Problem Z Wlan
enter1
Witam próbuję dla FC7 uruchomić sobie połączenie bezprzewodowe przy pomocy ndiswrappera, a wygląda to tak:
[root@localhost Nowy katalog_1]# su -
[root@localhost ~]# ndiswrapper -l
net8180 : driver installed
        device (10EC:8180) present
[root@localhost ~]# ndiswrapper -m
adding "alias wlan0 ndiswrapper" to /etc/modprobe.d/ndiswrapper ...
[root@localhost ~]# sudo depmod -a
[root@localhost ~]# sudo modprobe ndiswrapper
[root@localhost ~]# dmesg | tail
[code] sdc: sdc1
sd 3:0:0:0: Attached scsi disk sdc
sd 3:0:0:0: Attached scsi generic sg4 type 0
ndiswrapper version 1.46 loaded (smp=yes)
ndiswrapper: driver net8180 (Realtek,10/07/2004,5.173.1007.2004) loaded
ACPI: PCI Interrupt 0000:01:07.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 21
ndiswrapper: using IRQ 21
wlan0: ethernet device 00:50:fc:f1:c2:e5 using NDIS driver: net8180, version: 0x500aa, NDIS version: 0x500, vendor: 'Realtek RTL8180 Wireless LAN (Mini-)PCI NIC                                     ', 10EC:8180.5.conf
wlan0: encryption modes supported: WEP; TKIP with WPA; AES/CCMP with WPA
usbcore: registered new interface driver ndiswrapper
[root@localhost ~]# system-config-network
Nic mi nie wychodzi, ponieważ w pierwszej zakładce w system-config-network nie mogę wybrać ndiswrappera, mogę wybrać wyłącznie eth0 do eth8 brakuje tu ndiswrapper/wlan0. Co z tym zrobić, proszę pomóżcie.
Dodam jeszcze, że po iwlist mam coś takiego:
[root@localhost ~]# iwlist wlan0 scan
wlan0     Scan completed :
          Cell 01 - Address: 00:0F:B5:13:AA:E8
                    ESSID:"tenbartek"
                    Protocol:IEEE 802.11b
                    Mode:Managed
                    Frequency:2.462 GHz (Channel 11)
                    Quality:67/100  Signal level:-53 dBm  Noise level:-96 dBm
                    Encryption key:on
                    Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 22 Mb/s
                    Extra:bcn_int=100
                    Extra:atim=0
                    IE: WPA Version 1
                        Group Cipher : TKIP
                        Pairwise Ciphers (1) : TKIP
                        Authentication Suites (1) : PSK
          Cell 02 - Address: 00:17:3F:01:A4:5E
                    ESSID:"hurdy gurdy"
                    Mode:Managed
                    Quality:35/100  Signal level:-73 dBm  Noise level:-96 dBm
                    Encryption key:on
                    Extra:bcn_int=100
                    Extra:atim=0
                    IE: WPA Version 1
                        Group Cipher : TKIP
Ponieważ w system-config-network nie mogę ustawić ndiswrappera to dalej mam:
[root@localhost ~]# sudo /sbin/dhclient wlan0
Internet Systems Consortium DHCP Client V3.0.5-RedHat
Copyright 2004-2006 Internet Systems Consortium.
All rights reserved.
For info, please visit http://www.isc.org/sw/dhcp/
/sbin/dhclient-script: configuration for wlan0 not found. Continuing with defaults.
/etc/sysconfig/network-scripts/network-functions: line 78: wlan0: Nie ma takiego pliku ani katalogu
eth0: error fetching interface information: Device not found
External network device eth0 is not ready. Aborting..
Listening on LPF/wlan0/00:50:fc:f1:c2:e5
Sending on   LPF/wlan0/00:50:fc:f1:c2:e5
Sending on   Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
No DHCPOFFERS received.
No working leases in persistent database - sleeping.
Moja sieć to "tenbartek" i ustawione szyfrowanie WPA
