Aiglx + Radek X1400 Jak To Ugryzdz?
shrek999
Witam, zainstalowalem sobie w koncu fedorke 6. Za drugim podejsciem mal wiecej czasu jak i cierpliwosci wiec sie zabralem za systemik.. moje 4 podejscie do fedorki poczynajac od 2. zatem uporalem sie dzis ze sterami ati poonizej wklejam xorga.
# Xorg configuration created by livna-config-display
Section "ServerLayout"
    Identifier     "single head configuration"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Synaptics" "CorePointer"
EndSection
Section "Files"
    ModulePath   "/usr/lib/xorg/modules"
EndSection
Section "InputDevice"
    Identifier  "Keyboard0"
    Driver      "kbd"
    Option        "XkbModel" "pc105"
    Option        "XkbLayout" "us"
EndSection
    Identifier  "Synaptics"
    Driver      "synaptics"
    Option        "Device" "/dev/input/mice"
    Option        "Protocol" "auto-dev"
    Option        "Emulate3Buttons" "yes"
EndSection
Section "Monitor"
### Comment all HorizSync and VertSync values to use DDC:
    Identifier   "Monitor0"
    ModelName    "LCD Panel 1680x1050"
    HorizSync    31.5 - 90.0
    VertRefresh  59.9 - 60.1
    Option        "dpms"
EndSection
Section "Device"
    Identifier  "Videocard0"
    Driver      "fglrx"
    Option        "VideoOverlay" "on"
EndSection
Section "Screen"
    Identifier "Screen0"
    Device     "Videocard0"
    Monitor    "Monitor0"
    DefaultDepth     24
    SubSection "Display"
        Viewport   0 0
        Depth     24
    EndSubSection
EndSection
Section "ServerFlags"
    Option "AIGLX" "off"
EndSection
Section "Extensions"
    Option "Composite" "Disable"
EndSection
fglrxinfo
display: :0.0  screen: 0
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: ATI Mobility Radeon X1400
OpenGL version string: 2.0.6334 (8.34.8)
jak dobrac sie z tym do compiza czy beryla bo po to sobie teraz zainstalowalem fc6 czesciowo... ;]
dajac AIGLX on i composite enable sterownik na radeon to ixy nie wstaja.. jakos nie moglem znalezdz innych danych co z tym zrobic wiec pisze
