stanny Napisano Styczeń 5, 2008 Zgłoszenie Share Napisano Styczeń 5, 2008 Witam.. borykam sie juz z tym dluzszy czas i wraz nie wiem o co w tym chodzi... prosze o pomoc wywala mi komunikat :lammer: [root@localhost ~]# radiusd -X Starting - reading configuration files ... reread_config: reading radiusd.conf Config: including file: /etc/raddb/proxy.conf Config: including file: /etc/raddb/clients.conf Config: including file: /etc/raddb/snmp.conf Config: including file: /etc/raddb/sql.conf main: prefix = "/usr" main: localstatedir = "/var" main: logdir = "/var/log/radius" main: libdir = "/usr/lib" main: radacctdir = "/var/log/radius/radacct" main: hostname_lookups = no main: snmp = no main: max_request_time = 30 main: cleanup_delay = 5 main: max_requests = 1024 main: delete_blocked_requests = 0 main: port = 0 main: allow_core_dumps = no main: log_stripped_names = no main: log_file = "/var/log/radius/radius.log" main: log_auth = yes main: log_auth_badpass = yes main: log_auth_goodpass = yes main: pidfile = "/var/run/radiusd/radiusd.pid" main: user = "radiusd" main: group = "radiusd" main: usercollide = no main: lower_user = "no" main: lower_pass = "no" main: nospace_user = "no" main: nospace_pass = "no" main: checkrad = "/usr/sbin/checkrad" main: proxy_requests = yes proxy: retry_delay = 5 proxy: retry_count = 3 proxy: synchronous = no proxy: default_fallback = yes proxy: dead_time = 120 proxy: post_proxy_authorize = no proxy: wake_all_if_all_dead = no security: max_attributes = 200 security: reject_delay = 1 security: status_server = no main: debug_level = 0 read_config_files: reading dictionary read_config_files: reading naslist Using deprecated naslist file. Support for this will go away soon. read_config_files: reading clients read_config_files: reading realms radiusd: entering modules setup Module: Library search path is /usr/lib Module: Loaded exec exec: wait = yes exec: program = "(null)" exec: input_pairs = "request" exec: output_pairs = "(null)" exec: packet_type = "(null)" rlm_exec: Wait=yes but no output defined. Did you mean output=none? Module: Instantiated exec (exec) Module: Loaded expr Module: Instantiated expr (expr) Module: Loaded CHAP Module: Instantiated chap (chap) Module: Loaded MS-CHAP mschap: use_mppe = yes mschap: require_encryption = no mschap: require_strong = no mschap: with_ntdomain_hack = no mschap: passwd = "(null)" mschap: ntlm_auth = "(null)" Module: Instantiated mschap (mschap) Module: Loaded preprocess preprocess: huntgroups = "/etc/raddb/huntgroups" preprocess: hints = "/etc/raddb/hints" preprocess: with_ascend_hack = no preprocess: ascend_channels_per_line = 23 preprocess: with_ntdomain_hack = no preprocess: with_specialix_jetstream_hack = no preprocess: with_cisco_vsa_hack = no preprocess: with_alvarion_vsa_hack = no rlm_preprocess: Error reading /etc/raddb/huntgroups radiusd.conf[1023]: preprocess: Module instantiation failed. radiusd.conf[1804] Unknown module "preprocess". radiusd.conf[1794] Failed to parse authorize section. [root@localhost ~]# ------------- Listingi do 12-15 linijek umieszczaj między znacznikami [code] i [/code], dłuższe niż 15 linii pomiędzy [codebox] i [/codebox] - tak jest czytelniej. Przeczytaj "BB Code Help" - WalDo Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
