sratanik2 Napisano Listopad 25, 2007 Autor Zgłoszenie Share Napisano Listopad 25, 2007 Linux version 2.6.23.1-49.fc8 ([email protected]) (gcc version 4.1.2 20070925 (Red Hat 4.1.2-33)) #1 SMP Thu Nov 8 21:41:26 EST 2007 BIOS-provided physical RAM map: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable) BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved) BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved) BIOS-e820: 0000000000100000 - 000000002fff0000 (usable) BIOS-e820: 000000002fff0000 - 000000002fff3000 (ACPI NVS) BIOS-e820: 000000002fff3000 - 0000000030000000 (ACPI data) BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved) BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved) 0MB HIGHMEM available. 767MB LOWMEM available. found SMP MP-table at 000f4b20 Using x86 segment limits to approximate NX protection Entering add_active_range(0, 0, 196592) 0 entries of 256 used Zone PFN ranges: DMA 0 -> 4096 Normal 4096 -> 196592 HighMem 196592 -> 196592 Movable zone start PFN for each node early_node_map[1] active PFN ranges 0: 0 -> 196592 On node 0 totalpages: 196592 DMA zone: 32 pages used for memmap DMA zone: 0 pages reserved DMA zone: 4064 pages, LIFO batch:0 Normal zone: 1503 pages used for memmap Normal zone: 190993 pages, LIFO batch:31 HighMem zone: 0 pages used for memmap Movable zone: 0 pages used for memmap DMI 2.3 present. Using APIC driver default ACPI: RSDP 000F63F0, 0014 (r0 GBT ) ACPI: RSDT 2FFF3000, 002C (r1 GBT AWRDACPI 42302E31 AWRD 1010101) ACPI: FACP 2FFF3040, 0074 (r1 GBT AWRDACPI 42302E31 AWRD 1010101) ACPI: DSDT 2FFF30C0, 3769 (r1 GBT AWRDACPI 1000 MSFT 100000C) ACPI: FACS 2FFF0000, 0040 ACPI: APIC 2FFF6840, 005A (r1 GBT AWRDACPI 42302E31 AWRD 1010101) ACPI: PM-Timer IO Port: 0x4008 ACPI: Local APIC address 0xfee00000 ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) Processor #0 6:8 APIC version 16 ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1]) ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0]) IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23 ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level) ACPI: IRQ0 used by override. ACPI: IRQ2 used by override. ACPI: IRQ9 used by override. Enabling APIC mode: Flat. Using 1 I/O APICs Using ACPI (MADT) for SMP configuration information Allocating PCI resources starting at 40000000 (gap: 30000000:cec00000) swsusp: Registered nosave memory region: 000000000009f000 - 00000000000a0000 swsusp: Registered nosave memory region: 00000000000a0000 - 00000000000f0000 swsusp: Registered nosave memory region: 00000000000f0000 - 0000000000100000 Built 1 zonelists in Zone order. Total pages: 195057 Kernel command line: ro root=LABEL=/ rhgb quiet mapped APIC to ffffb000 (fee00000) mapped IOAPIC to ffffa000 (fec00000) Enabling fast FPU save and restore... done. Enabling unmasked SIMD FPU exception support... done. Initializing CPU#0 CPU 0 irqstacks, hard=c07a8000 soft=c0788000 PID hash table entries: 4096 (order: 12, 16384 bytes) Detected 1111.033 MHz processor. Console: colour VGA+ 80x25 console [tty0] enabled Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Memory: 771440k/786368k available (2184k kernel code, 14328k reserved, 1116k data, 280k init, 0k highmem) virtual kernel memory layout: fixmap : 0xffc53000 - 0xfffff000 (3760 kB) pkmap : 0xff800000 - 0xffc00000 (4096 kB) vmalloc : 0xf0800000 - 0xff7fe000 ( 239 MB) lowmem : 0xc0000000 - 0xefff0000 ( 767 MB) .init : 0xc073f000 - 0xc0785000 ( 280 kB) .data : 0xc0622165 - 0xc0739544 (1116 kB) .text : 0xc0400000 - 0xc0622165 (2184 kB) Checking if this processor honours the WP bit even in supervisor mode... Ok. SLUB: Genslabs=22, HWalign=32, Order=0-1, MinObjects=4, CPUs=1, Nodes=1 Calibrating delay using timer specific routine.. 2223.53 BogoMIPS (lpj=1111766) Security Framework v1.0.0 initialized SELinux: Initializing. SELinux: Starting in permissive mode selinux_register_security: Registering secondary module capability Capability LSM initialized as secondary Mount-cache hash table entries: 512 CPU: After generic identify, caps: 0383fbff c1c3fbff 00000000 00000000 00000000 00000000 00000000 00000000 CPU: CLK_CTL MSR was 60031223. Reprogramming to 20031223 CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line) CPU: L2 Cache: 256K (64 bytes/line) CPU: After all inits, caps: 0383f3ff c1c3fbff 00000000 00000420 00000000 00000000 00000000 00000000 Intel machine check architecture supported. Intel machine check reporting enabled on CPU#0. Compat vDSO mapped to ffffe000. Checking 'hlt' instruction... OK. SMP alternatives: switching to UP code Freeing SMP alternatives: 14k freed ACPI: Core revision 20070126 CPU0: AMD Athlon stepping 01 Total of 1 processors activated (2223.53 BogoMIPS). ENABLING IO-APIC IRQs ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1 Brought up 1 CPUs sizeof(vma)=84 bytes sizeof(page)=32 bytes sizeof(inode)=336 bytes sizeof(dentry)=132 bytes sizeof(ext3inode)=488 bytes sizeof(buffer_head)=56 bytes sizeof(skbuff)=180 bytes sizeof(task_struct)=1552 bytes Booting paravirtualized kernel on bare hardware Time: 11:19:44 Date: 11/25/07 NET: Registered protocol family 16 No dock devices found. ACPI: bus type pci registered PCI: PCI BIOS revision 2.10 entry at 0xf9b90, last bus=1 PCI: Using configuration type 1 Setting up standard PCI resources ACPI: EC: Look up EC in DSDT ACPI: Interpreter enabled ACPI: (supports S0 S1 S4 S5) ACPI: Using IOAPIC for interrupt routing ACPI: PCI Root Bridge [PCI0] (0000:00) Failed to force enable HPET PCI quirk: region 4000-407f claimed by vt8235 PM PCI quirk: region 5000-500f claimed by vt8235 SMB ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 *10 11 12 14 15) ACPI: PCI Interrupt Link [LNKB] (IRQs 1 3 4 5 6 7 10 *11 12 14 15) ACPI: PCI Interrupt Link [LNKC] (IRQs 1 3 4 5 6 7 10 *11 12 14 15) ACPI: PCI Interrupt Link [LNKD] (IRQs 1 3 4 *5 6 7 10 11 12 14 15) ACPI: PCI Interrupt Link [ALKA] (IRQs 20) *0 ACPI: PCI Interrupt Link [ALKB] (IRQs 21) *0 ACPI: PCI Interrupt Link [ALKC] (IRQs 22) *0 ACPI: PCI Interrupt Link [ALKD] (IRQs 23) *0 Linux Plug and Play Support v0.97 ? Adam Belay pnp: PnP ACPI init ACPI: bus type pnp registered pnp: PnP ACPI: found 13 devices ACPI: ACPI bus type pnp unregistered usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb PCI: Using ACPI for IRQ routing PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report NetLabel: Initializing NetLabel: domain hash size = 128 NetLabel: protocols = UNLABELED CIPSOv4 NetLabel: unlabeled traffic allowed by default Time: tsc clocksource has been installed. PCI: Bridge: 0000:00% InIrudeBwoy moglbys mi napisac jak zainstalowac knetworkmanager Dłuższe listingi niż 12-15 linijek dajemy do codebox zamiast code /Karlik Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
InIrudeBwoy Napisano Listopad 25, 2007 Zgłoszenie Share Napisano Listopad 25, 2007 Jasne, banalna sprawa. su -c "yum install knetworkmanager" lub w yumex wyszukaj sobie i zainstaluj. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
