flameheart Napisano Wrzesień 9, 2007 Zgłoszenie Share Napisano Wrzesień 9, 2007 Wczoraj postanowilem zainstalowac sobie Compiza-Fusion ale po ~12h restartow iksow stwierdzilem ze sie poddaje Problem jest od poczatku ten sam: jak odpalam CF'a dostaje komunikat: [yiedhia@yiebusia ~]$ fusion-icon * Using the GTK Interface * Searching for installed applications... /usr/bin/ccsm /usr/bin/compiz /usr/bin/gtk-window-decorator /usr/bin/emerald /usr/bin/metacity * gnome session * Executing: compiz --replace --sm-disable --ignore-desktop-hints ccp compiz (core) - Fatal: GLX_EXT_texture_from_pixmap is missing compiz (core) - Error: Failed to manage screen: 0 compiz (core) - Fatal: No manageable screens found on display :0.0 Okna zostaja bez paskow tytulowych i obramowan, jedyne wyjscie to ctrl+C ; metacity &. Na pokladzie: Radeon 9550, FC7 UTD, Gnome. Stery zanimstalowalem z livny, Xgla z repo xgl, compiza z repo kagesenshi. glxinfo : name of display: :0.0 display: :0 screen: 0 direct rendering: Yes server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_hyperpipe, GLX_SGIX_swap_barrier, GLX_SGIX_fbconfig, GLX_MESA_copy_sub_buffer client glx vendor string: ATI client glx version string: 1.3 client glx extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_get_proc_address, GLX_SGI_video_sync, GLX_ARB_multisample, GLX_ATI_pixel_format_float, GLX_ATI_render_texture GLX version: 1.2 GLX extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_multisample OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: ATI Radeon 9550 / X1050 Series OpenGL version string: 2.0.6747 (8.40.4) OpenGL extensions: GL_ARB_multitexture, GL_EXT_texture_env_add, GL_EXT_compiled_vertex_array, GL_S3_s3tc, GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader, GL_ARB_multisample, GL_ARB_occlusion_query, GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shader_objects, GL_ARB_shading_language_100, GL_ARB_shadow, GL_ARB_shadow_ambient, GL_ARB_texture_border_clamp, GL_ARB_texture_compression, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle, GL_ARB_transpose_matrix, GL_ARB_vertex_blend, GL_ARB_vertex_buffer_object, GL_ARB_pixel_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos, GL_ARB_draw_buffers, GL_ATI_draw_buffers, GL_ATI_element_array, GL_ATI_envmap_bumpmap, GL_ATI_fragment_shader, GL_ATI_map_object_buffer, GL_ATI_separate_stencil, GL_ATI_texture_env_combine3, GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_ATI_vertex_array_object, GL_ATI_vertex_attrib_array_object, GL_ATI_vertex_streams, GL_ATIX_texture_env_combine3, GL_ATIX_texture_env_route, GL_ATIX_vertex_shader_output_point_size, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color, GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_object, GL_EXT_multi_draw_arrays, GL_EXT_packed_pixels, GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color, GL_EXT_separate_specular_color, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_texgen_reflection, GL_EXT_texture3D, GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_vertex_array, GL_EXT_vertex_shader, GL_HP_occlusion_test, GL_NV_blend_square, GL_NV_occlusion_query, GL_NV_texgen_reflection, GL_SGI_color_matrix, GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x23 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x24 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x25 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x26 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x27 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x28 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x29 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x2a 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x2b 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x2c 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x2d 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x2e 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x2f 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x30 24 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x31 24 tc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x32 24 tc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x33 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x34 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x35 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x36 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x37 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x38 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x39 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x3a 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x3b 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x3c 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 None 0x3d 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x3e 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 16 16 16 16 0 0 None 0x3f 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x40 24 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None 0x41 24 dc 0 32 0 r y . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x42 24 dc 0 32 0 r . . 8 8 8 8 0 24 0 0 0 0 0 0 0 None 0x55 32 tc 1 0 0 c . . 0 0 0 0 0 0 0 0 0 0 0 0 0 None fglrxinfo: [yiedhia@yiebusia ~]$ fglrxinfo display: :0.0 screen: 0 OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: ATI Radeon 9550 / X1050 Series OpenGL version string: 2.0.6747 (8.40.4) xorg.conf # Xorg configuration created by livna-config-display Section "ServerLayout" Identifier "single head configuration" Screen 0 "Screen0" 0 0 InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" ModulePath "/usr/lib/xorg/modules" EndSection Section "ServerFlags" Option "AIGLX" "off" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" Option "XkbModel" "pc105" Option "XkbLayout" "pl" EndSection Section "Device" Identifier "Videocard0" Driver "fglrx" Option "UseFastTLS" "0" Option "BlockSignalsOnLock" "on" Option "ForceGenericCPU" "off" Option "KernelModuleParm" "locked-userpages=0" Option "UseInternalAGPGART" "no" Option "OpenGLOverlay" "off" Option "VideoOverlay" "on" Option "DamageEvents" "True" Option "UseEvents" "False" Option "TripleBuffer" "True" EndSection Section "Screen" Identifier "Screen0" Device "Videocard0" DefaultDepth 24 SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection Section "DRI" Mode 0666 EndSection Section "Extensions" Option "Composite" "Enable" EndSection Probowałem juz chyba wszystkiego co jest w googlach, serio. Any ideas please? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bartucha82 Napisano Wrzesień 9, 2007 Zgłoszenie Share Napisano Wrzesień 9, 2007 Będąc posiadaczem karty ATI możesz jedynie pomarzyć o AIGLX i efektach Compiza/Beryla. Jedyne wyjście to instalacja XGL. Niestety taki urok sterownika. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
matlas Napisano Wrzesień 9, 2007 Zgłoszenie Share Napisano Wrzesień 9, 2007 na ATI nie mozesz miec AIGLX! nie potrzebny twoj trud Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ponury Napisano Wrzesień 9, 2007 Zgłoszenie Share Napisano Wrzesień 9, 2007 Masz za dobrą kartę na 9200 by jeszcze poszło. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
flameheart Napisano Wrzesień 9, 2007 Autor Zgłoszenie Share Napisano Wrzesień 9, 2007 Będąc posiadaczem karty ATI możesz jedynie pomarzyć o AIGLX i efektach Compiza/Beryla. Jedyne wyjście to instalacja XGL. Niestety taki urok sterownika. Rozumiem ze sama paczka xorg-x11-server-Xgl.i386 0-0.12.070727git.fc7 installed to mało? [edit: pragnę równiez nadmienic iż kiedys instalowalem juz beryla i dzialal, a na youtube sa filmiki z CF'em na 9550] [edit2: Wydaje mi sie ze mam juz Xgl, coprawda nie wiem jak to sprawdzic ale mam sesje Gnome with Xgl ktora odpala sie razem z compizem, pojawily sie rownierz gorny i dolny pasek menu wiemc moge kozystac z Fusion Icon, ale dalej nie wyswietla krawedzi okien i paska tytulowego...ideas? ] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
flameheart Napisano Wrzesień 9, 2007 Autor Zgłoszenie Share Napisano Wrzesień 9, 2007 Wojny ciag dalszy Doinstalowalem Beryla, z poczatku efekt taki sam jak i CF'ie ale po zmianie dekoratora na niejakiego Heliodor wszystko zaczeło smigac ze az milo.. Czy to wyglada na wine Emeralda? Jakies ideas co dalej? [Jeszcze raz zaznaczam ze kiedys Beryl na tym sprzecie dzialal normalnie Wiemc dać sie da (_napewno_ → na pewno) ORT tylko to bylo na Ubunciaku, a niestety konfiguracje iksow to dla mnie jeszcze zupelna nowosc :/ ] Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
