W8_4_me Napisano Listopad 11, 2007 Zgłoszenie Share Napisano Listopad 11, 2007 Witam Przeszukalem forum ale zadne z podanych sposobów nie pomogły wiec pisze. Staram sie odpalić rmvb na mplayer,zainstalowalem paczke kodeków w32codec-all-20071007-0.pm.1.i586.rpm ale jeśli prubuje ucruchomic film rmvb to wypisuje mi jak poniżej. Dzwiek jest ale brak obrazu. MPlayer 1.0rc2-4.1.2 (C) 2000-2007 MPlayer Team CPU: Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz (Family: 6, Model: 15, Stepping: 6) CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1 Compiled for x86 CPU with extensions: MMX MMX2 SSE SSE2 Playing /media/disk/Filmy/pl/pl.rmvb. REAL file format detected. Stream description: Audio Stream Stream mimetype: audio/x-pn-realaudio [real] Audio stream found, -aid 0 Stream description: Video Stream Stream mimetype: video/x-pn-realvideo [real] Video stream found, -vid 1 Stream mimetype: logical-fileinfo VIDEO: [RV40] 688x368 24bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s) ========================================================================== Opening video decoder: [realvid] RealVideo decoder Error: /usr/lib/win32/drvc.so: wrong ELF class: ELFCLASS32 ERROR: Could not open required DirectShow codec drvc.so. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder ERROR: Could not open required DirectShow codec drvc.dll. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder Error: /usr/lib/win32/drv4.so.6.0: wrong ELF class: ELFCLASS32 ERROR: Could not open required DirectShow codec drv4.so.6.0. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder ERROR: Could not open required DirectShow codec drv43260.dll. Read the RealVideo section of the DOCS! VDecoder init failed :( Opening video decoder: [realvid] RealVideo decoder Error: /usr/lib/win32/drvc.bundle/Contents/MacOS/drvc: cannot open shared object file: No such file or directory ERROR: Could not open required DirectShow codec drvc.bundle/Contents/MacOS/drvc. Read the RealVideo section of the DOCS! VDecoder init failed :( Cannot find codec matching selected -vo and video format 0x30345652. Read DOCS/HTML/en/codecs.html! ========================================================================== ========================================================================== Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders AUDIO: 44100 Hz, 2 ch, s16le, 64.1 kbit/4.54% (ratio: 8010->176400) Selected audio codec: [ffcook] afm: ffmpeg (FFmpeg COOK audio decoder) Zasanawia mnie ten fragment, chciałem cos poszukac nt wrong ELF class ale wywala mi stronki po chińsku :lammer: Error: /usr/lib/win32/drvc.so: wrong ELF class: ELFCLASS32 ERROR: Could not open required DirectShow codec drvc.so. Read the RealVideo section of the DOCS! Plik znajduje sie w tym folderze. dodam ze wykonalem take polecenie chcon -t textrel_shlib_t drvc.so Juz nawet kąpilowalem mplayera ze źródel z kodekami win32 na sztywno ale to samo. Zainstalowalem realplayer - ktory odtwarza bez problemu pliki rmvb, probowalem nawet kopiowac jego kodeki z /usr/local/realplayer/codecs do mplayer ale dzieje sie to samo co wyżej. Kończa mi się pomysły i nie wiem czy to wina fedory 8 ?? Pomocy :lammer: plss..... Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lulo Napisano Listopad 12, 2007 Zgłoszenie Share Napisano Listopad 12, 2007 Nie wiem na ile zda się moja rada ale próbowałeś może: 1. zainstalować paczkę o nazwie mplayer-codecs i/lub mplayer-codecs-extra ze strony mplayera 2. skopiować zawartości katalogo codecs z ze struktury katalogu głównego programu raelplayer (codzienne budowanie) Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Black Dog Napisano Listopad 12, 2007 Zgłoszenie Share Napisano Listopad 12, 2007 Miałem to samo. Pobierasz ftp://stojak.info/Instalki/Fedora/RealPla...070805.i586.rpm Wypakowywujesz przy użyciu Krusadera. I pliku drvc.so i drvc.dll przenosisz do /usr/lib/win32 [widze że taką masz ścieżkę to taką podaję ]. I wszystko działa. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
W8_4_me Napisano Listopad 13, 2007 Autor Zgłoszenie Share Napisano Listopad 13, 2007 Nie wiem na ile zda się moja rada ale próbowałeś może: 1. zainstalować paczkę o nazwie mplayer-codecs i/lub mplayer-codecs-extra ze strony mplayera 2. skopiować zawartości katalogo codecs z ze struktury katalogu głównego programu raelplayer (codzienne budowanie) Niestety tego już próbowałem, ale pojawiał się błąd jak na listingu wyżej, ale dzieki za zainteresowanie... Miałem to samo. Pobierasz ftp://stojak.info/Instalki/Fedora/RealPla...070805.i586.rpm Wypakowywujesz przy użyciu Krusadera. I pliku drvc.so i drvc.dll przenosisz do /usr/lib/win32 [widze że taką masz ścieżkę to taką podaję ]. I wszystko działa. dzieki za zainteresowanie, spróbuje jak wrócę do domu i dam znać czy zadziałało... Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
W8_4_me Napisano Listopad 13, 2007 Autor Zgłoszenie Share Napisano Listopad 13, 2007 Miałem to samo. Pobierasz ftp://stojak.info/Instalki/Fedora/RealPla...070805.i586.rpm Wypakowywujesz przy użyciu Krusadera. I pliku drvc.so i drvc.dll przenosisz do /usr/lib/win32 [widze że taką masz ścieżkę to taką podaję ]. I wszystko działa. Witam.... Ściągnolem tą paczkę ale nie widze w środku pliku drvc.dll jest tylko drvc.so ale to chyba za malo bo jak go skpiowalem to dalej taki sam bląd.... PS: Mozesz mi wyslac pliki drvc gdzies na jakiś serwer plików np rapidshare.com etc?? Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Black Dog Napisano Listopad 13, 2007 Zgłoszenie Share Napisano Listopad 13, 2007 A skopiuj wszystkie kodeki i ten plik do /usr/lib/codecs , ja tak mam i dziala. Co do plików, to ja widze że drvc.dll tez u mnie y... nie ma? O_o a wczoraj był! O_o No nic, filmy mi działają. Najlepiej skopiuj wszystkie pliki z tej paczki RealPlayera do katalogu z kodekami. I no nie ma bata musi działać! Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
W8_4_me Napisano Listopad 14, 2007 Autor Zgłoszenie Share Napisano Listopad 14, 2007 A skopiuj wszystkie kodeki i ten plik do /usr/lib/codecs , ja tak mam i dziala. Co do plików, to ja widze że drvc.dll tez u mnie y... nie ma? O_o a wczoraj był! O_o No nic, filmy mi działają. Najlepiej skopiuj wszystkie pliki z tej paczki RealPlayera do katalogu z kodekami. I no nie ma bata musi działać! Tak już robiłem ale bląd wyskakuje jak powyżej..... Nie wiem czy to może być to ale mnie sie wydaje ze poprostu jest jakiś konflikt pakietów, ponieważ mam fedore w wersji 64bit. Spróbuje zainstalowac "zwyklą" i zobacze czy bedzie chodziło. A ty Black Dog jaką masz wersje fedory 64bit? pzdr Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Black Dog Napisano Listopad 14, 2007 Zgłoszenie Share Napisano Listopad 14, 2007 Ja mam sprzęt 32 bit to i system 32 bit Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
hodys Napisano Listopad 19, 2007 Zgłoszenie Share Napisano Listopad 19, 2007 To nie wystarczy zeby odpalic rmvb w mplayer kolego. Muisz do katalogu /usr/lib/codecs dorzucic kodeki rp9codecs np z http://www.mplayerhq.hu/MPlayer/releases/codecs/ . Powinno ruszyc. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
W8_4_me Napisano Listopad 20, 2007 Autor Zgłoszenie Share Napisano Listopad 20, 2007 To nie wystarczy zeby odpalic rmvb w mplayer kolego. Muisz do katalogu /usr/lib/codecs dorzucic kodeki rp9codecs np z http://www.mplayerhq.hu/MPlayer/releases/codecs/ . Powinno ruszyc. Dzięki kolego, dzisiaj przestrestuje jak wróce do domu i dam znac czy poszlo, Pozdrawiam Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
maslak Napisano Listopad 28, 2007 Zgłoszenie Share Napisano Listopad 28, 2007 mialem identyczny problem. zainstalowalem: 1. zainstalować paczkę o nazwie mplayer-codecs i/lub mplayer-codecs-extra ze strony mplayera ale to jeszcze nie pomoglo. pogrzebalem wiec i pobralem: http://www.mplayerhq.hu/MPlayer/releases/c...0071007.tar.bz2 bo tak sie sklada ze akurat mam amd64. wrzucilem zawartosc tej paczki do /usr/lib/codecs (tylko zawartosc tej paczki, zadnych innych plikow) i... i juz wszystko dziala: wystarcza ta paczka, ktora podalem. w konfiguracji w codecs&demuxer ustawiamy: video codec family: RealVideo Decoder audio codec family: FFmpeg/libavcodec audio decoders w video drivers mam standardowo: xv X11/Xv w audio oss ps. nie wiem na ile kluczowe bylo zainstalowanie tych paczek wymienionych w cytacie Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Neuromancer Napisano Grudzień 5, 2007 Zgłoszenie Share Napisano Grudzień 5, 2007 ps. nie wiem na ile kluczowe bylo zainstalowanie tych paczek wymienionych w cytacie Powiem Ci że było to kluczowe ponieważ ja miałem zainstalowane "niby wszystko" [tzn mplayer* i wypakowane kodeki do /usr/lib/codecs ] i w rmvb nie miałem obrazu a dźwięk był. Po doinstalowaniu tych paczek mplayer-codec i mplayer-codec-extra ruszyło wszystko elegancko. F8 X86_64 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cracket Napisano Grudzień 6, 2007 Zgłoszenie Share Napisano Grudzień 6, 2007 NIestety to jest kluczowe, jak się ma system x86_64 to binarki 64 bitowe MUSZĄ korzystać z 64 bitowych bibliotek. Sztandarowy przykład to firefox z flash-em i javą każdy błąd typu ELFCLASS32 oznacza że 64 bitowa binarka próbuje załadować 32bitową bibliotekę , wystarczy ją obejrzeć programikiem readelf Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
lulo Napisano Styczeń 18, 2008 Zgłoszenie Share Napisano Styczeń 18, 2008 NIestety to jest kluczowe, jak się ma system x86_64 to binarki 64 bitowe MUSZĄ korzystać z 64 bitowych bibliotek... ...co sugeruje, że z poruszonym problemem należy postąpić tak (zawsze mi działa na wszystkich 64-bitowych dystrybucjach jakie miałem/mam-również na Fedora 8 x86_64): 1. instalujesz mplayer-codecs-20061022-1.x86_64.rpm oraz mplayer-codecs-extra-20061022-1.x86_64.rpm ze strony Mplayer'a co spowoduje, iż pliki znajdą się nie w /usr/lib/codecs tylko w /usr/lib64/codecs, do którego... 2. ...tworzysz jako root dowiązanie (konsola) będąc w katalogu /usr/lib64 ln -s codecs win32 3.cieszysz się działającym *.rmvb Oczywiście pliki w /usr/lib64/codecs można podmienić tymi ze strony realplaera z rpm-ów "nocnego budowania", bo pojawiły się nareszcie wersje 64-bitowe....moim zdaniem są jeszcze kiepskie, więc i kodeki póki co też sprawiaja problemy z odtwarzaniem/budowaniem filmów .rmvb. Nie bez powodu zastosowałem te starsze rpm-y, gdyż z nimi nie ma problemów z dźwiękiem a w nowszych są. GENERALNIE: odpowiednie 64-bitowe kodeki muszą się znaleźć w /usr/lib64/codecs i trzeba ręcznie utworzyć w/w dowiązanie...sukces gwarantowany. Po zainstalowaniu działa nawet oglądanie *.rmvb w totem'ie ale niestety nie wiem do dzisiaj jak zlikwidować problemy z "metaliczno/syntezatorowym" (zniekształconym) dźwiękiem. Na szczęście w Mplaye'rze nie występują żadne problemy i dźwięk jest OK. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
