F7 Installation Fail
nowybog
Takie smaczki mi wyskoczyły podczas sprawdzania zależności pakietów...
Traceback (most recent call first):
 File "/usr/lib/anaconda/yuminstall.py", line 159, in callback
   s = str(_("<b>Installing %s</b> (%s)\n") %(po, size_string(hdr['size'])))
 File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 562, in runTransaction
   errors = self.ts.run(cb.callback, '')
 File "/usr/lib/anaconda/yuminstall.py", line 633, in _run
   self.runTransaction(cb=cb)
 File "/usr/lib/anaconda/yuminstall.py", line 623, in run
   self._run(instLog, cb, intf)
 File "/usr/lib/anaconda/yuminstall.py", line 1244, in doInstall
   self.ayum.run(self.instLog, cb, anaconda.intf, anaconda.id)
 File "/usr/lib/anaconda/backend.py", line 236, in doInstall
   anaconda.backend.doInstall(anaconda)
 File "/usr/lib/anaconda/dispatch.py", line 203, in moveStep
   rc = stepFunc(self.anaconda)
 File "/usr/lib/anaconda/dispatch.py", line 126, in gotoNext
   self.moveStep()
 File "/usr/lib/anaconda/text.py", line 605, in run
   anaconda.dispatch.gotoNext()
 File "/usr/bin/anaconda", line 955, in <module>
   anaconda.intf.run(anaconda)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 6: ordinal not in range(128)
Local variables in innermost frame:
what: 4
hdr: <rpm.hdr object at 0xb88ecb0>
txmbrs: [<yum.transactioninfo.TransactionMember instance at 0xafbd26c>]
h: (<rpm.hdr object at 0xb88ecb0>, u'/tmp/cache/anaconda-base-200705271038.i386/packages/filesystem-2.4.6-1.fc7.i386.rpm')
self: <yuminstall.AnacondaCallback instance at 0xb0555cc>
amount: 0
repo: anaconda-base-200705271038.i386
rpmloc: /tmp/cache/anaconda-base-200705271038.i386/packages/filesystem-2.4.6-1.fc7.i386.rpm
epoch: None
user:
total: 0
po: filesystem - 2.4.6-1.fc7.i386
Anaconda instance, containing members:
rootPath: /mnt/sysimage
rescue_mount: True
intf: InstallInterface instance, containing members:
 intf.screen: SnackScreen instance, containing members:
   intf.screen.width: 80
   intf.screen.helpCb: <bound method InstallInterface.helpWindow of <text.InstallInterface instance at 0x9f821ac>>
   intf.screen.height: 25
 intf.instLanguage: Language instance, containing members:
   intf.instLanguage.targetLang: None
   intf.instLanguage.default: pl
   intf.instLanguage.displayMode: t
   intf.instLanguage.current: pl_PL.UTF-8
 intf.showingHelpOnHelp: 0
rescue: False
updateSrc: None
methodstr: cdrom://scd0:/mnt/source
dispatch: Dispatcher instance, containing members:
 dispatch.skipSteps: {'upgradecontinue': 1, 'findinstall': 1, 'language': 2, 'upgradeswapsuggestion': 1, 'confirmupgrade': 1, 'betanag': 2, 'upgrademount': 1, 'upgbootloader': 1, 'upgrademigfind': 1, 'addswap': 1, 'upgrademigratefs': 1, 'regkey': 1}
 dispatch.method: CdromInstallMethod instance, containing members:
   dispatch.method.messageWindow: <bound method InstallInterface.messageWindow of <text.InstallInterface instance at 0x9f821ac>>
   dispatch.method.splitmethod: True
   dispatch.method.intf: Already dumped
   dispatch.method.isoPath: /mnt/source
   dispatch.method.timestamp: 1180276843.561677
   dispatch.method.tree: /mnt/source
   dispatch.method.rootPath: /mnt/sysimage
   dispatch.method.waitWindow: <bound method InstallInterface.waitWindow of <text.InstallInterface instance at 0x9f821ac>>
   dispatch.method.loopbackFile: /mnt/sysimage//rhinstall-stage2.img
   dispatch.method.progressWindow: <bound method InstallInterface.progressWindow of <text.InstallInterface instance at 0x9f821ac>>
   dispatch.method.device: scd0
   dispatch.method.currentMedia: [1]
 dispatch.step: 38
 dispatch.anaconda: Already dumped
 dispatch.firstStep: 0
 dispatch.dir: 1
method: Already dumped
isKickstart: False
id: InstallData instance, containing members:
 id.firewall: Firewall instance, containing members:
   id.firewall.portlist: [22:tcp]
   id.firewall.trustdevs: []
   id.firewall.enabled: 1
 id.rootParts: []
 id.instProgress: InstallProgressWindow instance, containing members:
   id.instProgress.info: Textbox instance, containing members:
     id.instProgress.info.w: <snackwidget object at 0xb2b7760>
   id.instProgress.screen: Already dumped
   id.instProgress.pct: 0.000200023651597
   id.instProgress.label: Label instance, containing members:
     id.instProgress.label.w: <snackwidget object at 0xb2b7c80>
   id.instProgress.width: 65
   id.instProgress.grid: GridForm instance, containing members:
     id.instProgress.grid.form: Form instance, containing members:
       id.instProgress.grid.form.trans: {246171352: Scale instance, containing members:
         id.instProgress.grid.form.trans.w: <snackwidget object at 0xb055d20>
, 249868120: Already dumped
, 296822608: Already dumped
       id.instProgress.grid.form.helpArg: None
       id.instProgress.grid.form.w: <snackform object at 0xb7f7aed0>
       id.instProgress.grid.form.filemap: {}
     id.instProgress.grid.g: <snackgrid object at 0xb7f7af00>
     id.instProgress.grid.title: Instalacja pakietów
     id.instProgress.grid.screen: Already dumped
     id.instProgress.grid.childList: [Already dumped
, Already dumped
, Already dumped
     id.instProgress.grid.form_created: 1
     id.instProgress.grid.gridmembers: [Already dumped
, Already dumped
, Already dumped
   id.instProgress.progress: Already dumped
   id.instProgress.drawn: True
 id.upgradeRoot: []
 id.xsetup: XSetup instance, containing members:
   id.xsetup.skipx: 0
   id.xsetup.xserver: XServer instance, containing members:
     id.xsetup.xserver.videohw: primary: 0
vidCards: [<rhpxl.videocard.VideoCard instance at 0xaa176ac>]
Primary Video Card Info:
device: None
driver : nv
descr : nVidia Corporation NV11DDR [GeForce2 MX200]
vidRam: None
     id.xsetup.xserver.serverflags: [vt6, -config, /tmp/XConfig.test, -extension, Composite, -s, 1440, -dpms, -v, -ac, -nolisten, tcp]
     id.xsetup.xserver.resolution: 800x600
     id.xsetup.xserver.root: /
     id.xsetup.xserver.hwstate: XF86HardwareState instance, containing members:
       id.xsetup.xserver.hwstate.videocard_PCIFn: None
       id.xsetup.xserver.hwstate.monitor: monName: None
monID: Unprobed Monitor
monHoriz: None
monVert: None
physicalWidth: 0
physicalHeight: 0
       id.xsetup.xserver.hwstate.config_resolutions: []
       id.xsetup.xserver.hwstate.videocard_name: nVidia Corporation NV11DDR [GeForce2 MX200]
       id.xsetup.xserver.hwstate.monitor_name: Unknown monitor
       id.xsetup.xserver.hwstate.video_ram: 0
       id.xsetup.xserver.hwstate.videocard: Already dumped
       id.xsetup.xserver.hwstate.videocard_driver: nv
       id.xsetup.xserver.hwstate.videocard_options: []
       id.xsetup.xserver.hwstate.all_resolutions: [640x480, 800x480, 800x512, 800x600, 848x480, 854x480, 1024x600, 1024x768, 1152x768, 1152x864, 1200x900, 1280x720, 1280x800, 1280x854, 1280x960, 1280x1024, 1360x768, 1400x900, 1400x1050, 1440x900, 1600x1024, 1600x1200, 1680x1050, 1900x1200, 1920x1080, 1920x1200, 1920x1440, 2048x1536, 2560x1600]
       id.xsetup.xserver.hwstate.hsync: 31.5-37.9
       id.xsetup.xserver.hwstate.vsync: 50-70
       id.xsetup.xserver.hwstate.probed_video_ram: 0
       id.xsetup.xserver.hwstate.videocard_PCIBus: None
       id.xsetup.xserver.hwstate.colordepth: 24
       id.xsetup.xserver.hwstate.videocard_PCIDev: None
       id.xsetup.xserver.hwstate.resolution: 800x600
       id.xsetup.xserver.hwstate.dri_enabled: 0
       id.xsetup.xserver.hwstate.xconfig: None
     id.xsetup.xserver.monitorhw: Already dumped
     id.xsetup.xserver.keyboard: Keyboard instance, containing members:
       id.xsetup.xserver.keyboard.info: {'KEYBOARDTYPE': pc, 'KEYTABLE': pl2}
       id.xsetup.xserver.keyboard.type: PC
       id.xsetup.xserver.keyboard.beenset: 1
       id.xsetup.xserver.keyboard._mods: KeyboardModels instance, containing members:
     id.xsetup.xserver.mousehw: FULLNAME="Generic - 3 Button Mouse (PS/2)"
MOUSETYPE="imps2"
XEMU3="no"
XMOUSETYPE="IMPS/2"
     id.xsetup.xserver.defaultdepth: 24
     id.xsetup.xserver.logfile: /dev/null
     id.xsetup.xserver.config: None
     id.xsetup.xserver.display: :9
   id.xsetup.anaconda: Already dumped
 id.keyboard: Already dumped
 id.timezone: Timezone instance, containing members:
   id.timezone.utc: True
   id.timezone.arc: 0
   id.timezone.tz: Europe/Warsaw
 id.mouse: Already dumped
 id.zfcp: ZFCP instance, containing members:
   id.zfcp.hasReadConfig: True
   id.zfcp.fcpdevs: []
 id.upgrade: None
 id.monitor: Already dumped
 id.iscsi: <iscsi.iscsi object at 0xaa2d10c>
 id.methodstr: cdrom://scd0:/mnt/source
 id.fsset: FileSystemSet instance, containing members:
   id.fsset.messageWindow: <bound method InstallInterface.messageWindow of <text.InstallInterface instance at 0x9f821ac>>
   id.fsset.volumesCreated: 1
   id.fsset.progressWindow: <bound method InstallInterface.progressWindow of <text.InstallInterface instance at 0x9f821ac>>
   id.fsset.migratedfs: 1
   id.fsset.waitWindow: <bound method InstallInterface.waitWindow of <text.InstallInterface instance at 0x9f821ac>>
   id.fsset.entries: [fsentry -- device: VolGroup00/LogVol00   mountpoint: /
 fsystem: ext3 format: 1
 ismounted: 1  options: 'defaults'
 bytesPerInode: 4096 label: None
, fsentry -- device: sda6   mountpoint: /boot
 bytesPerInode: 4096 label: /boot
, fsentry -- device: shm   mountpoint: /dev/shm
 fsystem: tmpfs format: 0
 ismounted: 0  options: 'defaults'
, fsentry -- device: devpts   mountpoint: /dev/pts
 fsystem: devpts format: 0
 ismounted: 0  options: 'gid=5,mode=620'
, fsentry -- device: sys   mountpoint: /sys
 fsystem: sysfs format: 0
, fsentry -- device: proc   mountpoint: /proc
 fsystem: proc format: 0
, fsentry -- device: sda1   mountpoint: None
 fsystem: ntfs format: 0
, fsentry -- device: VolGroup00   mountpoint: None
 fsystem: volume group (LVM) format: 1
, fsentry -- device: sda7   mountpoint: None
 fsystem: physical volume (LVM) format: 1
, fsentry -- device: VolGroup00/LogVol01   mountpoint: swap
 fsystem: swap format: 1
   id.fsset.mountcount: 5
 id.desktop: Desktop instance, containing members:
   id.desktop.info: {}
   id.desktop.runlevel: 3
 id.x_already_set: 0
 id.backend: YumBackend instance, containing members:
   id.backend.modeText: Instalowanie %s
   id.backend.instPath: /mnt/sysimage
   id.backend.supportsPackageSelection: True
   id.backend.totalSize: 2211135
   id.backend.instLog: <open file '/mnt/sysimage/root/install.log', mode 'w+' at 0xb315ec0>
   id.backend.supportsUpgrades: True
   id.backend.method: Already dumped
   id.backend.totalFiles: 116826
 id.firstboot: 0
 id.diskset: DiskSet instance, containing members:
   id.diskset.disks: {'sda': <PedDisk object at 0xa97e7a0>}
   id.diskset.anaconda: Already dumped
   id.diskset.onlyPrimary: None
 id.users: None
 id.displayMode: t
 id.auth: --enableshadow --enablemd5
 id.ksdata: None
 id.bootloader: x86BootloaderInfo instance, containing members:
   id.bootloader.doUpgradeOnly: 0
   id.bootloader.above1024: 0
   id.bootloader.defaultDevice: mbr
   id.bootloader.pure: None
   id.bootloader.serialDevice: None
   id.bootloader.args: KernelArguments instance, containing members:
     id.bootloader.args.args:
   id.bootloader.kernelLocation: /boot/
   id.bootloader.device: sda
   id.bootloader.configfile: /etc/lilo.conf
   id.bootloader.kickstart: 0
   id.bootloader.serialOptions: None
   id.bootloader.useGrubVal: 1
   id.bootloader._drivelist: [sda]
   id.bootloader.images: BootImages instance, containing members:
     id.bootloader.images.default: VolGroup00/LogVol00
     id.bootloader.images.images: {'VolGroup00/LogVol00': ('linux', 'Fedora', 'ext3'), 'sda1': ('Windows 2000', 'Windows 2000', 'ntfs')}
   id.bootloader.serial: 0
   id.bootloader.password: None
   id.bootloader.forceLBA32: False
 id.extraModules: []
 id.network: Network instance, containing members:
   id.network.hostname: Fx
   id.network.overrideDHCPhostname: 1
   id.network.netdevices: {'eth0': DEVICE=eth0
BOOTPROTO=dhcp
HWADDR=00:C0:DF:EB:B0:2D
IPV6_AUTOCONF=yes
ONBOOT=yes
   id.network.primaryNS:
   id.network.firstnetdevice: eth0
   id.network.isConfigured: 0
   id.network.domains: []
   id.network.secondaryNS:
   id.network.gateway:
 id.instClass: DefaultInstall instance, containing members:
 id.floppyDevice: fd0
 id.partitions: Partitions instance, containing members:
   id.partitions.useFdisk: 0
   id.partitions.useAutopartitioning: 1
   id.partitions.autoClearPartType: 2
   id.partitions.nextUniqueID: 10
   id.partitions.reinitializeDisks: 0
   id.partitions.autoClearPartDrives: [sda]
   id.partitions.zeroMbr: 0
   id.partitions.isKickstart: 0
   id.partitions.requests: [New Part Request -- mountpoint: /boot uniqueID: 8
 type: ext3  format: 1  badblocks: None
 device: sda6 drive: ['sda']  primary: None
 size: 100  grow: 0  maxsize: None
 start: None  end: None  migrate: None    fslabel: None  origfstype: None
 bytesPerInode: 4096  options: 'None'
, PreexistingPartitionSpec instance, containing members:
     currentDrive: None
     migrate: None
     origfstype: NTFSFileSystem instance, containing members:
       origfstype.partedPartitionFlags: []
       origfstype.checked: 0
       origfstype.name: ntfs
       origfstype.migratetofs: None
       origfstype.deviceArguments: {}
       origfstype.linuxnativefs: 0
       origfstype.maxSizeMB: 8388608
       origfstype.supported: -1
       origfstype.defaultOptions: defaults
       origfstype.packages: []
       origfstype.extraFormatArgs: []
       origfstype.formattable: 0
       origfstype.partedFileSystemType: <PedFileSystemType object at 0xb7f046e0>
       origfstype.maxLabelChars: 16
     primary: None
     dev: PartitionDevice instance, containing members:
       dev.device: sda1
       dev.isSetup: 0
       dev.doLabel: 1
       dev.deviceOptions:
       dev.label: None
     uniqueID: 1
     mountpoint: None
     requestSize: 8934.55664062
     end: 18298034
     grow: 0
     start: 63
     ignoreBootConstraints: 0
     type: 1
     badblocks: None
     format: None
     fsopts: None
     fstype: Already dumped
     preexist: 1
     device: sda1
     maxSizeMB: None
     bytesPerInode: 4096
     drive: sda
     fslabel: None
     protected: 0
     multidrive: None
, LV Request -- mountpoint: /  uniqueID: 7
 size: 9376  lvname: LogVol00  volgroup: 6
, VG Request -- name: VolGroup00  uniqueID: 6
 format: 1 pesize: 32768
 physvols: [5]
     currentDrive: None
     migrate: None
     origfstype: None
     primary: None
     dev: None
     uniqueID: 2
     mountpoint: None
     requestSize: 29227.6318359
     end: 78156224
     grow: 0
     start: 18298035
     type: 1
     badblocks: None
     format: None
     fsopts: None
     fstype: None
     preexist: 1
     device: sda2
     maxSizeMB: None
     bytesPerInode: 4096
     drive: sda
     fslabel: None
     protected: 0
     multidrive: None
, New Part Request -- mountpoint: None uniqueID: 5
 type: physical volume (LVM)  format: 1  badblocks: None
 device: sda7 drive: ['sda']  primary: None
 size: 0  grow: 1  maxsize: None
     currentDrive: None
     migrate: None
     origfstype: None
     primary: None
     dev: None
     uniqueID: 3
     mountpoint: None
     requestSize: 10150.4135742
     end: 39086144
     grow: 0
     start: 18298098
     type: 1
     badblocks: None
     format: None
     fsopts: None
     fstype: None
     preexist: 1
     device: sda-1
     maxSizeMB: None
     bytesPerInode: 4096
     drive: sda
     fslabel: None
     protected: 0
     multidrive: None
     currentDrive: None
     migrate: None
     origfstype: FATFileSystem instance, containing members:
       origfstype.name: vfat
       origfstype.maxSizeMB: 1048576
       origfstype.packages: [dosfstools]
       origfstype.formattable: 1
       origfstype.partedFileSystemType: <PedFileSystemType object at 0xb7f04260>
     primary: None
     dev: None
     uniqueID: 4
     mountpoint: None
     requestSize: 19077.1567383
     end: 78156224
     grow: 0
     start: 39086208
     type: 1
     badblocks: None
     format: None
     fsopts: None
     preexist: 1
     device: sda5
     maxSizeMB: None
     bytesPerInode: 4096
     drive: sda
     fslabel: None
     protected: 0
     multidrive: None
, LV Request -- mountpoint: None  uniqueID: 9
 type: swap  format: 1  badblocks: None
 size: 640  lvname: LogVol01  volgroup: 6
   id.partitions.autoPartitionRequests: [New Part Request -- mountpoint: None uniqueID: None
 device: None drive: None  primary: None
, VG Request -- name: lvm  uniqueID: None
 physvols: []
, LV Request -- mountpoint: /  uniqueID: None
 size: 1024  lvname: LogVol00  volgroup: lvm
, New Part Request -- mountpoint: /boot uniqueID: None
, LV Request -- mountpoint: None  uniqueID: None
 size: 320  lvname: LogVol01  volgroup: lvm
   id.partitions.deletes: []
 id.isHeadless: 0
 id.videocard: Already dumped
 id.instLanguage: Already dumped
 id.security: Security instance, containing members:
   id.security.selinux: 1
 id.upgradeSwapInfo: None
dir: 1
backend: Already dumped
/tmp/syslog:
<5>Linux version 2.6.21-1.3194.fc7 ([email protected]) (gcc version 4.1.2 20070502 (Red Hat 4.1.2-12)) #1 SMP Wed May 23 22:11:19 EDT 2007
<6>BIOS-provided physical RAM map:
<4>sanitize start
<4>sanitize end
<4>copy_e820_map() start: 0000000000000000 size: 000000000009fc00 end: 000000000009fc00 type: 1
<4>copy_e820_map() type is E820_RAM
<4>copy_e820_map() start: 000000000009fc00 size: 0000000000000400 end: 00000000000a0000 type: 2
<4>copy_e820_map() start: 00000000000f0000 size: 0000000000010000 end: 0000000000100000 type: 2
<4>copy_e820_map() start: 0000000000100000 size: 0000000013efd000 end: 0000000013ffd000 type: 1
<4>copy_e820_map() start: 0000000013ffd000 size: 0000000000002000 end: 0000000013fff000 type: 3
<4>copy_e820_map() start: 0000000013fff000 size: 0000000000001000 end: 0000000014000000 type: 4
<4>copy_e820_map() start: 00000000ffff0000 size: 0000000000010000 end: 0000000100000000 type: 2
<4> BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
<4> BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
<4> BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
<4> BIOS-e820: 0000000000100000 - 0000000013ffd000 (usable)
<4> BIOS-e820: 0000000013ffd000 - 0000000013fff000 (ACPI data)
<4> BIOS-e820: 0000000013fff000 - 0000000014000000 (ACPI NVS)
<4> BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
<5>0MB HIGHMEM available.
<5>319MB LOWMEM available.
<4>Using x86 segment limits to approximate NX protection
<7>Entering add_active_range(0, 0, 81917) 0 entries of 256 used
<4>Zone PFN ranges:
<4>  DMA             0 ->     4096
<4>  Normal       4096 ->    81917
<4>  HighMem     81917 ->    81917
<4>early_node_map[1] active PFN ranges
<4>    0:        0 ->    81917
<7>On node 0 totalpages: 81917
<7>  DMA zone: 32 pages used for memmap
<7>  DMA zone: 0 pages reserved
<7>  DMA zone: 4064 pages, LIFO batch:0
<7>  Normal zone: 607 pages used for memmap
<7>  Normal zone: 77214 pages, LIFO batch:15
<7>  HighMem zone: 0 pages used for memmap
<6>DMI 2.0 present.
<6>Using APIC driver default
<4>ACPI: RSDP 000F79A0, 0014 (r0 ASUS  )
<4>ACPI: RSDT 13FFD000, 002C (r1 ASUS   P2B-VM   42302E31 MSFT 31313031)
<4>ACPI: FACP 13FFD080, 0074 (r1 ASUS   P2B-VM   42302E31 MSFT 31313031)
<4>ACPI: DSDT 13FFD100, 1A83 (r1   ASUS P2B-VM       1000 MSFT  1000001)
<4>ACPI: FACS 13FFF000, 0040
<4>ACPI: BOOT 13FFD040, 0028 (r1 ASUS   P2B-VM   42302E31 MSFT 31313031)
<6>ACPI: PM-Timer IO Port: 0xe408
<4>Allocating PCI resources starting at 20000000 (gap: 14000000:ebff0000)
<4>Built 1 zonelists.  Total pages: 81278
<5>Kernel command line: initrd=initrd.img text lang=pl BOOT_IMAGE=vmlinuz
<6>Local APIC disabled by BIOS -- you can enable it with "lapic"
<7>mapped APIC to ffffd000 (0128a000)
<6>Enabling fast FPU save and restore... done.
<6>Enabling unmasked SIMD FPU exception support... done.
<6>Initializing CPU#0
<4>CPU 0 irqstacks, hard=c076e000 soft=c074e000
<4>PID hash table entries: 2048 (order: 11, 8192 bytes)
<4>Detected 501.144 MHz processor.
<4>Console: colour VGA+ 80x25
<4>Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<4>Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>Memory: 314324k/327668k available (2037k kernel code, 12752k reserved, 1069k data, 236k init, 0k highmem)
<4>virtual kernel memory layout:
<4>    fixmap  : 0xffc55000 - 0xfffff000   (3752 kB)
<4>    pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
<4>    vmalloc : 0xd4800000 - 0xff7fe000   ( 687 MB)
<4>    lowmem  : 0xc0000000 - 0xd3ffd000   ( 319 MB)
<4>      .init : 0xc070e000 - 0xc0749000   ( 236 kB)
<4>      .data : 0xc05fd722 - 0xc0708cb4   (1069 kB)
<4>      .text : 0xc0400000 - 0xc05fd722   (2037 kB)
<4>Checking if this processor honours the WP bit even in supervisor mode... Ok.
<4>Calibrating delay using timer specific routine.. 1002.90 BogoMIPS (lpj=501450)
<6>Security Framework v1.0.0 initialized
<6>SELinux:  Initializing.
<7>SELinux:  Starting in permissive mode
<6>selinux_register_security:  Registering secondary module capability
<6>Capability LSM initialized as secondary
<4>Mount-cache hash table entries: 512
<7>CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
<6>CPU: L1 I cache: 16K, L1 D cache: 16K
<6>CPU: L2 cache: 512K
<7>CPU: After all inits, caps: 0383f1ff 00000000 00000000 00000040 00000000 00000000 00000000
<6>Intel machine check architecture supported.
<6>Intel machine check reporting enabled on CPU#0.
<6>Checking 'hlt' instruction... OK.
<6>SMP alternatives: switching to UP code
<6>Freeing SMP alternatives: 13k freed
<6>ACPI: Core revision 20070126
<4>ACPI: setting ELCR to 0200 (from 0820)
<4>CPU0: Intel Pentium III (Katmai) stepping 03
<5>SMP motherboard not detected.
<5>Local APIC not detected. Using dummy APIC emulation.
<6>Brought up 1 CPUs
<7>sizeof(vma)=84 bytes
<7>sizeof(page)=32 bytes
<7>sizeof(inode)=336 bytes
<7>sizeof(dentry)=132 bytes
<7>sizeof(ext3inode)=488 bytes
<7>sizeof(buffer_head)=56 bytes
<7>sizeof(skbuff)=176 bytes
<7>sizeof(task_struct)=1376 bytes
<4>Time: 16:41:47  Date: 05/26/107
<6>NET: Registered protocol family 16
<6>ACPI: bus type pci registered
<6>PCI: PCI BIOS revision 2.10 entry at 0xf0710, last bus=1
<6>PCI: Using configuration type 1
<4>Setting up standard PCI resources
<6>ACPI: Interpreter enabled
<6>ACPI: (supports S0 S1 S4 S5)
<6>ACPI: Using PIC for interrupt routing
<6>ACPI: PCI Root Bridge [PCI0] (0000:00)
<7>PCI: Probing PCI hardware (bus 00)
<4>* Found PM-Timer Bug on the chipset. Due to workarounds for a bug,
<4>* this clock source is slow. Consider trying other clock sources
<4>PCI quirk: region e400-e43f claimed by PIIX4 ACPI
<4>PCI quirk: region e800-e80f claimed by PIIX4 SMB
<7>Boot video device is 0000:01:00.0
<7>ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
<4>ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
<4>ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
<4>ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
<4>ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
<6>Linux Plug and Play Support v0.97 ? Adam Belay
<6>pnp: PnP ACPI init
<6>pnp: PnP ACPI: found 13 devices
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>PCI: Using ACPI for IRQ routing
<6>PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
<6>NetLabel: Initializing
<6>NetLabel:  domain hash size = 128
<6>NetLabel:  protocols = UNLABELED CIPSOv4
<6>NetLabel:  unlabeled traffic allowed by default
<6>pnp: 00:00: iomem range 0x0-0x9ffff could not be reserved
<6>pnp: 00:00: iomem range 0xf0000-0xfffff could not be reserved
<6>pnp: 00:00: iomem range 0x100000-0x13ffffff could not be reserved
<6>pnp: 00:00: iomem range 0xfffe0000-0xffffffff could not be reserved
<6>pnp: 00:02: ioport range 0xe400-0xe43f has been reserved
<6>Time: tsc clocksource has been installed.
<6>pnp: 00:02: ioport range 0xe800-0xe80f has been reserved
<6>PCI: Bridge: 0000:00:01.0
<6>  IO window: disabled.
<6>  MEM window: d6000000-d7efffff
<6>  PREFETCH window: d7f00000-e3ffffff
<6>NET: Registered protocol family 2
<4>IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
<4>TCP established hash table entries: 16384 (order: 5, 196608 bytes)
<4>TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
<6>TCP: Hash tables configured (established 16384 bind 16384)
<6>TCP reno registered
<6>checking if image is initramfs...<6>Switched to high resolution mode on CPU 0
<4> it is
<6>Freeing initrd memory: 5541k freed
<6>Simple Boot Flag at 0x46 set to 0x1
<6>apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
<5>apm: overridden by ACPI.
<6>audit: initializing netlink socket (disabled)
<5>audit(1182876108.135:1): initialized
<4>Total HugeTLB memory allocated, 0
<5>VFS: Disk quotas dquot_6.5.1
<4>Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
<7>SELinux:  Registering netfilter hooks
<4>ksign: Installing public key data
<4>Loading keyring
<4>- Added public key C3680E46D35DB7E1
<4>- User ID: Red Hat, Inc. (Kernel Module GPG key)
<6>io scheduler noop registered
<6>io scheduler anticipatory registered
<6>io scheduler deadline registered
<6>io scheduler cfq registered (default)
<6>Limiting direct PCI/PCI transfers.
<6>ACPI: CPU0 (power states: C1[C1] C2[C2])
<6>isapnp: Scanning for PnP cards...
<6>pnp: SB audio device quirk - increasing port range
<6>isapnp: Card 'Creative ViBRA16C PnP'
<6>isapnp: Card 'FM Radio Tuner'
<6>isapnp: 2 Plug & Play cards detected total
<6>Real Time Clock Driver v1.12ac
<6>Non-volatile memory driver v1.2
<6>Linux agpgart interface v0.102 ? Dave Jones
<6>agpgart: Detected an Intel 440BX Chipset.
<6>agpgart: AGP aperture is 64M @ 0xe4000000
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
<6>Time: acpi_pm clocksource has been installed.
<6>serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
<6>serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
<6>00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
<6>00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
<4>RAMDISK driver initialized: 16 RAM disks of 16384K size 4096 blocksize
<6>input: Macintosh mouse button emulation as /class/input/input0
<6>usbcore: registered new interface driver libusual
<6>usbcore: registered new interface driver hiddev
<6>usbcore: registered new interface driver usbhid
<6>drivers/usb/input/hid-core.c: v2.6:USB HID core driver
<6>PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
<6>serio: i8042 KBD port at 0x60,0x64 irq 1
<6>serio: i8042 AUX port at 0x60,0x64 irq 12
<6>mice: PS/2 mouse device common for all mice
<6>input: AT Translated Set 2 keyboard as /class/input/input1
<6>TCP bic registered
<6>Initializing XFRM netlink socket
<6>NET: Registered protocol family 17
<4>Using IPI No-Shortcut mode
<4>  Magic number: 11:782:692
<4>drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
<6>Freeing unused kernel memory: 236k freed
<4>Write protecting the kernel read-only data: 803k
<6>input: ImExPS/2 Generic Explorer Mouse as /class/input/input2
<6>loop: loaded (max 8 devices)
<6>Floppy drive(s): fd0 is 1.44M
<6>FDC 0 is a post-1991 82077
<6>BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
<6>input: PC Speaker as /class/input/input3
<6>squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
<6>NET: Registered protocol family 10
<6>lo: Disabled Privacy Extensions
<6>Mobile IPv6
<5>SCSI subsystem initialized
<6>Loading iSCSI transport class v2.0-724.
<5>iscsi: registered transport (tcp)
<6>USB Universal Host Controller Interface driver v3.0
<4>ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
<7>PCI: setting IRQ 11 as level-triggered
<6>ACPI: PCI Interrupt 0000:00:07.2[D] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11
<6>;uhci_hcd 0000:00:07.2: UHCI Host Controller
<6>uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
<6>uhci_hcd 0000:00:07.2: irq 11, io base 0x0000a800
<6>usb usb1: configuration #1 chosen from 1 choice
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 2 ports detected
<6>ne2k-pci.c:v1.03 9/22/2003 D. Becker/P. Gortmaker
<6>  http://www.scyld.com/network/ne2k-pci.html
<4>ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
<7>PCI: setting IRQ 5 as level-triggered
<6>ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
<4>eth0: RealTek RTL-8029 found at 0xa400, IRQ 5, 00:C0:DF:EB:B0:2D.
<7>libata version 2.20 loaded.
<7>ata_piix 0000:00:07.1: version 2.10ac1
<6>ata1: PATA max UDMA/33 cmd 0x000101f0 ctl 0x000103f6 bmdma 0x0001b000 irq 14
<6>ata2: PATA max UDMA/33 cmd 0x00010170 ctl 0x00010376 bmdma 0x0001b008 irq 15
<6>scsi0 : ata_piix
<6>ata1.00: ata_hpa_resize 1: sectors = 78165360, hpa_sectors = 78165360
<6>ata1.00: ATA-6: ST340014A, 3.06, max UDMA/100
<6>ata1.00: 78165360 sectors, multi 16: LBA48
<6>ata1.00: configured for UDMA/33
<6>scsi1 : ata_piix
<4>ATA: abnormal status 0x7F on port 0x00010177
<6>ata2.01: ATAPI, max UDMA/33
<6>ata2.01: configured for UDMA/33
<5>scsi 0:0:0:0: Direct-Access     ATA      ST340014A        3.06 PQ: 0 ANSI: 5
<5>SCSI device sda: 78165360 512-byte hdwr sectors (40021 MB)
<5>sda: Write Protect is off
<7>sda: Mode Sense: 00 3a 00 00
<5>SCSI device sda: write cache: enabled, read cache: enabled, doesn't support DPO or FUA
<6> sda: sda1 sda2 < sda5 >
<5>sd 0:0:0:0: Attached scsi disk sda
<5>scsi 1:0:1:0: CD-ROM            _NEC     DVD_RW ND-3540A  1.01 PQ: 0 ANSI: 5
<4>sr0: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
<6>Uniform CD-ROM driver Revision: 3.20
<7>sr 1:0:1:0: Attached scsi CD-ROM sr0
<7>ISO 9660 Extensions: Microsoft Joliet Level 3
<4>Unable to load NLS charset utf8
<7>ISO 9660 Extensions: RRIP_1991A
<4>Unable to identify CD-ROM format.
<4>VFS: Can't find an ext2 filesystem on dev loop0.
<7>security:  3 users, 6 roles, 1816 types, 78 bools, 1 sens, 1024 cats
<7>security:  60 classes, 65638 rules
<7>SELinux:  Completing initialization.
<7>SELinux:  Setting up existing superblocks.
<7>SELinux: initialized (dev loop0, type squashfs), not configured for labeling
<7>SELinux: initialized (dev sr0, type iso9660), uses genfs_contexts
<7>SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts
<7>SELinux: initialized (dev ramfs, type ramfs), uses genfs_contexts
<7>SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
<7>SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
<7>SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
<7>SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
<7>SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses genfs_contexts
<7>SELinux: initialized (dev devpts, type devpts), uses transition SIDs
<7>SELinux: initialized (dev eventpollfs, type eventpollfs), uses task SIDs
<7>SELinux: initialized (dev inotifyfs, type inotifyfs), uses genfs_contexts
<7>SELinux: initialized (dev futexfs, type futexfs), uses genfs_contexts
<7>SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
<7>SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
<7>SELinux: initialized (dev cpuset, type cpuset), uses genfs_contexts
<7>SELinux: initialized (dev proc, type proc), uses genfs_contexts
<7>SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
<7>SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
<7>SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
<5>audit(1182876126.321:2): policy loaded auid=4294967295
<6>md: raid0 personality registered for level 0
<6>md: raid1 personality registered for level 1
<6>raid5: automatically using best checksumming function: pIII_sse
<4>   pIII_sse  :  1004.000 MB/sec
<4>raid5: using function: pIII_sse (1004.000 MB/sec)
<4>raid6: int32x1    109 MB/s
<4>raid6: int32x2    101 MB/s
<4>raid6: int32x4    128 MB/s
<4>raid6: int32x8    132 MB/s
<4>raid6: mmxx1      281 MB/s
<4>raid6: mmxx2      335 MB/s
<4>raid6: sse1x1     246 MB/s
<4>raid6: sse1x2     335 MB/s
<4>raid6: using algorithm sse1x2 (335 MB/s)
<6>md: raid6 personality registered for level 6
<6>md: raid5 personality registered for level 5
<6>md: raid4 personality registered for level 4
<6>md: raid10 personality registered for level 10
<4>GFS2 (built May 23 2007 22:13:32) installed
<6>Lock_Nolock (built May 23 2007 22:13:44) installed
<6>JFS: nTxBlock = 2502, nTxLock = 20020
<6>SGI XFS with ACLs, security attributes, large block numbers, no debug enabled
<6>SGI XFS Quota Management subsystem
<6>device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: [email protected]
<6>device-mapper: multipath: version 1.0.5 loaded
<6>device-mapper: multipath round-robin: version 1.0.0 loaded
<6>device-mapper: multipath emc: version 0.0.3 loaded
<5>audit(1182876144.818:3): audit_pid=571 old=0 by auid=4294967295 subj=system_u:system_r:anaconda_t:s0
<6>Adding 655352k swap on /dev/VolGroup00/LogVol01.  Priority:-1 extents:1 across:655352k
<6>kjournald starting.  Commit interval 5 seconds
<6>EXT3 FS on dm-0, internal journal
<6>EXT3-fs: mounted filesystem with ordered data mode.
<7>SELinux: initialized (dev dm-0, type ext3), uses xattr
<6>EXT3 FS on sda6, internal journal
<7>SELinux: initialized (dev sda6, type ext3), uses xattr
/tmp/anaconda.log:
16:41:50 INFO    : kernel command line: initrd=initrd.img text lang=pl BOOT_IMAGE=vmlinuz
16:41:50 INFO    : text mode forced from cmdline
16:41:50 INFO    : 320324 kB are available
16:41:50 INFO    : modules to insert cramfs fat vfat sunrpc lockd nfs_acl nfs loop isofs floppy edd pcspkr squashfs jbd mbcache ext3 ext2
16:41:50 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:41:51 INFO    : loaded cramfs from /modules/modules.cgz
16:41:51 INFO    : loaded fat from /modules/modules.cgz
16:41:51 INFO    : loaded vfat from /modules/modules.cgz
16:41:51 INFO    : loaded sunrpc from /modules/modules.cgz
16:41:51 INFO    : loaded lockd from /modules/modules.cgz
16:41:51 INFO    : loaded nfs_acl from /modules/modules.cgz
16:41:51 INFO    : loaded nfs from /modules/modules.cgz
16:41:51 INFO    : loaded loop from /modules/modules.cgz
16:41:51 INFO    : loaded floppy from /modules/modules.cgz
16:41:51 INFO    : loaded edd from /modules/modules.cgz
16:41:51 INFO    : loaded pcspkr from /modules/modules.cgz
16:41:51 INFO    : loaded squashfs from /modules/modules.cgz
16:41:51 INFO    : loaded jbd from /modules/modules.cgz
16:41:51 INFO    : loaded mbcache from /modules/modules.cgz
16:41:51 INFO    : loaded ext3 from /modules/modules.cgz
16:41:51 INFO    : loaded ext2 from /modules/modules.cgz
16:41:51 DEBUG   : module(s) isofs not found
16:41:51 INFO    : inserted /tmp/cramfs.ko
16:41:51 INFO    : inserted /tmp/fat.ko
16:41:51 INFO    : inserted /tmp/vfat.ko
16:41:51 INFO    : inserted /tmp/sunrpc.ko
16:41:51 INFO    : inserted /tmp/lockd.ko
16:41:51 INFO    : inserted /tmp/nfs_acl.ko
16:41:51 INFO    : inserted /tmp/nfs.ko
16:41:51 INFO    : inserted /tmp/loop.ko
16:41:51 INFO    : inserted /tmp/floppy.ko
16:41:51 INFO    : inserted /tmp/edd.ko
16:41:51 INFO    : inserted /tmp/pcspkr.ko
16:41:51 INFO    : inserted /tmp/squashfs.ko
16:41:51 INFO    : inserted /tmp/jbd.ko
16:41:51 INFO    : inserted /tmp/mbcache.ko
16:41:51 INFO    : inserted /tmp/ext3.ko
16:41:51 INFO    : inserted /tmp/ext2.ko
16:41:51 INFO    : load module set done
16:41:51 INFO    : modules to insert ipv6
16:41:51 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:41:52 INFO    : loaded ipv6 from /modules/modules.cgz
16:41:52 INFO    : inserted /tmp/ipv6.ko
16:41:52 INFO    : load module set done
16:41:52 INFO    : modules to insert cdrom ide-cd
16:41:52 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:41:52 INFO    : loaded cdrom from /modules/modules.cgz
16:41:52 DEBUG   : module(s) ide-cd not found
16:41:53 INFO    : inserted /tmp/cdrom.ko
16:41:53 INFO    : load module set done
16:41:53 INFO    : modules to insert scsi_mod sd_mod sr_mod
16:41:53 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:41:53 INFO    : loaded scsi_mod from /modules/modules.cgz
16:41:53 INFO    : loaded sd_mod from /modules/modules.cgz
16:41:53 INFO    : loaded sr_mod from /modules/modules.cgz
16:41:53 INFO    : inserted /tmp/scsi_mod.ko
16:41:53 INFO    : inserted /tmp/sd_mod.ko
16:41:53 INFO    : inserted /tmp/sr_mod.ko
16:41:53 INFO    : modules to insert scsi_transport_iscsi libiscsi iscsi_tcp
16:41:54 INFO    : loaded scsi_transport_iscsi from /modules/modules.cgz
16:41:54 INFO    : loaded libiscsi from /modules/modules.cgz
16:41:54 INFO    : loaded iscsi_tcp from /modules/modules.cgz
16:41:54 INFO    : inserted /tmp/scsi_transport_iscsi.ko
16:41:54 INFO    : inserted /tmp/libiscsi.ko
16:41:54 INFO    : inserted /tmp/iscsi_tcp.ko
16:41:54 INFO    : load module set done
16:41:54 INFO    : looking for usb controllers
16:41:54 INFO    : found USB controller uhci-hcd
16:41:54 INFO    : modules to insert uhci-hcd
16:41:54 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:41:55 INFO    : loaded uhci-hcd from /modules/modules.cgz
16:41:55 INFO    : inserted /tmp/uhci-hcd.ko
16:41:55 INFO    : load module set done
16:41:55 DEBUG   : waiting for usb to become stable...
16:41:57 DEBUG   : 2 seconds.
16:41:57 INFO    : modules to insert hid keybdev
16:41:57 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:41:57 DEBUG   : module(s) hid keybdev not found
16:41:57 INFO    : load module set done
16:41:58 INFO    : no firewire controller found
16:41:58 DEBUG   : going to set language to pl_PL.UTF-8
16:41:58 INFO    : setting language to pl_PL.UTF-8
16:41:59 DEBUG   : no pcic controller found
16:41:59 DEBUG   : probing buses
16:41:59 DEBUG   : finished bus probing
16:41:59 DEBUG   : ignoring driverless device Intel Corporation Unknown device 7113
16:41:59 DEBUG   : ignoring driverless device Intel Corporation Unknown device 7110
16:41:59 DEBUG   : ignoring driverless device Intel Corporation Unknown device 7191
16:41:59 DEBUG   : ignoring driverless device Intel Corporation Unknown device 7190
16:41:59 DEBUG   : ignoring driverless device Unknown device 125d:1969
16:41:59 DEBUG   : ignoring driverless device nVidia Corporation NV11DDR [GeForce2 MX200]
16:41:59 INFO    : modules to insert 8390 ne2k-pci libata ata_piix
16:41:59 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:41:59 INFO    : loaded 8390 from /modules/modules.cgz
16:41:59 INFO    : loaded ne2k-pci from /modules/modules.cgz
16:41:59 INFO    : loaded libata from /modules/modules.cgz
16:41:59 INFO    : loaded ata_piix from /modules/modules.cgz
16:41:59 INFO    : inserted /tmp/8390.ko
16:41:59 INFO    : inserted /tmp/ne2k-pci.ko
16:41:59 INFO    : inserted /tmp/libata.ko
16:42:01 INFO    : inserted /tmp/ata_piix.ko
16:42:01 INFO    : load module set done
16:42:01 INFO    : trying to mount CD device scd0
16:42:03 INFO    : mntloop loop0 on /mnt/runtime as /mnt/source/images/stage2.img fd is 10
16:42:03 DEBUG   : MD5SUM -> 7a4291b37912cbf1df08306507095821
16:42:03 DEBUG   : skipsectors = 15
16:42:03 INFO    : supported = 0
16:42:04 INFO    : Loading SELinux policy
16:42:06 INFO    : getting ready to spawn shell now
16:42:06 INFO    : modules to insert ide-cd
16:42:06 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:42:07 DEBUG   : module(s) ide-cd not found
16:42:07 INFO    : load module set done
16:42:07 INFO    : modules to insert
16:42:07 DEBUG   : getModuleLocation: 2.6.21-1.3194.fc7/i586
16:42:07 DEBUG   : probing buses
16:42:07 DEBUG   : finished bus probing
16:42:07 DEBUG   : ignoring driverless device Intel Corporation 82371AB/EB/MB PIIX4 ACPI
16:42:07 DEBUG   : ignoring driverless device Intel Corporation 82371AB/EB/MB PIIX4 ISA
16:42:07 DEBUG   : ignoring driverless device Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge
16:42:07 DEBUG   : ignoring driverless device Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge
16:42:07 DEBUG   : ignoring driverless device ESS Technology ES1969 Solo-1 Audiodrive
16:42:07 DEBUG   : ignoring driverless device nVidia Corporation NV11DDR [GeForce2 MX200]
16:42:07 INFO    : modules to insert md raid0 raid1 raid5 raid6 xor raid456 raid10 msdos gfs2 lock_nolock reiserfs jfs xfs dm-mod dm-zero dm-mirror dm-snapshot dm-multipath dm-round-robin dm-emc
16:42:08 INFO    : loaded raid0 from /modules/modules.cgz
16:42:08 INFO    : loaded raid1 from /modules/modules.cgz
16:42:08 INFO    : loaded xor from /modules/modules.cgz
16:42:08 INFO    : loaded raid456 from /modules/modules.cgz
16:42:08 INFO    : loaded raid10 from /modules/modules.cgz
16:42:08 INFO    : loaded msdos from /modules/modules.cgz
16:42:08 INFO    : loaded gfs2 from /modules/modules.cgz
16:42:08 INFO    : loaded lock_nolock from /modules/modules.cgz
16:42:08 INFO    : loaded reiserfs from /modules/modules.cgz
16:42:08 INFO    : loaded jfs from /modules/modules.cgz
16:42:08 INFO    : loaded xfs from /modules/modules.cgz
16:42:08 INFO    : loaded dm-mod from /modules/modules.cgz
16:42:08 INFO    : loaded dm-zero from /modules/modules.cgz
16:42:08 INFO    : loaded dm-mirror from /modules/modules.cgz
16:42:08 INFO    : loaded dm-snapshot from /modules/modules.cgz
16:42:08 INFO    : loaded dm-multipath from /modules/modules.cgz
16:42:08 INFO    : loaded dm-round-robin from /modules/modules.cgz
16:42:08 INFO    : loaded dm-emc from /modules/modules.cgz
16:42:08 DEBUG   : module(s) md raid5 raid6 not found
16:42:08 INFO    : inserted /tmp/raid0.ko
16:42:08 INFO    : inserted /tmp/raid1.ko
16:42:08 INFO    : inserted /tmp/xor.ko
16:42:08 INFO    : inserted /tmp/raid456.ko
16:42:08 INFO    : inserted /tmp/raid10.ko
16:42:08 INFO    : inserted /tmp/msdos.ko
16:42:08 INFO    : inserted /tmp/gfs2.ko
16:42:08 INFO    : inserted /tmp/lock_nolock.ko
16:42:08 INFO    : inserted /tmp/reiserfs.ko
16:42:08 INFO    : inserted /tmp/jfs.ko
16:42:08 INFO    : inserted /tmp/xfs.ko
16:42:08 INFO    : inserted /tmp/dm-mod.ko
16:42:08 INFO    : inserted /tmp/dm-zero.ko
16:42:08 INFO    : inserted /tmp/dm-mirror.ko
16:42:08 INFO    : inserted /tmp/dm-snapshot.ko
16:42:08 INFO    : inserted /tmp/dm-multipath.ko
16:42:08 INFO    : inserted /tmp/dm-round-robin.ko
16:42:09 INFO    : inserted /tmp/dm-emc.ko
16:42:09 INFO    : load module set done
16:42:09 INFO    : looking for USB mouse...
16:42:09 INFO    : Running anaconda script /usr/bin/anaconda
16:42:25 INFO    : using only installclass _Fedora
16:42:26 INFO    : anaconda called with cmdline = ['/usr/bin/anaconda', '-m', 'cdrom://scd0:/mnt/source', '-T', '--selinux', '--lang', 'pl']
16:42:26 INFO    : Display mode = t
16:42:26 INFO    : Method = cdrom://scd0:/mnt/source
16:42:35 INFO    : anaconda floppy device fd0
16:42:39 INFO    : Detected 320M of memory
16:42:39 INFO    : Swap attempt of 320M to 640M
16:42:39 WARNING : step installtype does not exist
16:42:39 WARNING : step complete does not exist
16:42:39 INFO    : moving (1) to step welcome
16:42:41 INFO    : moving (1) to step keyboard
16:42:46 INFO    : moving (1) to step findrootparts
16:42:46 DEBUG   : starting mpaths
16:42:46 DEBUG   : self.driveList(): ['sda']
16:42:46 DEBUG   : DiskSet.skippedDisks: []
16:42:46 DEBUG   : starting all mpaths on drives ['sda']
16:42:46 DEBUG   : scanning for multipath on drives ['sda']
16:42:46 DEBUG   : mpaths: []
16:42:46 DEBUG   : done starting mpaths.  Drivelist: ['sda']
16:42:46 DEBUG   : starting dmraids
16:42:46 DEBUG   : starting all dmraids on drives ['sda']
16:42:46 DEBUG   : scanning for dmraid on drives ['sda']
16:42:46 DEBUG   : done starting dmraids.  Drivelist: ['sda']
16:42:48 WARNING : step complete does not exist
16:42:48 INFO    : moving (1) to step partitionobjinit
16:42:48 INFO    : no initiator set
16:42:48 INFO    : no /tmp/fcpconfig; not configuring zfcp
16:42:49 DEBUG   : error reading jfs label on /tmp/disk: [Errno 22] Zły argument
16:42:49 DEBUG   : error reading reiserfs label on /tmp/disk: [Errno 22] Zły argument
16:42:50 INFO    : moving (1) to step parttype
16:43:03 INFO    : moving (1) to step autopartitionexecute
16:43:03 DEBUG   : used space is 1344
16:43:03 DEBUG   : actual space is 10016
16:43:03 DEBUG   : used space is 7936
16:43:03 DEBUG   : used space is 8256
16:43:03 DEBUG   : used space is 10016
16:43:03 INFO    : moving (1) to step partition
16:43:55 INFO    : moving (1) to step partitiondone
16:43:55 INFO    : moving (1) to step bootloadersetup
16:44:45 INFO    : moving (1) to step bootloaderadvanced
16:45:57 INFO    : moving (1) to step networkdevicecheck
16:48:15 INFO    : moving (1) to step timezone
16:48:26 INFO    : moving (1) to step accounts
16:48:43 INFO    : moving (1) to step reposetup
16:48:49 CRITICAL: No Repositories Available to Set Up
16:48:49 INFO    : switching from CD [1] to 1 for
16:48:56 INFO    : moving (1) to step basepkgsel
16:49:06 INFO    : moving (1) to step tasksel
16:49:20 INFO    : moving (1) to step group-selection
16:51:24 DEBUG   : No package named alsamixergui available to be installed: No package(s) available to install
16:51:56 DEBUG   : No package named Zim available to be installed: No package(s) available to install
16:53:41 DEBUG   : No package named xchat-gnome available to be installed: No package(s) available to install
16:53:41 DEBUG   : No package named azureus available to be installed: No package(s) available to install
16:53:41 DEBUG   : No package named kadu available to be installed: No package(s) available to install
16:53:41 DEBUG   : No package named xchat available to be installed: No package(s) available to install
16:54:21 DEBUG   : No package named fontforge available to be installed: No package(s) available to install
16:55:12 DEBUG   : No package named arrows available to be installed: No package(s) available to install
16:55:12 DEBUG   : No package named abe available to be installed: No package(s) available to install
16:55:12 DEBUG   : No package named gnome-sudoku available to be installed: No package(s) available to install
16:56:00 DEBUG   : No package named atlas available to be installed: No package(s) available to install
16:56:00 DEBUG   : No package named genius available to be installed: No package(s) available to install
16:56:00 DEBUG   : No package named geomview available to be installed: No package(s) available to install
16:56:00 DEBUG   : No package named galculator available to be installed: No package(s) available to install
16:57:03 DEBUG   : No package named WindowMaker available to be installed: No package(s) available to install
16:57:03 DEBUG   : No package named fluxconf available to be installed: No package(s) available to install
16:57:03 DEBUG   : No package named fluxbox available to be installed: No package(s) available to install
16:57:31 DEBUG   : No package named yumex available to be installed: No package(s) available to install
16:58:16 DEBUG   : No package named xfce4-dev-tools available to be installed: No package(s) available to install
17:00:17 DEBUG   : No package named childsplay available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-weather-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named Terminal available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-quicklauncher-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-websearch-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-sensors-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named mousepad available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-dict-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-icon-theme available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-mailwatch-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-smartbookmark-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-verve-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-battery-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-timer-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-datetime-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-systemload-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce-mcs-plugins available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-notes-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-xkb-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-xfapplet-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-screenshooter-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-mixer available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-fsguard-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-genmon-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-wavelan-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-taskmanager available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-places-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-netload-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfwm4-themes available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfprint available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-cpugraph-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-xmms-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-mount-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xarchiver available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-eyes-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named thunar-volman available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named thunar-media-tags-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-clipman-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce-mcs-manager available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-minicmd-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-appfinder available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named xfce4-diskperf-plugin available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named orage available to be installed: No package(s) available to install
17:01:47 DEBUG   : No package named thunar-archive-plugin available to be installed: No package(s) available to install
17:02:16 INFO    : moving (1) to step postselection
17:02:16 INFO    : selected kernel package for kernel
17:11:13 INFO    : moving (1) to step confirminstall
17:11:33 INFO    : moving (1) to step install
17:11:33 INFO    : moving (1) to step enablefilesystems
17:11:34 INFO    : disk.commit() for /dev/sda
17:11:44 INFO    : formatting swap as swap
17:11:44 INFO    : formatting / as ext3
17:11:44 INFO    : Format command:  ['mke2fs', '/dev/VolGroup00/LogVol00', '-i', '4096', '-j']
17:12:12 INFO    : formatting /boot as ext3
17:12:12 INFO    : Format command:  ['mke2fs', '/tmp/sda6', '-i', '4096', '-j']
17:12:14 DEBUG   : error reading jfs label on /tmp/disk: [Errno 22] Zły argument
17:12:14 DEBUG   : error reading reiserfs label on /tmp/disk: [Errno 22] Zły argument
17:12:15 INFO    : lv VolGroup00/LogVol00, attr is -wi-a-
17:12:16 INFO    : lv is VolGroup00/LogVol00, size of 9376
17:12:16 INFO    : lv is VolGroup00/LogVol01, size of 640
17:12:18 DEBUG   : error reading swap label on /dev/VolGroup00: [Errno 21] Jest katalogiem
17:12:18 DEBUG   : error reading xfs label on /dev/VolGroup00: [Errno 21] Jest katalogiem
17:12:18 DEBUG   : error reading jfs label on /dev/VolGroup00: [Errno 21] Jest katalogiem
17:12:18 DEBUG   : error reading reiserfs label on /dev/VolGroup00: [Errno 21] Jest katalogiem
17:12:18 INFO    : trying to mount VolGroup00/LogVol00 on /
17:12:18 INFO    : set SELinux context for mountpoint / to system_u:object_r:root_t:s0
17:12:18 DEBUG   : isys.py:mount()- going to mount /dev/VolGroup00/LogVol00 on /mnt/sysimage
17:12:18 INFO    : trying to mount sda6 on /boot
17:12:18 INFO    : set SELinux context for mountpoint /boot to system_u:object_r:boot_t:s0
17:12:18 DEBUG   : isys.py:mount()- going to mount /tmp/sda6 on /mnt/sysimage/boot
17:12:18 INFO    : trying to mount sys on /sys
17:12:18 INFO    : set SELinux context for mountpoint /sys to None
17:12:18 DEBUG   : isys.py:mount()- going to mount sys on /mnt/sysimage/sys
17:12:18 INFO    : trying to mount proc on /proc
17:12:18 INFO    : set SELinux context for mountpoint /proc to None
17:12:18 DEBUG   : isys.py:mount()- going to mount proc on /mnt/sysimage/proc
17:12:19 INFO    : moving (1) to step migratefilesystems
17:12:19 INFO    : moving (1) to step setuptime
19:12:21 INFO    : moving (1) to step preinstallconfig
19:12:30 DEBUG   : isys.py:mount()- going to mount /selinux on /mnt/sysimage/selinux
19:12:30 WARNING : no dev package, going to bind mount /dev
19:12:30 DEBUG   : isys.py:mount()- going to mount /dev on /mnt/sysimage/dev
19:12:30 INFO    : self.hostname = Fx
19:12:30 INFO    : moving (1) to step installpackages
19:12:30 INFO    : Preparing to install packages
/tmp/lvmout:
   Finding all logical volumes
/mnt/sysimage/root/install.log:
Instalowanie libgcc - 4.1.2-12.i386
warning: libgcc-4.1.2-12: Header V3 DSA signature: NOKEY, key ID 4f2a6fd2
Instalowanie setup - 2.6.4-1.fc7.noarch
PLZ help!
//===== edit =====
Poprawione tagi - exbros
Zacznijmy od tego: dlugie listingi (powyzej 15 linijek) nalezy umieszczac w znacznikach [c o d e b o x] & [/ c o d e b o x] a nie [c o d e] & [/ c o d e] czy [q u o t e] & [/q u o t e].
Teraz zasadnicze pytanie: sprawdziles plytke (skorzystales z opcji mediacheck na poczatku instalacji)?
Cos mi sie wydaje ze nie marnowales na to czasu, a teraz liczysz na to ze ktos przejrzy kod yuminstall.py, poszuka linijki nr 159, pozniej kilkuset innych linijek w innych pliczkach by w koncu powiedziec Ci co sie popsulo ;)
Sprawdz nagrany nosnik. Jesli sie okaze ze jest w 100% O.K. - wtedy mozna szukac innej przyczyny...
Powodzenia
Płyta jest w 100% sprawna, BTW właśnie zainstalowałem Fedore w trybie graficznym poszła bez problemu tyl, że miała o wiele mniej pakietów w trybie graficznym niż w tekstowym (chyba chciało mi się intalować z innego źródła) system śmiga a nic nie konfigurowałem, co prawda teraz rozdzielczość wynosi 640x480 ;p
Płyta jest w 100% sprawna, BTW właśnie zainstalowałem Fedore w trybie graficznym poszła bez problemu...
A! To trzeba bylo od razu zaznaczyc ze tamta proba instalacji byla w trybie tekstowym... to juz kolejny podobny przypadek wykladania sie tekstowej instalki o ktorym slysze, zdaje sie ze cos tam pozostalo niedopracowane :(
Skoro juz masz dzialajacy w trybie graficznym system, to z rozdzielczoscia i cala reszta juz sobie na pewno poradzisz ;)
Google i Szukajka na forum powinny byc bardzo pomocne. W przypadku problemow nie do rozwiazania zakladaj nowe watki.
Powodzenia w oswajaniu Fedory
