DAREK WL. Napisano Listopad 19, 2007 Zgłoszenie Share Napisano Listopad 19, 2007 Prosze o pomoc ; Gdy chce uruchomic serwer dzwieku JACK to on mi wywala takie błędy 1 7:32:27.481 Patchbay deactivated. 17:32:27.539 Statistics reset. JACK tmpdir identified as [/dev/shm] 17:32:27.601 MIDI connection graph change. 17:32:27.748 MIDI connection change. 17:32:44.139 Startup script... 17:32:44.140 artsshell -q terminate JACK tmpdir identified as [/dev/shm] 17:32:44.424 Startup script terminated with exit status=256. 17:32:44.424 JACK is starting... 17:32:44.424 jackd -R -P1 -dalsa -dhw:0 -r48000 -p1024 -n2 17:32:44.426 JACK was started with PID=2948 (0xb84). jackd 0.103.0 Copyright 2001-2005 Paul Davis and others. jackd comes with ABSOLUTELY NO WARRANTY This is free software, and you are welcome to redistribute it under certain conditions; see the file COPYING for details JACK compiled with System V SHM support. loading driver .. apparent rate = 48000 creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit control device hw:0 the playback device "hw:0" is already in use. Please stop the application using it and run JACK again cannot load driver module alsa no message buffer overruns 17:32:44.508 JACK was stopped successfully. 17:32:46.489 Could not connect to JACK server as client. Please check the messages window for more info. JACK tmpdir identified as [/dev/shm] Albo taki błąd ; o message buffer overruns 17:32:44.508 JACK was stopped successfully. 17:32:46.489 Could not connect to JACK server as client. Please check the messages window for more info. JACK tmpdir identified as [/dev/shm] 17:39:58.348 Startup script... 17:39:58.348 artsshell -q terminate JACK tmpdir identified as [/dev/shm] 17:39:58.633 Startup script terminated with exit status=256. 17:39:58.633 JACK is starting... 17:39:58.633 jackd -R -P1 -doss -r48000 -p1024 -n2 -w16 17:39:58.634 JACK was started with PID=2995 (0xbb3). jackd: unknown driver 'oss' 17:39:58.646 JACK was stopped with exit status=1. 17:40:00.691 Could not connect to JACK server as client. Please check the messages window for more info. JACK tmpdir identified as [/dev/shm] Serwere JACK jest mi niezbedny do uruchomienia programu ZYNADDSUBFX który bez niego uruchomic sie nie chce ; Try 'zynaddsubfx --help' for command-line options. Sound Buffer Size = 256 samples Internal latency = 5.8 ms ADsynth Oscil.Size = 512 samples JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] JACK tmpdir identified as [/dev/shm] ERROR: Cannot make a jack client (possible reasons: JACK server is not running or jackd is launched by root and zynaddsubfx by another user.). [root@localhost ~]# Prosze o pomoc . Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
bartucha82 Napisano Listopad 20, 2007 Zgłoszenie Share Napisano Listopad 20, 2007 Jaka wersja systemu?? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
cracket Napisano Listopad 22, 2007 Zgłoszenie Share Napisano Listopad 22, 2007 jackd: unknown driver 'oss' Twój jack nie może się dopiąć do oss-a Działa ci jakikolwiek odtwarzacz muzyki przez oss-a? np. mplayer -ao oss .... ? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
