booss Napisano Kwiecień 1, 2007 Zgłoszenie Share Napisano Kwiecień 1, 2007 Witam mam problem z instalacją sterowników do Nvidii geforce 5500 wygląda to tak [kamil@localhost ~]$ su - Hasło: [root@localhost ~]# yum install kmod-nvidia Loading "installonlyn" plugin Setting up Install Process Setting up repositories jpackage-generic 100% |=========================| 951 B 00:00 livna 100% |=========================| 1.1 kB 00:00 flash 100% |=========================| 951 B 00:00 jpackage-fedora 100% |=========================| 951 B 00:00 extras 100% |=========================| 1.1 kB 00:00 core 100% |=========================| 1.1 kB 00:00 updates 100% |=========================| 1.2 kB 00:00 Reading repository metadata in from local files Parsing package install arguments Resolving Dependencies --> Populating transaction set with selected packages. Please wait. ---> Package kmod-nvidia.i686 0:1.0.9755-2.2.6.20_1.2933.fc6 set to be installed --> Running transaction check --> Processing Dependency: nvidia-kmod-common >= 1.0.9755 for package: kmod-nvidia --> Processing Dependency: kernel-i686 = 2.6.20-1.2933.fc6 for package: kmod-nvidia --> Restarting Dependency Resolution with new changes. --> Populating transaction set with selected packages. Please wait. ---> Package xorg-x11-drv-nvidia.i386 0:1.0.9755-3.lvn6 set to be updated ---> Package kernel.i686 0:2.6.20-1.2933.fc6 set to be installed --> Running transaction check Dependencies Resolved ============================================================================= Package Arch Version Repository Size ============================================================================= Installing: kmod-nvidia i686 1.0.9755-2.2.6.20_1.2933.fc6 livna 2.3 M Installing for dependencies: kernel i686 2.6.20-1.2933.fc6 updates 16 M xorg-x11-drv-nvidia i386 1.0.9755-3.lvn6 livna 4.9 M Transaction Summary ============================================================================= Install 3 Package(s) Update 0 Package(s) Remove 0 Package(s) Total download size: 23 M Is this ok [y/N]: y Downloading Packages: Running Transaction Test Finished Transaction Test Transaction Check Error: package kernel-2.6.20-1.2933.fc6 is already installed file /boot/System.map-2.6.20-1.2933.fc6 from install of kernel-2.6.20-1.2933.fc6 conflicts with file from package kernel-2.6.20-1.2933.fc6 file /boot/config-2.6.20-1.2933.fc6 from install of kernel-2.6.20-1.2933.fc6 conflicts with file from package kernel-2.6.20-1.2933.fc6 file /boot/symvers-2.6.20-1.2933.fc6.gz from install of kernel-2.6.20-1.2933.fc6 conflicts with file from package kernel-2.6.20-1.2933.fc6 file /boot/vmlinuz-2.6.20-1.2933.fc6 from install of kernel-2.6.20-1.2933.fc6 conflicts with file from package kernel-2.6.20-1.2933.fc6 [root@localhost ~]# Mam kernel 2.6.20 system fedora core 6 grafika to jak wspomniałem NVidia GeForce 5500 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotreek23 Napisano Kwiecień 1, 2007 Zgłoszenie Share Napisano Kwiecień 1, 2007 http://fedoraproject.org/wiki/Bugs/FC6Comm...097983a3822f143 Blad anacondy jądro i586 zamiast i686 ci zainstalowało.W linku jest rozwiązanie. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
booss Napisano Kwiecień 1, 2007 Autor Zgłoszenie Share Napisano Kwiecień 1, 2007 dzięki ale mam jeszcze jeden problem językowy a mianowicie nie znam angielskiego Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotreek23 Napisano Kwiecień 1, 2007 Zgłoszenie Share Napisano Kwiecień 1, 2007 http://forum.fedora.pl/index.php?showtopic...;hl=kmod-nvidia poszukaj postów gajownika. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
booss Napisano Kwiecień 1, 2007 Autor Zgłoszenie Share Napisano Kwiecień 1, 2007 on napisał ponad 3000 postów do jutra mi zejdzie szukając tego:/ Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotreek23 Napisano Kwiecień 1, 2007 Zgłoszenie Share Napisano Kwiecień 1, 2007 Jezeli mamy problem z niewlasciwie zainstalowana wersja jadra przez instalator Anaconda Fedorki (wersja i568 zamiast i686) to uruchamiamy sobie terminal a w nim wpisujemy nastepujace magiczne polecenia rpm -qa 'kernel*' --queryformat "%{NAME}-%{VERSION}-%{RELEASE}.%{ARCH}\n"|sort Sprawdzamy jaka mamy koncówke jadra jezeli i586 a korzystamy z procesora powyzej pentium II to blad instalatora który zaladowal zle jadra podczas instalacji systemu. Wiec trzeba to naprawic. 1)Instalujemy yum-utils którego czescia jest yum-downloader W terminalu : su - yum install yum-utils Dalej sciagamy jadro skompilowane dla i686 yumdownloader kernel.i686 Teraz dwa przypadki jezeli jadra które sie pobralo wersja jest wieksze od tego które mamy zainstalowane w tej chwili to rpm -ivh kernel-2*.i686.rpm Jezeli jest równe co do wersji to rpm -ivh --replacefiles --replacepkgs kernel-2*.i686.rpm Nastepnie resetujemy maszyne uruchamiamy z nowym jajkiem i powinno ladnie dzialac. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
booss Napisano Kwiecień 1, 2007 Autor Zgłoszenie Share Napisano Kwiecień 1, 2007 wielkie dzięki Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
piotreek23 Napisano Kwiecień 1, 2007 Zgłoszenie Share Napisano Kwiecień 1, 2007 wielkie dzięki Nie ma sprawy temat i tak pójdzie do FAQ linków żeby nie szukać po forum rozwiazań. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
