Zzzminaa Hasla Do Samba Przez Www
adams24
Postanowilem ulatwic zycie userom i udostepnic im skrypt do zmiany hasla przez www.
Pobrac go mozna z tej strony
Instalacja przebiega wporzadku ale tylko przy skonfigurowanym jezyku domyslnym czyli angielskim.
Po ustawieniu jezyka na polski wywala taki blad:
[root@dom changepassword-0.9]# make
gcc -c -o smbencrypt/SMBPasswdGen.o  smbencrypt/SMBPasswdGen.c
gcc -c -o smbencrypt/encrypt.o	   smbencrypt/encrypt.c
gcc -c -o smbencrypt/md4.o		   smbencrypt/md4.c
gcc -c -o smbencrypt/smbencrypt.o	smbencrypt/smbencrypt.c
gcc changepassword.c -o changepassword.cgi smbencrypt/SMBPasswdGen.o smbencrypt/md4.o smbencrypt/smbencrypt.o smbencrypt/encrypt.o -lcrypt -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DHAVE_LIBCRYPT=1 -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_STDIO_H=1 -DHAVE_STRING_H=1 -DHAVE_STDLIB_H=1 -DHAVE_PWD_H=1 -DHAVE_ERRNO_H=1 -DHAVE_SIGNAL_H=1 -DHAVE_SHADOW_H=1 -DHAVE_TIME_H=1  -Dpolish -DSMBPASSWD=\"/etc/samba\" -DSQUIDPASSWD=\"no\" -DLOGO=\"none\" -L./smbencrypt -ldes
changepassword.c: In function ‘main’:
changepassword.c:100: error: ‘msg25’ undeclared (first use in this function)
changepassword.c:100: error: (Each undeclared identifier is reported only once
changepassword.c:100: error: for each function it appears in.)
changepassword.c:100: error: ‘msg15’ undeclared (first use in this function)
changepassword.c:101: error: ‘msg27’ undeclared (first use in this function)
changepassword.c:159: error: ‘msg07’ undeclared (first use in this function)
changepassword.c:159: error: ‘msg08’ undeclared (first use in this function)
changepassword.c:165: error: ‘msg26’ undeclared (first use in this function)
changepassword.c:183: error: ‘msg09’ undeclared (first use in this function)
changepassword.c:198: error: ‘msg10’ undeclared (first use in this function)
changepassword.c:201: error: ‘msg11’ undeclared (first use in this function)
changepassword.c:207: error: ‘msg12’ undeclared (first use in this function)
changepassword.c:210: error: ‘msg13’ undeclared (first use in this function)
changepassword.c:221: error: ‘msg14’ undeclared (first use in this function)
changepassword.c:280: error: ‘msg16’ undeclared (first use in this function)
changepassword.c:286: error: ‘msg17’ undeclared (first use in this function)
changepassword.c:293: error: ‘msg18’ undeclared (first use in this function)
changepassword.c:293: error: ‘msg19’ undeclared (first use in this function)
changepassword.c:299: error: ‘msg20’ undeclared (first use in this function)
changepassword.c:307: error: ‘msg21’ undeclared (first use in this function)
changepassword.c:317: error: ‘msg24’ undeclared (first use in this function)
changepassword.c: In function ‘htmlheader’:
changepassword.c:369: error: ‘msg01’ undeclared (first use in this function)
changepassword.c:369: error: ‘charset’ undeclared (first use in this function)
changepassword.c: In function ‘showform’:
changepassword.c:394: error: ‘msg01’ undeclared (first use in this function)
changepassword.c:394: error: ‘msg02’ undeclared (first use in this function)
changepassword.c:396: error: ‘msg03’ undeclared (first use in this function)
changepassword.c:397: error: ‘msg04’ undeclared (first use in this function)
changepassword.c:398: error: ‘msg05’ undeclared (first use in this function)
changepassword.c:399: error: ‘msg06’ undeclared (first use in this function)
changepassword.c: In function ‘changesmbpass’:
changepassword.c:433: error: ‘msg14’ undeclared (first use in this function)
changepassword.c:433: error: ‘msg15’ undeclared (first use in this function)
changepassword.c:433: error: ‘msg08’ undeclared (first use in this function)
changepassword.c:439: error: ‘msg25’ undeclared (first use in this function)
changepassword.c:534: error: ‘msg18’ undeclared (first use in this function)
changepassword.c:534: error: ‘msg19’ undeclared (first use in this function)
changepassword.c:540: error: ‘msg20’ undeclared (first use in this function)
changepassword.c:545: error: ‘msg23’ undeclared (first use in this function)
changepassword.c: In function ‘changesquidpass’:
changepassword.c:575: error: ‘msg14’ undeclared (first use in this function)
changepassword.c:575: error: ‘msg15’ undeclared (first use in this function)
changepassword.c:575: error: ‘msg08’ undeclared (first use in this function)
changepassword.c:581: error: ‘msg27’ undeclared (first use in this function)
changepassword.c:647: error: ‘msg28’ undeclared (first use in this function)
changepassword.c:647: error: ‘msg29’ undeclared (first use in this function)
changepassword.c:653: error: ‘msg30’ undeclared (first use in this function)
changepassword.c:658: error: ‘msg31’ undeclared (first use in this function)
make: *** [changepassword.cgi] Błąd 1
w dodatku chaslo moze zmienic tylko i wylacznie user ktory nie ma zablokowanego dostepu do shella. Ale to chyba tak stworzony skrypt?? Bede musial pomyslec nad tym zeby miec wlaczone konto shellowe a minium uprawnien zeby mieli userzy.
Czy mozecie jakos pomoc co z tym bledem zrobic ???/////////// nie wiem o co chodzi :|
Do dłuższych listingów stosujemy codebox, a nie code /Karlik
