 mm
(II) fglrx(0): h_active: 1024  h_sync: 1048  h_sync_end 1184 h_blank_end 1344 h_border: 0
(II) fglrx(0): v_active: 768  v_sync: 771  v_sync_end 777 v_blanking: 806 v_border: 0
(II) fglrx(0): Ranges: V min: 56  V max: 75 Hz, H min: 31  H max: 63 kHz, PixClock max 80 MHz
(II) fglrx(0): Monitor name: FLATRON L1510
(II) fglrx(0): Monitor name: S
(II) fglrx(0): EDID (in hex):
(II) fglrx(0): 	00ffffffffffff001e6d553b3e670000
(II) fglrx(0): 	070d0103281e1778eab145a1584f9526
(II) fglrx(0): 	1d5054bfee00314f454f614f01010101
(II) fglrx(0): 	01010101010164190040410026301888
(II) fglrx(0): 	360030e410000018000000fd00384b1f
(II) fglrx(0): 	3f08000a202020202020000000fc0046
(II) fglrx(0): 	4c4154524f4e204c31353130000000fc
(II) fglrx(0): 	00530a20202020202020202020200026
(II) fglrx(0): End of Display1 EDID data --------------------
(II) fglrx(0): Primary Controller - CRT on primary DAC
(II) fglrx(0): Internal Desktop Setting: 0x00000008
(II) fglrx(0): POWERplay version 3.  1 power state available:
(II) fglrx(0):   1. 398/196MHz @ 50Hz [enable load balancing]
(==) fglrx(0): Qbs disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0):  PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 23 modes found for primary display.
(--) fglrx(0): Virtual size is 1024x768 (pitch 0)
(**) fglrx(0): *Mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1024x768"   78.75  1024 1040 1136 1312  768 769 772 800
(**) fglrx(0):  Default mode "1024x768": 78.4 MHz (scaled from 0.0 MHz), 57.7 kHz, 72.0 Hz
(II) fglrx(0): Modeline "1024x768"   78.43  1024 1080 1192 1360  768 769 772 801 +hsync
(**) fglrx(0):  Default mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1024x768"   75.00  1024 1048 1184 1328  768 771 777 806 +hsync +vsync
(**) fglrx(0):  Default mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x768"   65.00  1024 1048 1184 1344  768 771 777 806 +hsync +vsync
(**) fglrx(0): *Mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
(II) fglrx(0): Modeline "800x600"   49.50  800 816 896 1056  600 601 604 625
(**) fglrx(0):  Default mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.0 Hz
(II) fglrx(0): Modeline "800x600"   50.00  800 856 976 1040  600 637 643 666
(**) fglrx(0):  Default mode "800x600": 45.5 MHz (scaled from 0.0 MHz), 43.8 kHz, 70.0 Hz
(II) fglrx(0): Modeline "800x600"   45.50  800 840 920 1040  600 601 604 625 +hsync
(**) fglrx(0):  Default mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "800x600"   40.00  800 840 968 1056  600 601 605 628
(**) fglrx(0):  Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz
(II) fglrx(0): Modeline "800x600"   36.00  800 824 896 1024  600 601 603 625
(**) fglrx(0): *Mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x480"   31.50  640 656 720 840  480 481 484 500 +hsync +vsync
(**) fglrx(0):  Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.0 Hz
(II) fglrx(0): Modeline "640x480"   31.50  640 664 704 832  480 489 492 520 +hsync +vsync
(**) fglrx(0):  Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x480"   25.18  640 656 752 800  480 490 492 525 +hsync +vsync
(**) fglrx(0):  Default mode "960x720": 55.9 MHz (scaled from 0.0 MHz), 44.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "960x720"   55.85  960 1008 1104 1248  720 721 724 746 +hsync
(**) fglrx(0):  Default mode "864x648": 45.1 MHz (scaled from 0.0 MHz), 40.2 kHz, 60.0 Hz
(II) fglrx(0): Modeline "864x648"   45.08  864 904 992 1120  648 649 652 671 +hsync
(**) fglrx(0):  Default mode "720x576": 32.7 MHz (scaled from 0.0 MHz), 35.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "720x576"   32.66  720 744 816 912  576 577 580 597 +hsync
(**) fglrx(0):  Default mode "640x400": 28.1 MHz (scaled from 0.0 MHz), 33.7 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x400"   28.07  640 696 736 832  400 413 415 449
(**) fglrx(0):  Default mode "640x400": 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x400"   24.92  640 664 760 792  400 460 462 525
(**) fglrx(0):  Default mode "400x300": 24.8 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "400x300"   24.75  400 408 448 528  300 601 602 625 doublescan
(**) fglrx(0):  Default mode "400x300": 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "400x300"   22.33  400 416 480 496  300 601 605 742 doublescan
(**) fglrx(0):  Default mode "320x240": 15.8 MHz (scaled from 0.0 MHz), 37.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x240"   15.75  320 328 360 416  240 481 482 501 doublescan
(**) fglrx(0):  Default mode "320x240": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x240"   12.59  320 328 376 400  240 491 493 525 doublescan
(**) fglrx(0):  Default mode "320x200": 13.1 MHz (scaled from 0.0 MHz), 31.5 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x200"   13.10  320 352 368 416  200 406 407 417 doublescan
(**) fglrx(0):  Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x200"   12.59  320 336 384 400  200 457 459 524 doublescan
(**) fglrx(0): Display dimensions: (300, 230) mm
(**) fglrx(0): DPI set to (86, 84)
(--) fglrx(0): Virtual size is 1024x768 (pitch 1024)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/xorg/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
(==) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/lib/xorg/modules/libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.2.0
(==) fglrx(0): HPV inactive
(==) fglrx(0): FSAA enabled: NO
(==) fglrx(0): FSAA Gamma enabled
(==) fglrx(0): FSAA Multisample Position is fix
(==) fglrx(0): NoDRI = NO
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/lib/xorg/modules/linux/libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(II) fglrx(0): Depth moves disabled by default
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x4000000f
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(WW) fglrx(0): No DRM connection for driver fglrx.
(II) fglrx(0): [drm] DRM buffer queue setup: nbufs = 100 bufsize = 65536
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(==) fglrx(0): EnablePrivateBackZ = NO
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC?  No, I don't.
(II) resource ranges after preInit:
[0] 0	0	0xdfef0000 - 0xdfefffff (0x10000) MX[b]
[1] 0	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b]
[2] -1	0	0x00100000 - 0x3fffffff (0x3ff00000) MX[b]E(
[3] -1	0	0x000f0000 - 0x000fffff (0x10000) MX[b]
[4] -1	0	0x000c0000 - 0x000effff (0x30000) MX[b]
[5] -1	0	0x00000000 - 0x0009ffff (0xa0000) MX[b]
[6] -1	0	0xdffffe00 - 0xdffffeff (0x100) MX[b]
[7] -1	0	0xdfffff00 - 0xdfffffff (0x100) MX[b]
[8] -1	0	0xe0000000 - 0xdfffffff (0x0) MX[b]O
[9] -1	0	0xdfee0000 - 0xdfeeffff (0x10000) MX[b](
[10] -1	0	0xb0000000 - 0xbfffffff (0x10000000) MX[b](
[11] -1	0	0xdfec0000 - 0xdfedffff (0x20000) MX[b](
[12] -1	0	0xdfef0000 - 0xdfefffff (0x10000) MX[b](
[13] -1	0	0xc0000000 - 0xcfffffff (0x10000000) MX[b](
[14] 0	0	0x000a0000 - 0x000affff (0x10000) MS[b](OprU)
[15] 0	0	0x000b0000 - 0x000b7fff (0x8000) MS[b](OprU)
[16] 0	0	0x000b8000 - 0x000bffff (0x8000) MS[b](OprU)
[17] 0	0	0x0000c800 - 0x0000c8ff (0x100) IX[b]
[18] -1	0	0x0000ffff - 0x0000ffff (0x1) IX[b]
[19] -1	0	0x00000000 - 0x000000ff (0x100) IX[b]
[20] -1	0	0x0000d400 - 0x0000d4ff (0x100) IX[b]
[21] -1	0	0x0000fc00 - 0x0000fc0f (0x10) IX[b]
[22] -1	0	0x0000e000 - 0x0000e01f (0x20) IX[b]
[23] -1	0	0x0000dc00 - 0x0000dc1f (0x20) IX[b]
[24] -1	0	0x0000d800 - 0x0000d81f (0x20) IX[b]
[25] -1	0	0x0000ec00 - 0x0000ec07 (0x8) IX[b]
[26] -1	0	0x0000e400 - 0x0000e41f (0x20) IX[b]
[27] -1	0	0x0000e800 - 0x0000e8ff (0x100) IX[b]
[28] -1	0	0x0000c800 - 0x0000c8ff (0x100) IX[b](
[29] 0	0	0x000003b0 - 0x000003bb (0xc) IS[b](OprU)
[30] 0	0	0x000003c0 - 0x000003df (0x20) IS[b](OprU)
(II) fglrx(0): driver needs X.org 7.1.x.y with x.y >= 0.0
(II) fglrx(0): detected X.org 7.1.1.0
(EE) fglrx(0): GART is not initialized, disabling DRI
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed!                  *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO)             *
(WW) fglrx(0): * no 3D acceleration available                *
(WW) fglrx(0): ********************************************* *
(II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x08000000
(==) fglrx(0): Write-combining range (0xc0000000,0x8000000)
(II) fglrx(0): FBMM initialized for area (0,0)-(1024,8191)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1024,768) (front color buffer - assumption)
(II) fglrx(0): Largest offscreen area available: 1024 x 7423
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(**) fglrx(0): DPMS enabled
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid Horizontal and Vertical Lines
Offscreen Pixmaps
Setting up tile and stipple cache:
	32 128x128 slots
	32 256x256 slots
	16 512x512 slots
(II) fglrx(0): Acceleration enabled
(WW) fglrx(0): Option "AGPMode" is not used
(WW) fglrx(0): Option "EnablePageFlip" is not used
(WW) fglrx(0): Option "XAAOfscreenPixmaps" is not used
(WW) fglrx(0): Option "FastWrite" is not used
(WW) fglrx(0): Option "ColorTiling" is not used
(WW) fglrx(0): Option "AllowGLXwithcomposite" is not used
(WW) fglrx(0): Option "RenderAccel" is not used
(WW) fglrx(0): Option "AddARGBGLXVisuals" is not used
(II) fglrx(0): Direct rendering disabled
(==) fglrx(0): Using hardware cursor
fbarea0->box.x1 0x00000000, fbarea0->box.y1 0x00000304
fbarea0->box.x2 0x00000400, fbarea0->box.y2 0x00000306
icon[0].start=0x304000
fbarea1->box.x1 0x00000000, fbarea1->box.y1 0x00000306
fbarea1->box.x2 0x00000400, fbarea1->box.y2 0x00000308
icon[1].start=0x306000
(**) fglrx(0): Video overlay enabled on CRTC1
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(EE) AIGLX: Screen 0 is not DRI capable
(II) Loading local sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/lib/xorg/modules/extensions/libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) GLX: Initialized MESA-PROXY GL provider for screen 0
(**) Option "Protocol" "IMPS/2"
(**) Mouse0: Device: "/dev/input/mice"
(**) Mouse0: Protocol: "IMPS/2"
(**) Option "CorePointer"
(**) Mouse0: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Emulate3Buttons" "yes"
(**) Mouse0: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Mouse0: ZAxisMapping: buttons 4 and 5
(**) Mouse0: Buttons: 9
(**) Option "CoreKeyboard"
(**) Keyboard0: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard0: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard0: XkbRules: "xorg"
(**) Option "XkbModel" "pc105"
(**) Keyboard0: XkbModel: "pc105"
(**) Option "XkbLayout" "pl"
(**) Keyboard0: XkbLayout: "pl"
(**) Option "CustomKeycodes" "off"
(**) Keyboard0: CustomKeycodes disabled
(II) XINPUT: Adding extended input device "Keyboard0" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "Mouse0" (type: MOUSE)
(II) Mouse0: ps2EnableDataReporting: succeeded
[b](--) fglrx(0): board vendor info: third party graphics adapter - NOT original ATI
[/b]drmOpenDevice: node name is /dev/dri/card0
cienko to wyglada :/ masz tego radeona na laptopie prawda?
zobacz co Ci wywali
modprobe fglrx
przed restartem X, zobacz jeszcze lsmod czy masz jakikolwiek modol odpowiedzialny za obsluge AGP.
ale raczej nie odpalisz na swojej karcie tych sterownikow :/ pozostaja moim zdaniem lepsze otwarte drivery.
Ale ja mam komputer stacjonarny nie laptopa :)
[root@TUX ~]# modprobe fglrx
FATAL: Module fglrx not found.
[root@TUX ~]#
hehe... Jakieś pomysły? Bo to nie za dobrze wygląda :/
no i wszystko jasne nie masz modulu do swojego jadra!
bede mial chwile to napisze wiecej
  • 2 months later...
Let the combat begin...
System: Fedora 7
Kernel: 2.6.21-1.3194.i686.fc7
ati-driver-installer-8.37.6-x86.x86_64.run
Efekt:
./make_install.sh
- recreating module dependency list
- trying a sample load of the kernel modules
FATAL: Error inserting fglrx (/lib/modules/2.6.21-1.3194.fc7/kernel/drivers/char/drm/fglrx.ko): Operation not permitted
Nie uzylem sterów z livny, bo (_wogóle_ → w ogóle) ORT nie dzialaja - wywala sterownik.
Wylaczylem selinuxa i zrobilem restart
Moze mi ktos pomóc? Gdzie i co trzeba wylaczyc?
Pozdrawiam.
P.S
Na FC6 w identyczny sposób robilem i bylo miodzio (arch i686 musial byc).
