HANS99 Napisano Styczeń 18, 2008 Zgłoszenie Share Napisano Styczeń 18, 2008 Problem polega na tym że po zainstalowaniu fed. 8 jest kłopot z podniesieniem wifi SIOCSIFFLAGS: Invalid argument Ustalanie informacji IP dla wlan0... niepowodzenie [root@localhost ~]# ifconfig wlan0 up SIOCSIFFLAGS: Zły argument karta to atheros 5006EG i została wykryta przez system. [root@localhost ~]# lspci 00:00.0 Host bridge: ATI Technologies Inc Unknown device 5a31 (rev 01) 00:01.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge 00:04.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge 00:05.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge 00:06.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge 00:07.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge 00:12.0 SATA controller: ATI Technologies Inc SB600 Non-Raid-5 SATA 00:13.0 USB Controller: ATI Technologies Inc SB600 USB (OHCI0) 00:13.1 USB Controller: ATI Technologies Inc SB600 USB (OHCI1) 00:13.2 USB Controller: ATI Technologies Inc SB600 USB (OHCI2) 00:13.3 USB Controller: ATI Technologies Inc SB600 USB (OHCI3) 00:13.4 USB Controller: ATI Technologies Inc SB600 USB (OHCI4) 00:13.5 USB Controller: ATI Technologies Inc SB600 USB Controller (EHCI) 00:14.0 SMBus: ATI Technologies Inc SB600 SMBus (rev 13) 00:14.1 IDE interface: ATI Technologies Inc SB600 IDE 00:14.2 Audio device: ATI Technologies Inc SB600 Azalia 00:14.3 ISA bridge: ATI Technologies Inc SB600 PCI to LPC Bridge 00:14.4 PCI bridge: ATI Technologies Inc SB600 PCI to PCI Bridge 01:05.0 VGA compatible controller: ATI Technologies Inc RC410 [Radeon Xpress 200M] 02:00.0 Ethernet controller: Atheros Communications, Inc. AR5006EG 802.11 b/g Wireless PCI Express Adapter (rev 01) 08:01.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev b3) 08:01.1 Generic system peripheral [0805]: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 17) 08:01.2 System peripheral: Ricoh Co Ltd R5C592 Memory Stick Bus Host Adapter (rev 08) 08:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10) [root@localhost ~]# nie wiem co robić (temat linuksa jest mi delikatnie mówiąc obcy czyt. brak doświadczenia z nim, dopiero zaczynam) prosiłbym o jak najdokładniejsze wyjaśnienie co robić krok po kroku. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
@perl Napisano Styczeń 20, 2008 Zgłoszenie Share Napisano Styczeń 20, 2008 to ze w lspci wypisalo Ci ze masz ta karte nie znaczy ze system zainstalowal sterowniki, skorzystaj z tej podpowiedzi: http://forum.fedora.pl/index.php?showtopic...st&p=101933 Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
HANS99 Napisano Styczeń 21, 2008 Autor Zgłoszenie Share Napisano Styczeń 21, 2008 niestety nic to nie daje instaluje a w zakładce sieć w ogóle nie ma mojej karty i nawet przy konfiguracji HELP !!!! przed aktualizacją (bo działa mi teraz net przez kabel lecz to rozwiązanie tylko czasowe) karta była wykrywana, już mnie krew zalewa bo nie wiem co robić. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Ponury Napisano Styczeń 21, 2008 Zgłoszenie Share Napisano Styczeń 21, 2008 daj service network restart ifconfig wlan0 adres.ip.routera/maskęsieci zobacz czy zadziała. I zobacz polecenie lspci jak pisał perl Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
HANS99 Napisano Styczeń 21, 2008 Autor Zgłoszenie Share Napisano Styczeń 21, 2008 ładuje mi sie tylko pod kabel [root@localhost ~]# service network restart Wyłączanie interfejsu loopback: [ OK ] Podnoszenie interfejsu loopback: [ OK ] Podnoszenie interfejsu eth0: Ustalanie informacji IP dla eth0... nie powiodło się, brak połączenia. Może sprawdź kabel? [ZAWIÓDŁ] lspci to samo co wcześniej daje nic nowego Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dj_oko Napisano Styczeń 21, 2008 Zgłoszenie Share Napisano Styczeń 21, 2008 Teraz czas na moje kilka śmiesznych rad: - czy używasz jądra Xen? - czy masz uruchmione usługi NetworkManager i WPA Supplicant? - czy włączałeś kiedyś zabawkę "monitor sieci" na panelu? Jeśli nie, zrób to. Ten gadzęt czasem pozwala zgadnąć parę rzeczy. Nazwy interfesjów wpisz ręcznie w Preferencjach (eth0, lo, wlan0). Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
HANS99 Napisano Styczeń 21, 2008 Autor Zgłoszenie Share Napisano Styczeń 21, 2008 jeżeli twoje rady będą bardzo śmieszne i równie szalone pisze się na to jak najbardziej -- xena nie używam zwykłego jajka po aktualizacji (standard) a xen jest lepszy/gorszy ? -- NM jest włączony a co jeszcze ? -- Monitora Sieci chyba żadnego nie mam ? wszelkie opisy będą mile widziane a z racji że normalny nie jestem to sposoby pozornie trudne dla większości są dla mnie łatwe więc ..... Dobrej nocy na dzisiaj już sobie odpuszcze ale zaczne z samego rana Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
