Problem Z Frostwire W F8
kurzawa
Próbowałem odpalić Frostwire na F8 i dałem polecenie:
[kurzawa@localhost ~]$ frostwire
Ale otrzymałem:
Starting FrostWire...
Java exec found in PATH. Verifying...
Suitable java version found [java = 1.6.0_03]
Configuring environment...
Loading FrostWire:
java: xcb_xlib.c:50: xcb_xlib_unlock: Assertion `c->xlib.lock' failed.
/usr/lib/frostwire/runFrostwire.sh: line 125:  4886 Przerwane               ${JAVA_PROGRAM_DIR}java -ea -Dorg.apache.commons.logging.Log=org.apache.commons.logging.impl.NoOpLog -Djava.library.path=. $EXECUTABLE -jar FrostWire.jar $ARGUMENTS
Something went wrong with FrostWire.
Maybe you're using the wrong version of Java?
(FrostWire is tested against and works best with with Sun's JRE, Java 1.4+)
The version of Java in your PATH is:
java version "1.6.0_03"
Java SE Runtime Environment (build 1.6.0_03-b05)
Java HotSpot Client VM (build 1.6.0_03-b05, mixed mode, sharing)
Pakiet libXp mam zainstalowany:
[kurzawa@localhost ~]$ rpm -qil libXp
Name        : libXp                        Relocations: (not relocatable)
Version     : 1.0.0                             Vendor: Fedora Project
Release     : 8.fc8                         Build Date: śro, 22 sie 2007, 01:05:53
Install Date: czw, 22 lis 2007, 16:06:21      Build Host: xenbuilder2.fedora.redhat.com
Group       : System Environment/Libraries   Source RPM: libXp-1.0.0-8.fc8.src.rpm
Size        : 33141                            License: MIT/X11
Signature   : DSA/SHA1, czw, 25 paź 2007, 05:36:18, Key ID b44269d04f2a6fd2
Packager    : Fedora Project
URL         : http://www.x.org
Summary     : X.Org X11 libXp runtime library
Description :
/usr/lib/libXp.so.6
/usr/lib/libXp.so.6.2.0
/usr/share/doc/libXp-1.0.0
/usr/share/doc/libXp-1.0.0/AUTHORS
/usr/share/doc/libXp-1.0.0/COPYING
/usr/share/doc/libXp-1.0.0/ChangeLog
/usr/share/doc/libXp-1.0.0/INSTALL
/usr/share/doc/libXp-1.0.0/README
Co zrobić?
Znany problem z javą ,a nie programem Frostwire. Proszę sprawdzić wątki o javie w F8. Stosowny patch podany praktycznie w każdym wątku o javie w F8.
wcale niekoniecznie. u mnie Java dziala bez problemow, a Frostwire akurat sie uparl. bawilem sie nawet w edycje skryptu startowego, ale nic nie pomaga.
Ta linijeczka mówi wszystko. Jest to właśnie sławetny błąd w javie, który sprawia, że raz ona działa, a raz nie. Po prostu chłopaki z SUN nie postarali się. :D
to fakt, ale niestety rozwiazanie, ktore działa we wszystkich innych przypadkach, tu nie daje rezultatow. czeski film... :rolleyes:
swoja droga na IcedTea nie dzialaly za to inne programy. i coz tu czynic? :lol:
Mówisz, że patch nie działa na jave?? Czy, że nawet po patchowaniu javy Frostwire nie chodzi??
Ja rozwiązałem ten problem w taki sposób wykonując:
updatedb
for i in $(locate libmawt.so); do
sed -i 's/XINERAMA/FAKEEXTN/g'  ${i}
done
teraz już wszystko powinno śmigać ;)
Dzięki kurzawa. Wszystko śmiga. Proponuję przypiąć to rozwiązanie bo może się okazać, że rozwiązuje problemy z instalatorem Oracle i innymi aplikacjami java pod F8.
Gość
