adams24 Napisano Sierpień 3, 2007 Zgłoszenie Share Napisano Sierpień 3, 2007 Jul 20 04:27:22 serwer-ug sshd[2912]: pam_succeed_if(sshd:auth): error retrieving information about user playboy Jul 20 04:27:24 serwer-ug sshd[2912]: Failed password for invalid user playboy from 61.145.119.180 port 52413 ssh2 Jul 20 04:27:24 serwer-ug sshd[2913]: Received disconnect from 61.145.119.180: 11: Bye Bye Jul 20 04:27:27 serwer-ug sshd[2914]: Invalid user hotmail from 61.145.119.180 Jul 20 04:27:27 serwer-ug sshd[2915]: input_userauth_request: invalid user hotmail Jul 20 04:27:27 serwer-ug sshd[2914]: pam_unix(sshd:auth): check pass; user unknown Jul 20 04:27:27 serwer-ug sshd[2914]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.145.119.180 Jul 20 04:27:27 serwer-ug sshd[2914]: pam_succeed_if(sshd:auth): error retrieving information about user hotmail Jul 20 04:27:29 serwer-ug sshd[2914]: Failed password for invalid user hotmail from 61.145.119.180 port 53962 ssh2 Jul 20 04:27:30 serwer-ug sshd[2915]: Received disconnect from 61.145.119.180: 11: Bye Bye Jul 20 04:27:34 serwer-ug sshd[2916]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.145.119.180 user=mail Jul 20 04:27:36 serwer-ug sshd[2916]: Failed password for mail from 61.145.119.180 port 55136 ssh2 Jul 20 04:27:36 serwer-ug sshd[2917]: Received disconnect from 61.145.119.180: 11: Bye Bye Jul 20 04:27:40 serwer-ug sshd[2920]: Invalid user hotline from 61.145.119.180 Jul 20 04:27:40 serwer-ug sshd[2922]: input_userauth_request: invalid user hotline Jul 20 04:27:40 serwer-ug sshd[2920]: pam_unix(sshd:auth): check pass; user unknown Jul 20 04:27:40 serwer-ug sshd[2920]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.145.119.180 Jul 20 04:27:40 serwer-ug sshd[2920]: pam_succeed_if(sshd:auth): error retrieving information about user hotline Jul 20 04:27:41 serwer-ug sshd[2920]: Failed password for invalid user hotline from 61.145.119.180 port 56410 ssh2 Jul 20 04:27:42 serwer-ug sshd[2922]: Received disconnect from 61.145.119.180: 11: Bye Bye Jul 20 04:27:44 serwer-ug sshd[2923]: Invalid user sex from 61.145.119.180 Jul 20 04:27:44 serwer-ug sshd[2924]: input_userauth_request: invalid user sex Jul 20 04:27:44 serwer-ug sshd[2923]: pam_unix(sshd:auth): check pass; user unknown Jul 20 04:27:44 serwer-ug sshd[2923]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.145.119.180 Jul 20 04:27:45 serwer-ug sshd[2923]: pam_succeed_if(sshd:auth): error retrieving information about user sex Jul 20 04:27:46 serwer-ug sshd[2923]: Failed password for invalid user sex from 61.145.119.180 port 57617 ssh2 Jul 20 04:27:47 serwer-ug sshd[2924]: Received disconnect from 61.145.119.180: 11: Bye Bye Jul 20 04:27:50 serwer-ug sshd[2925]: Invalid user sesso from 61.145.119.180 Jul 20 04:27:50 serwer-ug sshd[2926]: input_userauth_request: invalid user sesso Jul 20 04:27:50 serwer-ug sshd[2925]: pam_unix(sshd:auth): check pass; user unknown Jul 20 04:27:50 serwer-ug sshd[2925]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.145.119.180 Widze ze nieustannie ktos probuje sie dobic na moj serwer. N szczescie serwer ten nie jest stale udostepniony w internecie, to jest czesc logow z jednego dnia kiedy przekierowalem porty na ten serwer. Co doradzacie??? Czy zmaina portu na ktorym dziala ssh pomoga, czy to jest (_wogole_ → w ogóle) ORT samobojstwo udostepniac ssh na zewnatrz??? Na ruterze (Ipcop) za ktorym stoi ten serwer standardowo wylanaczam przekierowanie na port ssh po zakonczeniu pracy. Przy dłuższych listingach proszę stosować codebox zamiast code /Karlik Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Sierpień 5, 2007 Zgłoszenie Share Napisano Sierpień 5, 2007 Jest kilka podstawowych rzeczy (stosowanych powszechnie), które trzeba zrobić, aby ograniczyć dostęp do Twojego serwera z zewnątrz: - skonfiguruj zaporę sieciową iptables (ruch na porcie ssh powinien być tylko z określonej puli adresów) - jest to warstwa najbliżej jądra i jest najbardziej skuteczna - skonfiguruj hosts.allow i hosts.deny (w hosts.allow dopusc pule adresów, w hosts.deny zablokuj wszystko inne) - jest to warstwa aplikacji sieciowych - m.in. ssh (czyli uzupełnienie powyższego zabezpieczenia) - wyłącz dostęp do logowania się na użytkownika root z zewnątrz za pomoca ssh (/etc/ssh/sshd_config) - dostęp do roota pownien być dozwolony tylko z innego konta w systemie - napastnik musiałby najpier zalogować się na jakiegoś użytkownika, aby potem móc zalogować się na roota - wyłącz możliwośc wykonania lokalnego ssh na maszynie - w przypadku exploitów ssh napastnik będzie miał utrudnienie Dodatkowe strony (pamiętaj google Twoim przyjacielem ): http://www.debianusers.pl/article.php?aid=71 http://www.ssh.com/support/documentation/o...rs_Support.html http://www.eioba.pl/a71411/pliki_hosts_allow_oraz_hosts_deny Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
adams24 Napisano Sierpień 6, 2007 Autor Zgłoszenie Share Napisano Sierpień 6, 2007 Wiem że google moim przyjacielem. Poszukałem poczytałem teraz trzeba się (_wziąść_ → wziąć) ORT do roboty. Al dzieki za podpowiedź utwierdziłeś mnie perl w moich przekonaniach. Zawsze dobrze jest poznać zdanie zawansowanych adminów. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Arabski Napisano Grudzień 5, 2007 Zgłoszenie Share Napisano Grudzień 5, 2007 Możesz "przesunąć" ssh na wysoki port. U siebie tak mam i logi są czyste. p.s. Teraz doczytałem - żadne samobójstwo. Większość skanów to automaty szukające na standardowych portach. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
MonteChristo Napisano Grudzień 28, 2007 Zgłoszenie Share Napisano Grudzień 28, 2007 fail2ban -> banalny program, ktory spokojnie poradzi sobie z tym co masz. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Grudzień 31, 2007 Zgłoszenie Share Napisano Grudzień 31, 2007 fail2ban -> banalny program, ktory spokojnie poradzi sobie z tym co masz. testowałeś to? ja do automatów nigdy nie miałem przekonania, ale po zasadzie działania to rzeczywiście proste i w 95% skuteczne rozwiązanie, Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
MonteChristo Napisano Styczeń 6, 2008 Zgłoszenie Share Napisano Styczeń 6, 2008 testowalem ! dziala wysmienicie....dlatego polecam. To jeden z lepszych automatow.... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
