Nie Moge Zainstalowac Srodowiska Gnome W Fedorze 8
DAREK WL.
Jesli macie problemy z pakietem yelp zainstalujcie go z tego RPM-a: http://koji.fedoraproject.org/packages/yel...-5.fc8.i386.rpm . U mnie z tej paczki zainstalowal sie bez problemu. (z repo mialem to samo co wy)
yyyy... WTF?! :ph34r:
A to lektura dla ciekawskich:
Component: pirut
Summary: TB2d8305f8 threading.py:94:acquire:RuntimeError: maximum recursion depth exceeded
 File "/usr/sbin/system-install-packages", line 355, in <module>
   main()
 File "/usr/sbin/system-install-packages", line 351, in main
   pkginst.run()
 File "/usr/sbin/system-install-packages", line 339, in run
   self.doRefresh()
 File "/usr/sbin/system-install-packages", line 98, in doRefresh
   self.populatePackages()
 File "/usr/sbin/system-install-packages", line 279, in populatePackages
   self._populateLocalPackages(locals)
 File "/usr/sbin/system-install-packages", line 154, in _populateLocalPackages
   self.tsInfo.addInstall(po = po)
 File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 535, in <lambda>
   tsInfo = property(fget=lambda self: self._getTsInfo(),
 File "/usr/lib/python2.5/site-packages/yum/depsolve.py", line 83, in _getTsInfo
   self._tsInfo.setDatabases(self.rpmdb, self.pkgSack)
 File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 526, in <lambda>
   pkgSack = property(fget=lambda self: self._getSacks(),
 File "/usr/lib/python2.5/site-packages/yum/__init__.py", line 393, in _getSacks
   self.plugins.run('exclude')
 File "/usr/lib/python2.5/site-packages/yum/plugins.py", line 169, in run
   func(conduitcls(self, self.base, conf, **kwargs))
 File "/usr/lib/yum-plugins/priorities.py", line 68, in exclude_hook
   obsoletes = conduit._base.pkgSack.returnObsoletes()
 File "/usr/lib/python2.5/site-packages/yum/plugins.py", line 305, in __init__
   self.logger = logging.getLogger("yum.plugin")
 File "/usr/lib/python2.5/logging/__init__.py", line 1265, in getLogger
   return Logger.manager.getLogger(name)
 File "/usr/lib/python2.5/logging/__init__.py", line 864, in getLogger
   _acquireLock()
 File "/usr/lib/python2.5/logging/__init__.py", line 191, in _acquireLock
   _lock.acquire()
 File "/usr/lib/python2.5/threading.py", line 94, in acquire
   me = currentThread()
Local variables in innermost frame:
self: <_RLock(None, 0)>
blocking: 1
Fedora 8... :/ Oczywiście to się dzieje przy próbie zainstalowania czegokolwiek, bo nie może być zbyt pięknie... Nie dość, że coś spaprali (w 7 aplikacje gtk wyglądały, a teraz nie chcą) to jeszcze jaśnie wielmożny pirut sie wysypał...
k_myk
