Fc6 I N6230 Brak Połączenia W Iplusie
juchas
uzywalem ubuntu 6.10 net dzialal bez problemu lecz na fc6 laczy sie jedynie "teoretycznie" tzn w konsoli po wpisaniu "pppd call gprs" idzie wszystko tak jak to mialo miejsce na ubuntu ale gdy odpalam przegladarke czy komunikatora gaim brak polaczenia z netem. oto pliki które uzywam to laczenia:
GPRS
# $Id: gprs,v 1.4 2004/04/28 08:40:32 mcfrisk Exp $
# File:
# gprs
# Description:
# Serial cable, IrDA, Bluetooth and USB pppd options for GPRS phones.
# See 'man pppd' for detailed option descriptions.
# Most GPRS phones don't reply to LCP echo's
lcp-echo-failure 0
lcp-echo-interval 0
# Keep pppd attached to the terminal:
# Comment this to get daemon mode pppd
nodetach
# Debug info from pppd:
# Comment this off, if you don't need more info
debug
# Show password in debug messages
show-password
# Connect script:
# scripts to initialize the GPRS modem and start the connection,
# wvdial command is for Orange SPV while other phones should work with chat
#connect /etc/ppp/peers/gprs-connect-chat
connect "/usr/bin/wvdial --chat --config /etc/ppp/peers/gprs-wvdial.conf radiolinja_usb_orange_spv"
# Disconnect script:
# AT commands used to 'hangup' the GPRS connection.
disconnect /etc/ppp/peers/gprs-disconnect-chat
# Serial device to which the GPRS phone is connected:
# /dev/ttyS0 for serial port (COM1 in Windows),
# /dev/ircomm0 for IrDA,
# /dev/ttyUB0 for Bluetooth (Bluez with rfcomm running) and
#/dev/ttyACM0    # for USB
/dev/ttyACM0
#/dev/ttyS0	# serial port one
#/dev/ttyS1	# serial port two
#/dev/ircomm0	# IrDA serial port one
#/dev/rfcomm0	# Bluetooth serial port one
#/dev/ttyUSB0	# USB serial device, for example Orange SPV
# Serial port line speed
#115200	# fast enough
57600	# perhaps usefull with IrDA as some phones don't like
       # speeds higher than this
# Hardware flow control:
# Use hardware flow control with cable, Bluetooth and USB but not with IrDA.
crtscts  # serial cable, Bluetooth and USB, on some occations with IrDA too
#nocrtscts # IrDA
# Ignore carrier detect signal from the modem:
local
# IP addresses:
# - accept peers idea of our local address and set address peer as 10.0.0.1
# (any address would do, since IPCP gives 0.0.0.0 to it)
# - if you use the 10. network at home or something and pppd rejects it,
# change the address to something else
:10.0.0.1
# pppd must not propose any IP address to the peer!
noipdefault
# Accept peers idea of our local address
ipcp-accept-local
# Add the ppp interface as default route to the IP routing table
defaultroute
# Newer pppd's also support replacing the default route, if one is
# already present, when the GPRS connetion should be set as the default route
# to the network
#replacedefaultroute
# DNS servers from the phone:
# some phones support this, some don't.
usepeerdns
# ppp compression:
# ppp compression may be used between the phone and the pppd, but the
# serial connection is usually not the bottleneck in GPRS, so the
# compression is useless (and with some phones need to disabled before
# the LCP negotiations succeed).
novj
nobsdcomp
novjccomp
nopcomp
noaccomp
# The phone is not required to authenticate:
noauth
# Username and password:
# If username and password are required by the APN, put here the username
# and put the username-password combination to the secr#!/bin/sh
# $Id: gprs-disconnect-chat,v 1.3 2004/07/08 22:40:47 mcfrisk Exp $
# File:
# gprs-disconnect-chat
# send break
exec /usr/sbin/chat -V -s -S	\
ABORT		"BUSY"		\
ABORT		"ERROR"		\
ABORT		"NO DIALTONE"	\
SAY		"\nSending break to the modem\n"	\
""		"\K"		\
""		"\K"		\
""		"\K"		\
""		"+++ATH"	\
""		"+++ATH"	\
""		"+++ATH"	\
SAY		"\nPDP context detached\n"
ets file:
# /etc/ppp/pap-secrets for PAP and /etc/ppp/chap-secrets for CHAP
# authentication. See pppd man pages for details.
# Example, Radiolinja operator pap-secrets:
# "rlnet"         *       "internet"	*
user "internet"
#user "internet"
# The persist tries to reopen the connection if it is dropped. This
# is usefull for example with a Nokia 7650 which only manages to
# 'dial' with every second attempt or when the network lik#!/bin/sh
# File:
# send break
ABORT		"BUSY"		\
ABORT		"ERROR"		\
""		"\K"		\
""		"\K"		\
""		"\K"		\
""		"+++ATH"	\
""		"+++ATH"	\
""		"+++ATH"	\
es to drop the
# connection every now and then. It's not fun when the over-night
# 'apt-get dist-upgrade -d -y' fails constantly...
#persist
#maxfail 99
#!/bin/sh
# File:
# send break
ABORT		"BUSY"		\
ABORT		"ERROR"		\
""		"\K"		\
""		"\K"		\
""		"\K"		\
""		"+++ATH"	\
""		"+++ATH"	\
""		"+++ATH"	\
# Asyncmap:
# some phones may require this option.
#asyncmap 0xa0000
# No magic:
#nomagic
# Require PAP authentication:
#require-pap
gprs-connect-chat
#!/bin/sh
# $Id: gprs-connect-chat,v 1.2 2004/02/02 23:19:28 mcfrisk Exp $
# File:
# gprs-connect-chat
# Description: #!/bin/sh
# File:
# send break
ABORT		"BUSY"		\
ABORT		"ERROR"		\
""		"\K"		\
""		"\K"		\
""		"\K"		\
""		"+++ATH"	\
""		"+++ATH"	\
""		"+++ATH"	\
# chat script to open Radiolinjas GPRS service with GPRS phones. If ppp
# negotiation stalls, try restarting the phone. To try with other GPRS
# operator setting, change the PDP contex setting. The settings work with
# most Ericsson models, but Nokia 8310 and 30 do not support QoS parameters
# with AT commands, so just delete those lines and it'll work.
# Set PDP context CID=1, protocol=IP, APN=internet:
# AT+CGDCONT=1,"IP","internet","",0,0
# Set CID=1 QoS requirements from the network, not supported by Nokia:
# AT+CGQREQ=1,0,0,0,0,0
# Set CID=1 minimum acceptable QoS parameters, not supported by Nokia:
# AT+CGQMIN=1,0,0,0,0,0
# 'Call' CID=1 (activate PDP context one, perform GPRS attach):
# ATD*99***1#
# Some phones like the Orange SPV (yes, the Microsoft Smartphone) use this
# dial string to start GPRS connection:
# ATD*99#
# The actual chat script:
exec chat 						\
TIMEOUT		5				\
ECHO 		ON				\
ABORT		'\nBUSY\r'			\
ABORT		'\nERROR\r'			\
ABORT		'\nNO ANSWER\r'			\
ABORT		'\nNO CARRIER\r'		\
ABORT		'\nNO DIALTONE\r'		\
ABORT		'\nRINGING\r\n\r\nRINGING\r'	\
''		\rAT				\
TIMEOUT		12				\
SAY		"Press CTRL-C to close the connection at any stage!"	\
SAY		"\ndefining PDP context...\n"	\
OK		ATH				\
OK		ATE1				\
OK		'AT+CGDCONT=1,"IP","internet","",0,0'	\
#	OK		'AT+CGDCONT=1,"IP","internet","",0,0'	\
OK		ATD*99#				\
TIMEOUT		22				\
SAY		"\nwaiting for connect...\n"	\
CONNECT		""				\
SAY		"\nConnected." \
SAY		"\nIf the following ppp negotiations fail,\n"	\
SAY		"try restarting the phone.\n"
#!/bin/sh
# File:
# send break
ABORT		"BUSY"		\
ABORT		"ERROR"		\
""		"\K"		\
""		"\K"		\
""		"\K"		\
""		"+++ATH"	\
""		"+++ATH"	\
""		"+++ATH"	\
gprs-wvdial.conf
# File:
# $Id: gprs-wvdial.conf,v 1.3 2004/04/27 21:44:35 mcfrisk Exp $
# gprs-wvdial.conf
# Description:
# Wvdial settings for different GPRS phones and operators. See wvdial man pages
# for more help. Below are the service specific settings, which should be given
# by the operator - at least the
# Set PDP (Packet Data Protocol) context CID (Context ID)  = 1 (an index sort of
# since a phone may have many different GPRS settings), protocol = IP,
# APN (Access Point Name) = "internet":
# Set CID=1 QoS (Quality of Service) requirements from the network, not
# supported by Nokia phones:
# Set CID=1 minimum acceptable QoS parameters, not supported by Nokia phones:
# Call CID=1 which activate PDP context one and perform GPRS attach:
# ATD*99***1#
# Some phones seem to have only one CID, in which case the CID can be omitted
# when calling:
# ATD*99#
# Init4 = AT+CGQREQ=1,0,0,0,0,0
# Init5 = AT+CGQMIN=1,0,0,0,0,0
[Dialer radiolinja_usb_orange_spv]
#Modem = /dev/ttyACM0
#Baud = 115200
Baud = 57600
Init1 = ATH
Init2 = ATE1
#Init3 = AT+CGDCONT=1,"IP","internet","",0,0
# Some phones like the NEC DB7000 don't like empty strings, so an address must
# be provided
#Init3 = AT+CGDCONT=1,"IP","internet","0.0.0.0",0,0
# Some phones don't like the quality of service parameters:
Dial Command = ATD
#Phone = *99#
#Phone = ATD*99***1#
Phone=*99***1#
Username = plusgsm
Password = plusgsm
#Username =
#Password =
