Mldonkey
guciol
instalacje poszla bez przeszkod.
po odpaleniu "mlnet " wywala mi cos takiego
No /home/piotr/.mldonkey/installer.ini found
Resolving [dom] ...done
Network Global Shares registered
Network FileTP registered
Network BitTorrent registered
No ./results.ini found
Network.save_complex_options not implemented by BitTorrent
Options correctly saved on localtime: 16/ 9, 08:24:23
Network.load_complex_options not implemented by BitTorrent
Network.load_complex_options not implemented by FileTP
Network BitTorrent enabled
Network FileTP enabled
enable
enabling...
Exception: bind failed: Address already in use at port 6881
Exception in BTTracker.start_tracker: bind failed: Address already in use
XXXXXXXXXXXXXXX
Exception: bind failed: Address already in use at port 6882
Exception bind failed: Address already in use while init bittorrent server
Network.recover_temp not implemented by BitTorrent
Network.recover_temp not implemented by FileTP
Exception: bind failed: Address already in use at port 4080
Exception http server while starting bind failed: Address already in use
Exception: bind failed: Address already in use at port 4000
Exception telnet server while starting bind failed: Address already in use
Exception: bind failed: Address already in use at port 4002
Exception chat server while starting bind failed: Address already in use
Connection refused : connect
chat_app_host=localhost chat_app_port=5036
Exception: bind failed: Address already in use at port 4001
Exception gui server while starting bind failed: Address already in use
Exception: bind failed: Address already in use at port 1213
Exception gift server while starting bind failed: Address already in use
SHARING ./incoming PRIO 0
SHARING shared PRIO 0
QUERY URL http://ocbmaurice.dyndns.org/pl/slist.pl/s...server-best.met
Welcome to MLdonkey client
Check http://www.mldonkey.net/ for updates
To command: telnet 127.0.0.1 4000
Or with browser: http://127.0.0.1:4080
Welcome to MLdonkey
Core started on localtime: 16/ 9, 08:24:23
Disabling output to console, to enable: stdout true
Wyczytalem ze trzeba potem odpalic nakladke g2gui albo sancho.
Wszystko fajnie - nakladke mam g2gui - binarke. tylko nie moge jej odpalic.
co mam wpisac w konsoli zeby to zadzialalo ????
Upewnij się, że poprawnie wgrałeś mldonkey i GUI. GUI musi być w odpowiedniej wersji do mldonkey's (a dosdniej jego core'a) - to kluczowy warunek, aby to mogło działać! Nie odpalaj mlnet (przynajmniej ja nie musiałem), pozwól GUI zająć się wszystkim. Osobiście polecam mldonkey'a tylko na szybkie łącza i chcę podkreślić, że mi działało dopiero trzecie próbowane GUI (ale to było już bardzo dawno, pewnie z mojej winy), więc popróbuj ekwiwalentów.
Gość
