K3b Dvd-video
satch_boogie
Witam,
Mam pliki dvd-video w katalogu VIDEO_TS (projekt jest ok - inni wypalali w nero i poszlo)
Dostaje debug:
System
K3b Version: 1.0
KDE Version: 3.5.5-0.2.fc5 Fedora-Core
QT Version:  3.3.7
Kernel:      2.6.20-1.2316.fc5
Devices
HL-DT-ST CD-RW GCE-8523B 1.03 (/dev/hdc, ) [CD-R, CD-RW, CD-ROM] [CD-ROM, CD-R, CD-RW] [sAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R]
HL-DT-ST DVDRAM GSA-H10N JL10 (/dev/hdd, ) [CD-R, CD-RW, CD-ROM, DVD-ROM, DVD-R, DVD-RW, DVD-R DL, DVD+R, DVD+RW, DVD+R DL] [DVD-ROM, DVD-R Sequential, DVD-R Dual Layer Sequential, DVD-R Dual Layer Jump, DVD-RAM, DVD-RW Restricted Overwrite, DVD-RW Sequential, DVD+RW, DVD+R, DVD+R Dual Layer, CD-ROM, CD-R, CD-RW] [sAO, TAO, RAW, SAO/R96P, SAO/R96R, RAW/R16, RAW/R96P, RAW/R96R, Restricted Overwrite, Layer Jump]
K3bIsoImager
mkisofs print size result: 0 (0 bytes)
Used versions
mkisofs: 2.1.1a03
mkisofs
/usr/bin/mkisofs: Warning: -follow-links does not always work correctly; be careful.
Unknown file type (unallocated) /tmp/kde-grzes/k3bVideoDvd0/.. - ignoring and continuing.
/usr/bin/mkisofs: IFO is not of correct size aborting
/usr/bin/mkisofs: Unable to parse DVD-Video structures.
/usr/bin/mkisofs: Unable to make a DVD-Video image.
mkisofs calculate size command:
/usr/bin/mkisofs -gui -graft-points -print-size -quiet -volid VIDEO_TS -volset  -appid K3B THE CD KREATOR © 1998-2006 SEBASTIAN TRUEG AND THE K3B TEAM -publisher  -preparer  -sysid LINUX -abstract  -copyright  -biblio  -volset-size 1 -volset-seqno 1 -sort /tmp/kde-grzes/k3bjnBa7a.tmp -no-cache-inodes -udf -iso-level 1 -path-list /tmp/kde-grzes/k3bWO1hJb.tmp -dvd-video -f /tmp/kde-grzes/k3bVideoDvd0
macie jakiś pomysł, bede wdzieczny
