Aver Napisano Październik 8, 2004 Zgłoszenie Share Napisano Październik 8, 2004 (_linux'a_ → Linuksa) ORT (FC2)mam od ... dzisiaj wiec moje pytanie moze wydawa sie glupie ale co jrobie nie tak? Postepuje wg. instrukcji na stronie http://aurox.vel.pl/ (artykul o instalacji kadu). I wszystko bylo by fajnie gdyby nie to ze podczas instalacji pokazuje mi sie komunikat: *************************************** * Configuring Kadu, please wait . . . * *************************************** checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking target system type... i686-pc-linux-gnu checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets ${MAKE}... yes checking for g++... g++ checking for C++ compiler default output... a.out checking whether the C++ compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking for style of include used by make... GNU checking dependency style of g++... gcc3 checking for gcc... gcc checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking dependency style of gcc... gcc3 checking for pthread_create in -lpthread... yes checking if libpng.so library is in system directories... yes checking for QT moc... Qt's moc not found! If you have installed Qt in an unusual place, please use the "--with-qt-moc=" option =============================================================================== Operacja Configure zakończona powodzeniem Teraz będziemy wszystko kompilować =============================================================================== make: *** No targets specified and no makefile found. Stop. ============================================================================= Wystąpił błąd operacja Kompiluj nie powiodła się ============================================================================= Co robie nie tak? Z gory dzieki za pomoc Pozdrawiam Aver Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
skazi Napisano Październik 8, 2004 Zgłoszenie Share Napisano Październik 8, 2004 A nie łatwiej ściągnąć paczkę dla FC2 z tej strony??? Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
Aver Napisano Październik 8, 2004 Autor Zgłoszenie Share Napisano Październik 8, 2004 Ale jak klinke na link z wersja 3.9 (3.8 to samo) - na stronie http://www.kadu.net/download/binary/redhat...at/fedoracore2/ to mi sie otwiera strona z jakimis znaczkami. Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
dwafafiki Napisano Październik 8, 2004 Zgłoszenie Share Napisano Październik 8, 2004 Aver napisał: Ale jak klinke na link z wersja 3.9 (3.8 to samo) - na stronie to mi sie otwiera strona z jakimis znaczkami. kliknij prawy i wybierz zapisz jako.. :lammer: Odnośnik do komentarza Udostępnij na innych stronach More sharing options...
