Instalacja Fedora Core 5 Na Konsoli Ps3
kolesp
Mam problem.
Zacznę od opisu co by było wiadomo o co chodzi.
* Download the Fedora Core 5 PPC DVD using one of the methods previously described. Burn the ISO image on a DVD at a slow speed. Most DVD burning applications should allow you to burn ISO files properly.
* Download the Sony PS3 Cell Addon CD ISO
* Open the ISO File using WinRAR or any other ISO-related app.
* Navigate to the kboot folder and extract the otheros.bld file.
* Download the Sony PS3 Other OS Installer. It will contain a file otheros.self.
* Plug in a USB Drive into your PC.
* In the root of the USB drive, make a folder PS3. Inside the PS3 folder, make a otheros folder.
* Copy the otheros.bld and otheros.self files into the otheros folder on the USB drive. (X:\PS3\otheros\*)
* Burn the Sony PS3 Cell Addon ISO onto a CD at a slow speed.
* Start the PS3 and go to Settings -> System Settings and format your Hard Disk.
* Once the Hard Disk is formatted, just click on Allot 10GB to Other OS. (Bear in mind that you can allot more space if you have a bigger hard disk.
* Now plug in the USB drive into the PS3 and go to Settings -> System Settings -> Install Other OS
* It will ask you to select the Other OS.
* Once you press the appropriate button, it will give you a warning. Accept it.
* You will see a black screen for a few moments. This is perfectly fine.
* Once done, you will be brought back to the PS3's Game OS.
* Go to Settings -> System Settings -> Default OS. Select Other OS from the list.
* Restart your PS3. You will be brought to the kboot prompt.
* At this point, insert the Fedora Core 5 DVD into the PS3 and using the USB keyboard, type in
install-fc sda
* Once it starts, you should see a message:
Please insert Fedore Core install DVD.
Is it OK? (y/n):
* Press y to begin.
* The next screen will ask you if you want to do a Minimal install or a Full install. We would recommend a Full install for a better Linux experience.
* Do not forget the password you supplied during installation or bad things will happen!
* This will take upto 2 hours. Go make yourself some coffee :)
* Once Fedora Core 5 is fully installed, it will ask you to insert the Addon CD.
* After inserting it and pressing y, it will install a few more things specifically for the PS3's hardware.
* After the install ends, you will see this message:
Install done.
Type reboot to start Linux or type halt to power off.
* Type reboot to restart your PS3.
* Once it reboots, you will be able to login using 'root' username and your supplied password.
* If you're stuck at a command line after logging in, type in startx to load a GUI environment.
Have fun with Fedora Core 5! :)
Proste prawda?
Wszystko poszło ok do miejsca gdy instalator poprosił mnie o Addon CD
Potem pojawiła się lsta błędów i info że instalacja nie powiodła się.
kboot i czeka ,a ja nie wiem jak ponowić mu instalację tej 2-giej płyty.
Udało się.
Ponowna instalacja pomogła.
Okazało się że coś było nie tak z tą 2-gą płytą.
Ale.Fedora nie zapytała mnie w trakcie instalaji o login.Hasło nadałem.
I taraz jest problem bo nie wiem co mam jej wpsać by poszła dalej.
W opisie wygląda to tak.
# Once it reboots, you will be able to login using 'root' username and your supplied password.
# If you're stuck at a command line after logging in, type in startx to load a GUI environment.
login masz "root". Jest to login administratora systemu. Hasło masz takie, jakie nadałeś.
Najlepiej zaraz po zalogowaniu utwórz sobie zwykłego użytkownika, bo siedzenie na roocie nie jest najlepszym pomysłem. Możesz to zrobić komendą
useradd
Informacje jak jej użyć masz w
man useradd
