kwachu Napisano Listopad 1, 2007 Zgłoszenie Share Napisano Listopad 1, 2007 witam mam debiana na dysku podłączonym do primary master i fedore instalowaną na innym kompie do primary slave. dodalem do gruba wpis title Fedora (2.6.21-1.3194.fc7) root (hd1,0) kernel /boot/vmlinuz-2.6.21-1.3194.fc7 ro root=/dev/sdb1 rhgb quiet initrd /boot/initrd-2.6.21-1.3194.fc7.img przy próbie startu fedory wywala mi Unable to access resume device (LABEL=SWAP-sda2) mount: could not find filesystem '/dev/root' setoproot: moving /dev failed: No such file or directory setuproot: error mounting /proc: No such file or directory setuproot: error mounting /sys: No such file or directory switchroot: mount failed: Nosuch file or directory Kernel panic - not syncing: Attempted to kill init! fdisk -l Disk /dev/hda: 60.0 GB, 60022480896 bytes 255 heads, 63 sectors/track, 7297 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x8f800000 Device Boot Start End Blocks Id System /dev/hda1 * 1 2611 20972826 7 HPFS/NTFS /dev/hda2 2612 3462 6835657+ 83 Linux /dev/hda3 3463 7297 30804637+ 5 Extended /dev/hda5 3463 3556 755023+ 82 Linux swap / Solaris /dev/hda6 3557 7297 30049551 83 Linux Disk /dev/hdb: 80.0 GB, 80026361856 bytes 255 heads, 63 sectors/track, 9729 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x00037324 Device Boot Start End Blocks Id System /dev/hdb1 * 1 1275 10241406 83 Linux /dev/hdb2 1276 1340 522112+ 82 Linux swap / Solaris /dev/hdb4 2558 9729 57609090 5 Extended /dev/hdb5 2558 2680 987966 83 fstab fedory LABEL=/ / ext3 defaults 1 1 tmpfs /dev/shm tmpfs defaults 0 0 devpts /dev/pts devpts gid=5,mode=620 0 0 sysfs /sys sysfs defaults 0 0 proc /proc proc defaults 0 0 LABEL=SWAP-sda2 swap swap defaults 0 0 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Amos Napisano Listopad 1, 2007 Zgłoszenie Share Napisano Listopad 1, 2007 W fedorowym fstab zamiast LABEL=/ daj /dev/sdb1 a zamiast LABEL=SWAP-sda2 daj /dev/sdb2 i powinno być dobrze... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
kwachu Napisano Listopad 1, 2007 Autor Zgłoszenie Share Napisano Listopad 1, 2007 W fedorowym fstab zamiast LABEL=/ daj /dev/sdb1 a zamiast LABEL=SWAP-sda2 daj /dev/sdb2 i powinno być dobrze... próbowałem tego wcześniej ale niestety nic to nie zmienilo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
